Granatelli Turbo Install
#241
#242
Keep us updated
You do! ![Thumb](https://themustangsource.com/forums/images/smilies/thumb.gif)
We're working away at it...
I've already verified that I have no intake leaks from the turbo, through the intercooler, to the throttle body via loose/missing hose clamps. What, ME miss a hose clamp??
P'shaw!
I verified via vacuum/boost gauge that the blow off valve IS seeing vacuum AND boost like it should. I hooked one up temporarily to confirm this.
Tomorrow morning, with my wife at the throttle
I will visually verify that the blow off valve is opening and closing properly. Also, I will verify that air is coming out of the blow off valve during the decel of revs from 3000 to 2000 RPM via the "hand in front of the opening of the blow off valve method". This test should confirm or deny a bad BOV.
And here's the major change I will be making: With the consent of Turbonetics, I will be hooking the SIDE port of the waste gate up to manifold vacuum. I do understand that this will limit boost much lower than 13.4 psi. A good thing!
When vacuum in the manifold line changes to boost, it will aide the opening of the wastegate's spring. Therefore, peak psi should be in the 8-10 psi range, and not the 13-14 psi range. What I don't understand, is whether this will help the turbo spool faster... and if it does, HOW it does that.
J.R. / Russ / Anybody - please correct me if I'm wrong on any of this!
![Icon Mrgreen](https://themustangsource.com/forums/images/smilies/icon_mrgreen.gif)
![Icon Rolleyes](https://themustangsource.com/forums/images/smilies/icon_rolleyes.gif)
I hope all works out and that thing makes some more power and it's drivable..Hopefully JR will get it worked out while he is at PRI this week.
Take care.
Rob
#243
Tom - Keep us updated on your progress. I've been watching/lurking on this post as I have planned on buying a Turbonetics kit in Jan/Feb...but I want to see how you make out with JR's kit. I'd like to make sure things are right before I consider anything (as I am sure you would do).
Take care.
Rob
Take care.
Rob
JR is going to drive the car tomorrow. Everything is right with the tune, so it only leaves something mechanical.
What I'm saying is, if I ended up with a bad part (wastegate, BOV, etc.), then you wouldn't have the same issue with spooling.
I limited boost levels down to where they should be with that connection from the manifold to the side of the wastegate. Hopefully JR can determine what is wrong when he drives the car tomorrow.
I'm sure he'll take care of it!
#244
#245
Do you have any sort of boost controller or are you relying solely on the wastegate spring? The only way to get the turbo to spool quicker is with a boost controller. With a controller the wastegate diaphragm does not receive a signal until right before the desired boost setting so the wastegate valve stays closed allowing all the exhaust to spin the turbine. If you are running a line directly from the intake manifold, as soon as the engine starts to make boost the diaphragm will start to open the wastegate valve and begin dumping exhaust slowing the rate of spool.
I'm planning on getting a boost controller down the road, but maybe I should do it sooner than later?
But how come the boost still came in slow when I didn't have anything hooked to the wastegate?
#246
I met with JR Granatelli yesterday and he drove the hell out of the car... in a good way! I didn't have my camera, but the guys with JR got some pictures... including a shot of the 1st and 2nd gear patches through the parking lot. We ran out of room before he could hit 3rd. He's a really nice guy and is totally revolved around customer service.
He had the tuner send me another tune, which I now have on my memory stick. I couldn't get it to upload to the Predator. He's sure from all the testing that everything is working properly. He was under the car while I was revving it to 5 grand checking things out!
After work today, I'm going back to PRI and the DiabloSport guys are going to get the tune into the Predator. Then I'm going to upload the tune to the car and JR has set up 2 dyno pulls for me at the show.
It'll be on a Mustang Dyno, but supposedly, there is a "Dyno Jet" setting.
The new tune will add timing back and take away a little more fuel. When Scott saw the 13 psi, he got really conservative. Now it will be back to normal with about 7 psi max boost levels. Which is perfect for my needs.
I'll post my results tonight! I'm still just hoping for a tad over 400 RWHP. I was almost there last time!
for GMS!
#247
If there is no boost signal going to the wastegate, ie. if there are no vacuum/pressure hoses connected to the diaphragm, the wastegate is not functioning and the engine will develop as much boost as the turbo is capable of making, limited mainly by intake and exhaust restriction. The turbo will also spool at maximum rate when the WG is not operational. 13plus psi is pretty low for an uncontrolled turbo. I would suspect that the BOV spring tension is set too low and it is opening and bleeding off intake pressure.
#248
Now, with vacuum/pressure to the SIDE of the wastegate, it only goes to about 6psi.
Scott pulled timing because of the high boost. With the new improved tune, they are positive max boost will increase to 7psi. That's fine for me.
The DiabloSport people weren't at their booth yesterday, so everything that was supposed to happen yesterday is scheduled for today, instead. The show starts today, so they'll be around today for sure.
#249
The 2nd day at PRI was also a bust for the dyno. ![Nonono](https://themustangsource.com/forums/images/smilies/nonono.gif)
I'm just going to pay $55 to Justin (VMP Tuning) to get the car dyno'd on a Dyno Jet in January at Silver Springs.
I want to get a boost controller and try it out. The new tune is made for 8psi, so that's what I want to set the boost controller to.
Here are install instructions for the wastegate:
http://www.tialmedia.com/documents/w..._wginstall.pdf
See how it says to hook up the SIDE of the wastegate to vacuum/pressure BEFORE the throttle plate?
