Sponsored by:
Sponsored by: CARiD
Rumoured power outputs for '15
Old May 19, 2013 | 07:11 PM
  #161
lexi2013's Avatar
Originally Posted by Mr. V
This is obviously why I am single and bought a GT.
Do you also kick sand in the face of nerds at the beach and stuff others in lockers too? :P
Old May 19, 2013 | 08:49 PM
  #162
Dave07997S's Avatar
Don't buy the 3.7V6 at 400hp at all..that would be 108hp/litre, not unless it redlines at 8300 rpm like a BMW M engine.
Dave
Old May 19, 2013 | 10:27 PM
  #163
MustangDizzle's Avatar
Dave
Ya, that's definitely bullcrap. Not happening.
Old May 20, 2013 | 05:43 AM
  #164
Overboost's Avatar
Dave
I like how you had to reference the BMW engine here. Ford won't make a V6 that close to the GT. Simple as that.
Old May 20, 2013 | 06:43 AM
  #165
Twin Turbo's Avatar
Indeed, the M3/M4 will be reverting back to 6 cylinders, soon, but even that will rely on turbos to get a little over 400bhp, so don't be looking for that sort of power in a n/a V6 from Ford.
Oh, and what have I started with this thread? I wasn't expecting this
Old May 20, 2013 | 08:42 AM
  #166
conv_stang's Avatar
Originally Posted by lexi2013
What about just this
Turbo 4- 300-325hp (plus less weight from having a smaller engine and the 150lbs ford promised and irs suspension)
V8- 430-450
This to me sounds a little bit better a slight hp increase plus less weight, and the people who buy the base model aren't restricted at all you could just tune it and get around 360-370 with a turbo 4. Not to mention if ford uses a engine from the focus rs or something similar I'm sure it'll have other mods like cams and heads and the list goes on.
But is the turbo 4 going to weigh less than the 3.7? It's the same thing with the Ecoboost V6, it weighs the same as the 5.0. Smaller turbo engines don't necessarily weigh less than their larger counterparts.
Old May 20, 2013 | 09:24 AM
  #167
CCTking's Avatar
This. The added weight of the turbo system, especially the intercooler may make it as heavy if not heavier than the next size motor
Old May 20, 2013 | 09:27 AM
  #168
Mr. V's Avatar
I believe this would depend on the motors being used. When I bought an a4 the v6 weighted more than the 4cyl turbo by 100 pounds. After just tuning it(increasing the boost pressure) they had the same power. There is a possibility of weight savings with a turbo but it depends on the design.
Old May 20, 2013 | 10:45 AM
  #169
lexi2013's Avatar
2.5 liter turbo in the subaru is light. The car weighs in around 3100-3200 nod that's mostly because of the awd. I think a similar displacement and turbo set up should weigh considerably less than a v6 enspecially if it's all aluminum.
Old May 20, 2013 | 01:59 PM
  #170
conv_stang's Avatar
STI weighs right around 3400 depending on options. And the EVO is over 3500.
Old May 20, 2013 | 03:19 PM
  #171
lexi2013's Avatar
Either way isn't that 200 less then the current v6?
Old May 20, 2013 | 03:34 PM
  #172
steven46746's Avatar
V6 is around 3500
Old May 20, 2013 | 04:36 PM
  #173
CCTking's Avatar
Originally Posted by steven46746
V6 is around 3500
So its similar weight, but the other two vehicles both have AWD and that adds weight. As do the extra two door and added metal compared to the mustang
Old May 20, 2013 | 05:15 PM
  #174
lexi2013's Avatar
Without the awd it probably would weigh in the 2000lbs range for the wrx and very low if not in the 2900lbs range for the Sti. If I'm wrong someone correct me.
Old May 20, 2013 | 05:54 PM
  #175
Gabe's Avatar
AWD tends to add only about 200-250 lbs, not 400-500 like in a truck
Old May 20, 2013 | 06:23 PM
  #176
lexi2013's Avatar
Then that would put the wrx at around 2950-3000lbs. I believe the Sti has more to the drivetrain to weigh 200 more than the subie wrx. Though if you minus the weight of extra doors like someone said it should be in the really high 2000lbs range.
Old May 20, 2013 | 06:33 PM
  #177
3400 - 200 = 3200lb. Also wouldn't be so sure about the weight of the 2 extra doors, the difference in a 4 door civic Si to a Si coupe is 13lbs. Taking the awd from a Evo or Sti would take away any advantage or edge they ever had.
Old May 20, 2013 | 07:07 PM
  #178
lexi2013's Avatar
Edmonds has the curb weight at 3215 not 3400. Either the wrx Sti weighs more than the regular wrx or Edmonds is wrong.
  #179
bob's Avatar
bob
Wasnt the LT1 worse then the LS?
The LT1 was an evolution of the original small block V8, opti-spark ignition aside it was a good engine (IIRC in its final LT4 configuration put out over 400 hp) The LS engines were a clean sheet design.
In any event when the LT1 hit, GM had 275hp on tap for the Camaro and Ford dumped a big steaming pile on the Mustang faithful by not bothering to do anything with the 5.0 mill and only offering a limited number of cars with the 5.8 then to add insult on top of injury they dropped the not ready for Mustang duty 2v 4.6 in.
People can pick on Gubament Motors all they want but you have to respect their dedication to an engine platform. It would be nice if Ford would slow down trying to reinvent the wheel every coupla years and go with one good solid platform across various model lines.
Old May 20, 2013 | 07:57 PM
  #180
CCTking's Avatar
Ford doesnt exactly reinvent something every couple of years. I mean look how long the 2v 4.6 was in the line-up, they stuck with it for a while. Then when the new camaro came out and stomped 2010 gt figures Ford responded with a brand new toy of their own in the form of the 5.0.
Now that the 50th anniversary and global push are around the corner it would make sense to bring somethin copletely brand new to the table
