'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old Sep 11, 2014 | 07:15 PM
  #2141
dbrford's Avatar
Read through this post over the last few days. Very interested in doing this to my 2011 GT. Question, I saw reference to someone that had Roush programmed PCM. Was there ever a solution to this? I am running the Roush Phase 3 on my car and my PCM was sent to them to be reprogrammed. I know I can run the blackbox but would like to have everything working including the cruise lights. Thanks
Old Sep 12, 2014 | 10:42 AM
  #2142
awoychosky123's Avatar
The lights on the cruise switch will work if wired correctly (I kinda screwed up the first time :P) I know that a ford IDS tool can not properly configure a Roush PCM so what I would do is send it to Roush again and see if the will reprogram it to a 2013 or 14 and see if it works if not your best bet is the black box. Matt if you have anything to add your expertise would probably be more useful than mine.
Old Sep 12, 2014 | 11:39 AM
  #2143
jim010's Avatar
I also think you may need to go with a Black Box to avoid the hassles.
I would add that the cruise lights will work only if you program the PCM. If using the Black Box, then you need to modify the switch. But even with modifying, the cruise lights won't work.
See here post#4 for modifying the switch:
https://themustangsource.com/forums/...luster-529167/
Old Sep 12, 2014 | 01:05 PM
  #2144
I reprogrammed my pcm but never modify d the switch does that mean that my cruise control does work?
Old Sep 12, 2014 | 02:11 PM
  #2145
dbrford's Avatar
Thanks for the responses. Amazed at the level of effort that went into getting this work.
I am thinking I will try Roush, might tell them I demodding to see if they will put stock config back on the computer. Other option might be to look for a PCM from a salvage. Car will be parked in the next month or two for winter so will see what I can do during the downtime.
Old Sep 12, 2014 | 02:45 PM
  #2146
jim010's Avatar
Your cruise will be fine, as long as you changed the wiring. No modding of the cruise circuitry needed.
Old Sep 12, 2014 | 05:25 PM
  #2147
Ya I went and tried it out and thats great that it all works light illuminates all the buttons work how there supposed to! Best mod I have ever done hands down!
Old Sep 23, 2014 | 02:44 PM
  #2148
Moejoe_989's Avatar
Does anyone know how difficult it would be to swap the Roush stage 3 speedo (220 MPH) into a Canadian GT? I'd still want the Canadian roush speedo.
Is it as simple as purchasing the speedometer faceplate and getting it tuned at my dealer?
Old Sep 24, 2014 | 07:26 AM
  #2149
Eh you will have to buy a faceplate in km/h or buy the new cluster from ford/roush with that option.
Old Sep 24, 2014 | 07:32 AM
  #2150
Moejoe_989's Avatar
I just want the 360 km/h speedo. 220mph for my American friends. Is it possible to switch to that on my GT?
Old Sep 24, 2014 | 08:32 AM
  #2151
jim010's Avatar
It is no problem. I had to buy an American cluster. It was a simple matter of just switching out the face with a Canadian one, that is all.
You can have Black Cat Custom do a custom one for you as well.
Old Sep 29, 2014 | 04:54 PM
  #2152
mmmojo's Avatar
I just did the conversion last week but still no track apps showing up on my cluster!!! Every time I try to PMI the PCM it reads the 2012 CR3A part number on the PCM and will not let me program it to a DR3A number, so, as a result, no track apps showing up!!! I can't even get in to manually enter the as built data for a 2013 PCM. Each time I try to enter the As Built data, it goes to the Ford website and downloads the as built data for the particular PCM part number that it is reading off of my PCM rather than what I enter as the part number. Anyone encounter this or have a fix for the issue? BES has been trying to help me also since we're local to each other but I seem to keep running into the same issue. Any help would be greatly appreciated!!!
Old Sep 29, 2014 | 05:35 PM
  #2153
dmhines's Avatar
The PCM does not enable track apps. The 2013+ ABS module does.
Old Sep 29, 2014 | 08:49 PM
  #2154
mmmojo's Avatar
That's strange. BES's directions on the SVT forum are to enter the part number for a 2013+ and PMI the PCM. I put a 2014 ABS module in that I bought from Tousley but that did not enable Track Apps at all. I bought a 2014 SVT cluster plus a 2014 steering wheel and all the correct steering wheel controls from Tousley also. Are you sure that the PCM doesn't have to be PMI'd as a 2013+ since my car is a 2012?
Old Sep 29, 2014 | 08:51 PM
  #2155
mmmojo's Avatar
One other thing, for the ABS module, I put in the as built information code 056E which I got from a 2013 GT with track apps to clear the ABS light from flashing (which it did clear it up).
Old Sep 29, 2014 | 08:53 PM
  #2156
dmhines's Avatar
You PMI the ABS module to enable track apps .. without the PMI you should be getting ABS, Traction Control and ESP error lights. You reflash the PCM to a 2013 calibration (at your own risk) to enable Cruise Control and the extra gauges on the cluster.
All the instructions are in the other thread. Make sure when you install you software you indicated your were a DEALER when asked. You can make up a number.
Old Sep 29, 2014 | 09:04 PM
  #2157
dmhines's Avatar
I saw your other thread .. it seems like you had Ford load Base GT As-Built into a GT500 cluster. You need to load Premium GT AS-Built into your cluster to enable Track Apps Menu. You then need to PMI the ABS module to get rid of the error lights - Track Apps function may work even with the ABS error lights on. I know Track Apps worked fine on my car even with all the error lights until I PMI'd the ABS module. My ABS module was used not new.
Keep in mind you cruise will not work properly and the extra gauges like A/F Ration will not work unless your flash your PCM to a 2013.
Old Sep 29, 2014 | 09:05 PM
  #2158
mmmojo's Avatar
okay, thanks. I will try that. I will have to uninstall IDS and reinstall it. The ABS module that Tousley sold me is part number DR3Z-2C219-A. They told me this is the one they have been selling everyone that is doing the swap. Is this correct? I have a 2012 GT Track Pack car. Thank you again for your help!! I really appreciate it because I have literally been losing my mind trying to get this issue resolved!!!
Old Sep 29, 2014 | 09:07 PM
  #2159
dmhines's Avatar
I do know that I had problems flashing my PCM until I indicated I was a Dealer.
You maybe able to go into settings and change yourself to a dealer .. I don't recall.
Old Sep 29, 2014 | 09:17 PM
  #2160
mmmojo's Avatar
Okay, I'll try and see what happens. Right now, the cluster works but track apps is not an option even though I have the abs module and have pmi'd the module so there must be something screwy with it. I'll give it a shot since nothing else is working! Thanks again.
