'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old Apr 9, 2013 | 11:25 AM
  #141
Greg2011's Avatar
Any idea where I can get a cheap 2011-2012 cruise switch to take apart?
Old Apr 9, 2013 | 12:26 PM
  #142
jim010's Avatar
Will be a bit of work to make it look good. At least it is a square cutout that is needed.
Have you tested the switch? Does it work?
Old Apr 9, 2013 | 12:29 PM
  #143
jim010's Avatar
They are pretty cheap new. $20 maybe?
  #144
dmhines's Avatar
I am at work. Will test tonight.
Old Apr 9, 2013 | 01:04 PM
  #145
zeroaviation's Avatar
Do either one of you Gentlement have any electronics experiance? I may be able to assist you in getting the disired information you want to display on your screen. This would be reading the information from the OBD line of traffic, and re-introducing it on the MS-CAN network using a seperate microcontroller. As far as the Track Apps are concerned, I have it on good.. well knowledge, that the application itself is embeded into the gauge microcontroller, it just neeeds to be activated at Key On
PM's welcome.
Old Apr 9, 2013 | 01:12 PM
  #146
dmhines's Avatar
PM's welcome.
No experience here but glad to have you in this thread ... Apparantly SCT can't turn off PATS so I have been starting my Car with 2012 cluster and then swapping in the 2013 cluster while car is running. Are you thinking the track apps will be enabled once I have the PATS relearned and I start the car with the 2013 cluster installed? Or is there more too it than that?
Old Apr 9, 2013 | 01:23 PM
  #147
jim010's Avatar
Absolutely would love assistance. At this point, I just want to confirm that the directional/ok buttons work and that cruise works or not.
+1
Old Apr 9, 2013 | 01:38 PM
  #148
Greg2011's Avatar
PM's welcome.
OMG we finally got a real engineer on here! Is there a way to reprogram the cruise control in the PCM?
Old Apr 9, 2013 | 01:43 PM
  #149
stangfoeva's Avatar
MOTM Committee Member
I love this thread!
Old Apr 9, 2013 | 01:48 PM
  #150
jim010's Avatar
Also, will dowloading the 'as built' data onto the 2013 cluster disable all the functions like Track Apps and the like?
Old Apr 9, 2013 | 04:32 PM
  #151
jim010's Avatar
My cluster is here! $46 in brokerage fees + $25 shipping! Yay!
Old Apr 9, 2013 | 04:36 PM
  #152
jim010's Avatar
My service manager at my local Ford dealership (he's very knowledage and helped me with the nav retrofit) figures that as built data will NOT need to be uploaded into the new cluster, and that PATS will not be an issue.
I now have the diagrams I needed. Just need to go over them.
Old Apr 9, 2013 | 04:53 PM
  #153
dmhines's Avatar
Thats good to hear .. so you are going to leave the 2013 as built data in the cluster? I have read that when the technician does the PATS Relearn .. he should tell the system the PCM was replaced and not the Cluster. If the tech tells the software that the relearn is for a replaced cluster then it will want to reload the as built data.
I was able to test the buttons ...
Old Apr 9, 2013 | 05:01 PM
  #154
jim010's Avatar
OK, here it is:
2012
-to the clockspring (c2274a)
Pin 1 - airbag driver 1
pin 2 - airbag driver 2
Pin 3 - unused
Pin 4 - switch Audio w/ SYNC 2 -
Pin 5 - ground cross car beam
Pin 6 - switch Audio /w SYNC 2 +
Pin 7 - unused
Pin 8 - horn
Pin 9 - airbag driver 1
Pin 10 - airbag driver 2
Pin 11 - unused
Pin 12 - switch audio 1 -
Pin 13 - switch audio 1 +
Pin 14 - cruise control command return
Pin 15 - cruise control command
Pin 16 - illumination
2013
Pin 3 - switch info
Pin 7 - unused
Pin 8 - horn
Pin 11 - switch info
2012
-from clockspring (c2274a) to clockspring (c2274b)
Pin 1 - horn
Pin 2 - unused
Pin 3 - bluetooth
Pin 4 - ground cross car beam
Pin 5 - climate sensors and generic vref return in logistical schematics
Pin 6 - unused
Pin 7 - illumination
Pin 8 - cruise control command
Pin 9 - cruise control command return
Pin 10 - audio pwr
Pin 11 - audio return
Pin 12 - unused
2013
Pin 1 - horn
Pin 2 - unused
Pin 3 - bluetooth
Pin 5 - bluetooth return
Pin 6 - switch info
Pin 10 - audio pwr
Pin 12 - switch info
2012
- from clockspring (c2274b) to left steering wheel switches (c2998)
Pin 1 - illumination
Pin 2 - cruise control command
Pin 3 - cruise control command return
Pin 5 - horn
Pin 6 - unused
Pin 7 - unused
Pin 8 - unused
Pin 9 - unused
Pin 10 - unused
2013
Pin 1 - cruise control command return
Pin 2 - switch info
Pin 3 - switch info
Pin 4 - unused
Pin 5 - unused
Pin 6 - ground
Pin 7 - cruise control command
Pin 8 - illumination
Pin 9 - unused
Pin 10 - unused
Old Apr 9, 2013 | 05:04 PM
  #155
jim010's Avatar
No track apps ...
Oh well, not a deal breaker for me. I spent not much on the cluster. Just want cruise to work right.
Old Apr 9, 2013 | 05:07 PM
  #156
dmhines's Avatar
What the heck is switch info? You have steering wheel harness side of clockspring to see where switch info goes?
Old Apr 9, 2013 | 05:13 PM
  #157
10MustangGT's Avatar
So no chance at all of track apps?
Old Apr 9, 2013 | 05:15 PM
  #158
dmhines's Avatar
Oh duh. Switch info is the 4-way ok button.
Old Apr 9, 2013 | 05:26 PM
  #159
jim010's Avatar
He wasn't 100% sure. He did say that I should have the VIN the cluster came out of handy, as if there is an issue, he can look at the lines of code and tackle it from there. That would be more trouble than its worth, though.
Old Apr 9, 2013 | 05:30 PM
  #160
jim010's Avatar
I got muy service guy to print off the cruise control with resistor values. I have different values than below for a 2013, assuming I'm reading it right.
The PCM controls the cruise functions based on the voltage signal it receives.
2011
Off: Short
On: 2.11 K
Set -: 300
Set +: 600
Res: 1.11 K
Cncl: N/A
2013
Off: Short
On: Short
Set -: 120
Set +: 300
Res: 600
Cncl: 600
That only leaves 3 options:
1) Modify the switch to give the correct signals.
2) Modify the PCM programming to accept the signals you send.
3) Swap in a 2013 PCM, harness, and clock spring.
