Notices
'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old 5/31/14, 04:06 PM
  #1781
BlueEyedSnake's Avatar
Originally Posted by LEXiiON
Little update from this evening..
We solved some items: the red tach is gone, the black box is working and displaying IAT.
We couldn't program boost and AFR, as the real voltage on the analogs exceeded the max allowable by the black box.
The manual stated differently, but we didn't want to risk frying the black box.
ABS module is going to be a challenge.
Next steps: Matt will create a analog/digital converter for boost and AFR, that will convert that for the black box.
I will monkey around with the as build data to get rid of the oil life message.
Odo correction couldn't be done, as I forgot my second key at home.
That's it for now, good night
LEXiiON
How did you get raid of the red tach light between 6250 and 7000 RPM'S? LC will never work if I can't get raid of it. Glad to hear that things are looking well for you with the cluster install.
Old 5/31/14, 04:10 PM
  #1782
LEXiiON's Avatar
No the redline is still there. The tach turned completely red once light is on. That's gone. I don't think my PCM supports LC.
LEXiiON
Old 5/31/14, 06:04 PM
  #1783
FYI, VCM II's are only $110. **** I paid $159.... Lol
Old 5/31/14, 07:50 PM
  #1784
LEXiiON's Avatar
I paid $199 $&@$@@!!
Old 6/1/14, 10:44 AM
  #1785
LEXiiON's Avatar
I downloaded my as build into the cluster today, to get rid of the oil message. Indeed it is gone. However, all gauges, and TrackApps are gone too.
Old 6/1/14, 10:59 AM
  #1786
dmhines's Avatar
Was your car a base or premium ?
Old 6/1/14, 11:00 AM
  #1787
LEXiiON's Avatar
Premium
Old 6/1/14, 11:13 AM
  #1788
dmhines's Avatar
I would think atleast the extra gauges would be there. Gonna have to stick with 2013 as built. Guess you could experiment mixing the codes and figure out which one turns off the oil light
Old 6/1/14, 11:17 AM
  #1789
jim010's Avatar
I knew track apps would be gone, but the guages are interesting. So to be clear, guages and track apps are removed from the menu?
Old 6/1/14, 11:20 AM
  #1790
LEXiiON's Avatar
Correct
Old 6/1/14, 11:21 AM
  #1791
LEXiiON's Avatar
I guess that would be an option. Although it comes with a checksum. So basically it is only two different possibilities (mixing the lines)
LEXiiON
Old 6/1/14, 11:27 AM
  #1792
LEXiiON's Avatar
I guess that us a good option if I ever want to sell it. Removes all the extra stuff and no black box necessary.
LEXiiON
Old 6/1/14, 11:50 AM
  #1793
jim010's Avatar
Yeah, I'm thinking for a 2005-2009 car.
Old 6/1/14, 12:39 PM
  #1794
LEXiiON's Avatar
SUCCESS!!
I put in the first line of the as build from my 2010 premium and the second from a 2013 GT500:
Result: Oil change message is gone, all menus are there: TrackApps, Gauges etc... Blackbox works as designed for now and displays IAT. red Tach is still gone, when black box active. Oil life reset menu is completely gone (was the same with my 2012 Boss cluster)... back to manual oil changes ... but no more error messages
So if any one wants to know, this is the as build combination I put in:
720-01-01 CB99 EF60 DC
720-02-01 F80E 8000 B0
LEXiiON
Old 6/1/14, 02:19 PM
  #1795
dmhines's Avatar
Gotta like the simple solutions.
Old 6/1/14, 02:22 PM
  #1796
LEXiiON's Avatar
Yes Sir!!
Now the last three items are:
AFR and Boost
Odo correction
TrackApps
But I think, TrackApps requires some major effort. I will see what I can do there. Lowest priority now.
LEXiiON
Old 6/1/14, 02:49 PM
  #1797
jim010's Avatar
Zero originally thought of adding an accelerometer to his black box. He still looking at that?
Old 6/1/14, 02:52 PM
  #1798
LEXiiON's Avatar
We talked about this. He thinks it is too dangerous.
LEXiiON
Old 6/1/14, 05:13 PM
  #1799
dmhines's Avatar
Originally Posted by McLovin
P.S. Still waiting to see pics of your car Dan!
I just went and snapped a few ....
Old 6/1/14, 05:52 PM
  #1800
LEXiiON's Avatar
Nice car Dan!!!
LEXiiON
Quick Reply: '13-14 Cluster into '10-12 car (with TrackApps) retrofit
