Notices
'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old 5/19/14, 05:47 PM
  #1681
dmhines's Avatar
The headlight switch bezel is not sold separately from the switch. Cheapest way to get one is buy a used 2010-2012 base Model switch and bezel and then swap switches.
Old 5/19/14, 07:43 PM
  #1682
McLovin's Avatar
Bummer.
I've found a TON of salvaged mustangs but I sadly cant afford to buy them for 2 pieces lol.
Old 5/19/14, 09:29 PM
  #1683
McLovin's Avatar
This freakin part is going to be the BANE of my existence. Holy crap I have never had so much trouble finding a part before! :-\
I bought mine cheap off ebay ... just buy a base model 2010-2012 switch and swap your Foglight switch into the plain housing. I don't think you can buy just the housing ...
This is kinda pricey but I bought one of these and swapped my switch.
Mustang LX Head Light Switch Dimmer 2010 2011 Lamp Headlight Headlamp No Fog | eBay
Old 5/23/14, 04:34 PM
  #1684
LEXiiON's Avatar
Hi All,
quick update. EPAS came in today. Looked at it and found two issues to resolve before the retrofit can happen:
1st: Need a way to get the bracket marked in picture below retrofitted (don't necessarily want to buy a new K-Member)... Only there with EPAS, mine doesn't have it. If i want to do it right, i need to remove the K-Member and weld it on...or buy a new K-Member ($309 OE Ford, $480 aftermarket)... Now you guys know the difference between 05-10 and 11-14 K-Members... the additional bracket for the EPAS
2nd: I need the connectors to retrofit the wiring. That requires some research. I couldn't find them yet. If anybody has an idea which connector type C1453A and C1453B are? That would help.
Thanks,
LEXiiON
Attached Thumbnails '13-14 Cluster into '10-12 car (with TrackApps) retrofit-2012kmember.jpg
Old 5/23/14, 05:09 PM
  #1685
BlueEyedSnake's Avatar
You should through up a want to buy post on the svt performance forum and see if any of the 2011-2014 guys have there stock k-member for sale. A few guys have upgraded there to the bmr or some other after market brand.
Zeroaviation, I was wondering do you think it would be possible for me to flash my PCM to a 2013 GT500 PCM firmware with calibration? I can't for the life of me get the the ABS or Traction Control lights to turn off. My tuner said that getting me a new tune in order to get my car to run would be easy. He is just concern is that everything in my car communicate as it should with no DTC's, etc.
Old 5/23/14, 06:08 PM
  #1686
LEXiiON's Avatar
Dmhines and Jim successfully flashed their PCMs to 2013. They can tell you how to do it with IDS.
LEXiiON
Old 5/23/14, 07:03 PM
  #1687
-I just did it..... I'm am now DR3A-12A650-AJD, I used to be BR3A-12C204-BKA.
My Strategy used to be FGDH3S3 and now is FGFC3C5.
-Now when I connect the IDS to my car it shows as 5.8L instead of the 5.4L.
All gauges work with the black box off and the switch even though it was modified still works fine so far.
-Now the bad news, I still have the ABS and Traction Control light on. I reflashed the ABS and did the as built data. Any idea's anyone?
-I now have to get the tune on my car updated since it is running lean due to larger intake, TB and Supercharger over the factory 2013 GT500 PCM calibrations.
By the way, It only took less than 10 minutes from start to finish when IDS programmed my PCM to include the time it took to erase it.
Old 5/23/14, 07:04 PM
  #1688
dmhines's Avatar
The PCM will flash. But 2013 gt500 has differnt engine so that is the problem. You have to pmi the abs module with your vin.
Old 5/23/14, 07:07 PM
  #1689
LEXiiON's Avatar
Ok the only idea I have now, is that this f*****g ABS module is bad...
Which means, I need to order a new one ..grrrrr
And that seller sold me a bad module...
And it also means, I could have tried until my Stang is a piece of rust until that thing would ever have worked...
LEXiiON
Old 5/23/14, 07:09 PM
  #1690
Picture after it was done programming the PCM.
Picture of the DTC.
  #1691
dmhines's Avatar
The modified cruise control switch is turning the cruise indicator on in the cluster ? Jim's did not.
Old 5/23/14, 07:12 PM
  #1692
dmhines's Avatar
If you go back in this thread. You will see that is exact dTC I got before doing pmi. It is indicating abs vin does not match PCM vin.
Old 5/23/14, 07:13 PM
  #1693
LEXiiON
Red Dot is still in the middle and I used the 0-60 timer a few times even though the lights are on and it worked. So I have no idea whats going on. Did Matt get the one I sent him working? If you get another one, you think you could send it my way? I'll pay for expedited shipping cause this ABS thing is killing me.
Old 5/23/14, 07:15 PM
  #1694
dmhines's Avatar
Track apps will still work even with vin mismatch.
Old 5/23/14, 07:22 PM
  #1695
LEXiiON's Avatar
Well he did the PMI.. Same issue as I have...
Old 5/23/14, 07:24 PM
  #1696
LEXiiON's Avatar
Is this for real????
LEXiiON
Attached Thumbnails '13-14 Cluster into '10-12 car (with TrackApps) retrofit-abs-module.jpg
Old 5/23/14, 07:27 PM
  #1697
dmhines's Avatar
And he did pmi with his Vin? And the PCM Also shows his correct Vin?
  #1698
dmhines's Avatar
Yes ford dropped price of module.
Old 5/23/14, 07:31 PM
  #1699
LEXiiON's Avatar
Yup.. He flashed his original 2012 PCM to the 2013 code and did a PMI again on the ABS module... I believe that thing is dead, as it should have worked with his 2012 PCM code, too.
It would have never ever worked in my GT...and it never did
LEXiiON
Old 5/23/14, 09:37 PM
  #1700
dmhines's Avatar
Just spent 2 hours on phone .. and NO GO. We PMI with His VIN. PMI with 2013 VIN. Change VIN in PCM to match VIN used for 2013 PMI .. still software mismatch error.
So Jim and I were able to do PMI and it worked. We went from a 5.0 to a 5.0 .
Lex is having problems .. but he is going from 4.6 to 5.0.
BES is having problems .. but he is going from a 5.4 to a 5.8.
Not sure if changing engine has anything to do with it.
And I put a used ABS module in my car and it worked fine. Jim put a new ABS module in his car and it worked fine.
Quick Reply: '13-14 Cluster into '10-12 car (with TrackApps) retrofit
