Eduardo's 94 Mustang GT thread
Old Nov 29, 2009 | 01:14 PM
  #181
future9er24's Avatar
Originally Posted by edumspeed
There are some aftermarket headers that fit them quite well and leave enough access to the plugs, like BBK shorties for example. I've done some googling and looked for info on other forums as well. They're the best flowing factory heads, according to what I've read so far. They can be found on 97-01 Explorers if I remember correctly. And the classified for the $500 460 is still there But that will need some extra parts, and I don't think it will bolt on to my transmission bellhousing But a 385 series engine on a sn95 should be a ton of fun
and im pretty sure they make motor mounts for that swap... at least they did for foxes, i dont imagine it being too different for sn95s
460
Old Nov 29, 2009 | 05:31 PM
  #182
edumspeed's Avatar
Legacy TMS Member Pr
Originally Posted by cntchds
Would getting something like this be easier? Then you wouldn't have to drill out the injector bungs.
That's a neat fuel rail kit. Too bad the manifold isn't included
460
They're the same parts The advantages of having a fox body variant
Old Dec 6, 2009 | 12:20 PM
  #183
edumspeed's Avatar
Took apart the upper end of the engine to have a look on the valvetrain to determine if the damage was there. Here are some pics.
As you can see, everything's fine. Diagnosis, bent connecting rods, two at least from the sound
btw, pix from my inherited digi cam
Old Dec 6, 2009 | 01:19 PM
  #184
Blue Notch's Avatar
That sucks Eduardo.
Old Dec 6, 2009 | 01:34 PM
  #185
edumspeed's Avatar
When I took off the upper plenum, there was water still inside it. I re assembled everything back to be able to move it. I'll need to move/throw away some stuff in the back of the house to be able to get that ****. out for the rebuild/replace.
Old Dec 6, 2009 | 02:36 PM
  #186
mustangGT90210's Avatar
I will buy Jack Stands!!!
Someone needs some CAMS!!
For the rebuild. Gotta make it better than it was, ya know?
Old Dec 6, 2009 | 06:15 PM
  #187
technically he needs A CAM
Old Dec 6, 2009 | 06:48 PM
  #188
I'm just jealous
Old Dec 6, 2009 | 06:57 PM
  #189
Originally Posted by mustangGT90210
I'm just jealous
Old Dec 6, 2009 | 07:01 PM
  #190
At least no C/T will come from this mishap. It'd be pretty crappy compared to my current one
Old Dec 6, 2009 | 07:03 PM
  #191
Panty Gnome FTMFW!
That is in the Top 10 Hall of Fame C/T's!!!
Old Dec 6, 2009 | 07:04 PM
  #192
Blue Notch's Avatar
What's the whole top ten then? (post in MCTC)
Old Jan 2, 2010 | 09:34 PM
  #193
edumspeed's Avatar
Still looking @ the parts I may need on various websites. Plans are to put a #19 cam, roller rockers, new lifters, oil pump & shaft, pistons & rods, and if money permits... I plan to liven things up a bit for this thing
Old Jan 2, 2010 | 09:36 PM
  #194
Blown 331 stroker?
Old Jan 2, 2010 | 09:38 PM
  #195
edumspeed's Avatar
Blown 331 stroker?
Nope. It's cheaper to swap a 351, and get more power out of it.
Old Jan 2, 2010 | 09:40 PM
  #196
Blue Notch's Avatar
351.
Old Jan 2, 2010 | 09:53 PM
  #197
edumspeed's Avatar
351.
It would be awesome, but still no 351 swap either
Old Jan 2, 2010 | 09:55 PM
  #198
BoogieNights's Avatar
BoogieNights Studios:
Official Fluffer
Its funny you mention that cuz that is what was in the Stang that I am getting before the guy pulled it out.
Old Jan 2, 2010 | 09:56 PM
  #199
edumspeed's Avatar
But you're putting a 460 instead
Old Jan 2, 2010 | 09:58 PM
  #200
Official Fluffer
Yes I am putting a 460 in instead cuz to me a 351 is too small for what I wanted to do. I believe that the guy still has that 351 still too. It aint "stock" either if you get my drift.
