412hp!!! Is it true???
Old Dec 18, 2009 | 08:26 AM
  #101
Boomer's Avatar
I love reading comments on other sites.
They have no idea of gears, weight, power curve etc and they just continue to make stupid comments.
People have NO clue. Whatever helps them sleep at night.
Old Dec 18, 2009 | 08:31 AM
  #102
Overboost's Avatar
Originally Posted by IWantMyNewGT
So it could be 390...
You may be correct, but I can't confirm that
Old Dec 18, 2009 | 08:32 AM
  #103
Overboost's Avatar
Ignorance is an epidemic. I would bet most of those sites also take stabs at the SLA because they have nothing else of worth to say.
Old Dec 18, 2009 | 08:38 AM
  #104
CO_VaporGT_09's Avatar
Confirmed on Autoweek:
http://www.autoweek.com/article/2009...ROIT/912189996
412hp @6500 rpm, 390 lb-ft.
Twin independent valve timing?! Tuned length headers?! What's the world comin to...
Old Dec 18, 2009 | 08:40 AM
  #105
Overboost's Avatar
Yep, that's all the info I heard. Cat's outta the bag now.
Old Dec 18, 2009 | 08:41 AM
  #106
IWantMyNewGT's Avatar
Old Dec 18, 2009 | 08:42 AM
  #107
RandyW's Avatar
Yeehaw! Giddyup, my little pony.
Old Dec 18, 2009 | 08:46 AM
  #108
rony1976's Avatar
Is 412 really that impressive? I mean, Saleen already did it with the Parnelli Jones. BMW can squeeze 400hp out of a 4.4L V8 @ 5,500rpm, I don't think 412 @ 6500rpm is that impressive... I'm all for Ford products, but I expected 450 out of it, not that close to 400.
Old Dec 18, 2009 | 08:49 AM
  #109
Overboost's Avatar
So, to sum up the Autoweek post:
-412hp/390tq @6500rpm
-tuned length headers
-all-aluminum block, cast iron sleeves
-4 blot main bearings
-25mpg
-forged steel crankshaft
-wide distance between heads allows intake ports to sit vertically on engine
Old Dec 18, 2009 | 08:51 AM
  #110
Five Oh Brian's Avatar
Originally Posted by fdjizm
btw why would torque be lower than HP on a bigger displacement engine?
5.0L may be bigger than 4.6L, but it is still a relatively small engine by V8 standards. I imagine that it is an oversquare configuration (bore is bigger than stroke), so it is designed more for revs and hp. Undersquare (longer stroke than bore) would yield bigger torque numbers, but yield smaller hp #'s - and we all know that hp sells cars (even though torque "supposedly" wins drag races).
So, I would not be surprised to see 412hp & 380tq for this new 5.0L. Dang, that's very close to my supercharged 07 GT (~455hp / ~380tq at the flywheel). Guess I need to mod just a little more to put some distance on the '11 GT's...
Old Dec 18, 2009 | 08:56 AM
  #111
Boomer's Avatar
Wow, someone couldn't keep their traps shut.
Old Dec 18, 2009 | 08:57 AM
  #112
Overboost's Avatar
Yeah, it's only 10 days early.
Old Dec 18, 2009 | 08:58 AM
  #113
RedCandy5.0's Avatar
Christmas has come early guys!
Old Dec 18, 2009 | 08:59 AM
  #114
My guess is the compression ratio on this motor is lower than the M3's (4.0 liter) 414hp engine (only 295 lb-ft), to allow a FRPP supercharger without changing the pistons. Higher compression ratio always gives a higher specific output, usually at higher revs, and BMWs mills are known for that. I also think the M3 and M5 V8/V10 use individual throttles for each cylinder, correct? Though now Ford has a double variable camshaft timing too...
Old Dec 18, 2009 | 09:03 AM
  #115
zzcoop's Avatar
Sounds **** good to me. Besides, I'm sure it's capable of a LOT more. Why blow your wad right out of the gate if you don't have to?
Old Dec 18, 2009 | 09:04 AM
  #116
Dave07997S's Avatar
Exactly..
Dave
Old Dec 18, 2009 | 09:05 AM
  #117
yeahyouknwit's Avatar
Goodbye '03 hello '11 :-)
Old Dec 18, 2009 | 09:14 AM
  #118
2010MustangGT's Avatar
Where's that peak torque reached at RPM wise?
I'm hoping below 5k...
Old Dec 18, 2009 | 09:24 AM
  #119
i3arracuda's Avatar
I really think it is impressive when you compare it to an M3. You have an engine that makes 2 less peak HP but nearly 100 more lb-ft of TQ, all in overall package that gets 20% better fuel economy and costs $20K-$25K less.
Old Dec 18, 2009 | 09:33 AM
  #120
SynisterGT's Avatar
Autoweek
"To Ford Mustang fans, 5.0 means a lot, and the new 2011 5.0-liter V8 Mustang will deliver 412 hp and 390 lb-ft of torque, company officials said on Thursday. The information was supposed to be embargoed until Dec. 28, but news leaked out shortly after the announcement in Dearborn, Mich.
The new 5.0-liter Mustang produces 83 hp per liter yet will return 25 mpg, according to Ford marketing boss Jim Farley. The 5.0-liter Mustang’s main competitors are the Chevrolet Camaro SS, rated at 426 hp, and the Dodge Challenger SRT8, which makes 425 hp. Of course, the top-of-the-line Shelby GT500 and its supercharged V8 is rated at 540 hp.
What makes the brand-new V8 engine powering the ’Stang so potent is how engineers were able to allow the engine to breathe. All-new heads sit atop an all-new aluminum block with cast-iron cylinder sleeves. The wide distance between the heads allows for the intake ports to sit vertically on top of the engine. The engine features four valves per cylinder and twin independent variable valve timing. Tuned exhaust headers eliminate the need for aftermarket headers to let the engine breath better. Inside the engine are a forged-steel full counterweight crankshaft and four-bolt main bearings and high-performance pistons and connecting rods. Peak horsepower is reached at 6,500 rpm.
The new 5.0-liter Mustangs can be fitted with either the 6R80 automatic transmission or the MT82 six-speed manual.
The pony car will make its official debut at the Detroit auto show in January."
Read more: http://www.autoweek.com/article/2009...#ixzz0a3gPZuA0
So I am glad that we have a forged steel crankshaft but when they say perfformance pistons and rods does that also mean forged as well? I don't want to worry about blowing out the engine when adding a sc to the already potent 5.0
So what they are saying is that going aftermarket with headers will not yield that much of a gain or what? Will there even be a need to replace them except for changing the sound?