My connection to the side is from the intake manifold, which is AFTER the throttle body.
Anybody know what the difference is? Or why it would matter?
#250
#251
#252
#253
I keep looking at your dyno chart and, frankly, it is just horrible. Look at the chart posted by Bullitt995. In the span of about 800 RPM his torque balloons from 320 to 480 at 10 psi. He's got full spool and full boost by about 4500 so he has a huge amount of power under the curve. Your NA 89 actually has more torque at 4000 RPM than your GT. That just isn't right. Don't get me wrong. 392 rwhp is nothing to sneeze at. It's a lot more than I have, but it's like being built like Arnold Schwarzneggar and only being able to benchpress 200 lbs. Sure that's more than 95% of the population can lift, but with muscles like that a guy should be able to do a lot more. It just doesn't add up. If I were you I would insist that Granatelli make it right. I'm happy to send you the boost controller (I did find it), but I don't think that is the answer. Even with massive turbo lag you did eventually peak at 13 plus psi so you should be making the same amount of power that everyone else does at that boost level.
#254
#255
I also agree that at 13psi the car shuld have been making 530 to 550 even at 6000
#256
See attachment:
Attachment 36770
And I still agree in general with the comments above. - Tom asked for an entry level kit and that is what he got. Our website shows the entry level kit makes 6psi and only 370hp. But the torque should be in the 410 range. I have agreed to exchange any and all components in question. I personally inspected teh car and it looked A OK
. His turbo has a 1 year warranty as well. However, we need to get the parts back to inspect them before we can just start shipping more stuff. That is standard and only fair.
See attachment:
Attachment 36771
I'm hoping it will show at least 420 on a Dyno Jet. I would like a boost controller so I can set it to 8psi since that's what Scott's new tune is designed for.
As far as the Torque being low, I guess it points to a boost leak. I have the nose off the car right now and every clamp is tight.
I think a wastegate and/or BOV can be shipped without having to put my car out of commission for a week or more. I'll return what I don't use, of course. You said yourself that the turbo has the correct air ratio and it would be VERY rare if it was defective, so let's start with the simple things that I can change in a matter of minutes.
By the way, the new tune that Scott provided made no change in the way the car feels.
#257
See attachment:
Attachment 36771
I'm hoping it will show at least 420 on a Dyno Jet. I would like a boost controller so I can set it to 8psi since that's what Scott's new tune is designed for. .
![](http://www.granatellimotorsports.com/images/artlr/mustangturbo-6psi.jpg)
We know the kits will make 400 to the tire but that was never our written claim on the base kit. The kits will go up to 20psi and we have several cars out the road in the upper 600 low 700hp range.
It really comes down to semantics but you did buy our entry level kit with 39lb inj, MAF and base tune. Granted Scott missed on round one but he was quick to send a new tune and up to the point where you dyno’d it, you wrote how happy you were.
I think a waste gate and/or BOV can be shipped without having to put my car out of commission for a week or more. I'll return what I don't use, of course. You said yourself that the turbo has the correct air ratio and it would be VERY rare if it was defective, so let's start with the simple things that I can change in a matter of minutes.
In closing, I am not sure if it is your driving style or not but Scott added 5^ of timing in the middle which would make a huge difference seat of the pants. And again all due respect you said the car would not break the tires loose and that was a non-issue when I gave you a ride. I never banged gears and never even shifted your car above 5500 and it still managed to lay rubber in second for 3 or 4 feet until I lifted. With all this said I still agree your car is not the fastest 6psi 2006 Mustang I have ever driven and I am willing to inspect your parts the same day they come in. I also offered to send you a spring that will increase your boost to 8psi. If Scott told you the tune was set for 8psi that does not mean GMS owes you an 8psi spring. However we are giving that to you as well in an effort to make you happy. Comparing the stroker motor in your 89 to a mod motor from idle to 4500 is apples and watermelon.
#258
I would get a boost controller if I were you. The only reason my 76mm spools up at a respectable pace is because of the Eboost-2 that I had installed at the same time. Paul at SVPU told me it definatly helps with the lag by controlling how the wastegate opens. It's also got TONS of options. Plus it saved me money instead of buying an electronic boost gauge + boost controller.
#259
#260
Let's be perfectly clear: I didn't buy an "entry level kit". The entry level kit didn't come with injectors, mass air meter, or the Predator w/tune. The instruction manual says 7psi and I was told 420 RWHP would be no problem.
See attachment:
Attachment 36771
See attachment:
Attachment 36771
The wording should be corrected to something along the lines of a HP range that can be expected and to specifically say the HP is measured at the rear wheels (not will support 450 to the rear wheels). That would cover the difference inherit from auto to auto.
From what I've learned here at TMS Tom is one of the most honorable members we have and now this thread is veering in a direction thats seemed to be almost foreseeable given others experiences..................
I don't agree with the response GMS provided in the previous post, frankly I was hoping the vendor would have gone out of there way to ensure this turned out to be a very positive experience, especially since its getting such visibility with its focal thread. Seems like there are a number of vendors here who really understand customer service and how to ensure their customers are totally satisfied, vendors such as MGW or Brenspeed come immediately to mind.
I'm in the Just Fix It and Make the Customer Happy and Right! camp, NOW
Very disappointing to me, hang in there Tom, I hope this sorts itself out for you and you end up totally satisfied.
