Installing a Factory NAV on a 2005 'Stang
Old May 9, 2008 | 10:12 AM
  #321
suspence's Avatar
Originally Posted by data174
mrkabc
I have the shaker 500 and when I installed the nav unit after programing, everything worked, except for the speed error and configuration failure. The subwoofer has improved with the nav radio. I am still waitng for the new cluster to arrive, wheel sensors have been installed. I still get the error messages on the dtc.
Wht05vert installed both, and is still getting the error message.
I guess that when ford said the shaker 1000 was not compatible they were correct.
Cheers
Hey data174,
Im new to the forums but I had a question for ya. I have a 2006 gt and it has the shaker 500. If I were to get the navi, would it be a direct replacement or is there more that I would need to buy? thanks a lot!
Old May 9, 2008 | 12:24 PM
  #322
data174's Avatar
suspence
Welcome to th the forum. The ford navigation radio is pnp. But their are some problems related to the nav unit. If you get a chance got through all the threads this prior to this and then you can make a final determination which way you want to go.
Cheers
Old May 11, 2008 | 02:20 AM
  #323
Busted's Avatar
well ive read the first 100 posts and think you guys are doing great.
However, I am personally not interested in the GPS but I am interested in what you guys did with your units once you took them out. More specificly the shaker 500 with the text and seek on the same button. If you are willing to sell your 500 and a resonable price, PM me.
If your not sure what im talking about, lemme know, and Ill try to find pics.
Old May 13, 2008 | 12:47 PM
  #324
themac5150's Avatar
All I can say is... WOW. I was so pumped at getting the OEM nav for my 07 V6 manual, but after reading all of this, I'm having second thoughts. I had no clue there were issues at all with it. Anyone have good news about it?
Old May 13, 2008 | 05:14 PM
  #325
bee bop's Avatar
Themac since you have an 07 you are in a lot better shape than most of us in this thread. Most of us have 05 and 06 models which the nav unit was never intended for. If your car was built after Jan 07 you will more than likely have no issues what so ever, the install will be plug and play. If you have a early 07 you may need a new guage cluster, but that is just to get rid of the speed error. Which is more if an annoyance than an issue unles, you go in a tunnel or something blocks the GPS signal. I originally purchased one from Kevin, but sent it back after his programmer disappeared. Not Kevins fault. Then I got one off of E-bay and it has worked fine other than the the speed error which is just an extra ok when starting the nav portion of the radio.
Old May 14, 2008 | 05:58 AM
  #326
jcthorne's Avatar
Unfortunatly replacing the gauge cluster on an 07 does not fix the speed error either. Some of the 07s that came with the Nav unit as OEM have the same issue.
Old May 14, 2008 | 05:16 PM
  #327
data174's Avatar
Hi All
I received the new cluster today and installed it. It still will have to be programmed at the dealer. I still have the nav error B2477 and U2473 and also have the tire monitor system light on. My 06 did not come with tms.
Will keep you posted.
Old May 14, 2008 | 08:07 PM
  #328
jim010's Avatar
Is this Tire Pressure Monitor a warning light, or does it give an actual pressure reading?
Just curious, as I have a pressure monitor in my Jeep, and it gives a reading of each tire - even the spare.
Cheers
Old May 15, 2008 | 07:20 AM
  #329
07S197's Avatar
Swamp Donkey Man Cans
Disapointment
Well I have to say that I have been following this thread for quite a while. There have been some ups and downs and now that this all seems to be done there is no chance of the factory system working in my 07 shaker 1000 car. Quite a disappointment. Looks like I will be looking for an aftermarket dash unit, if I can find one to work with the 1000 system. If only I had known that the 1000 system was this unique and difficult to deal with I would have opted for the 500 and spent the saved money on a high quality installed system.
Any suggestions on an aftermarket nav unit to drive the Shaker 1000 subs?
Old May 15, 2008 | 07:25 AM
  #330
data174's Avatar
The tire monitoring system was government mandated on all 2007 and up. My 2006 GT did not have TMS. I hope that they can shut off the warning signal and light. On the 2007 and up it will be illegal for the dealers to shut off the TMS system. Maybe when they scan the as is data from my vehicle it will sense that my vehicle does not have TMS. This new system creates a problem when installing after market wheels. It requires that you move the TMS sensors from the old wheels to the new wheels, that becomes costly.
Cheers:
Old May 15, 2008 | 07:38 AM
  #331
jim010's Avatar
Yes, but my question was, is the TMS an idiot light or does it give actual pressure for each tire? It sounds like it is just a light?
Cheers
Old May 15, 2008 | 07:45 AM
  #332
data174's Avatar
It is just the idiot light. All the system are not in place to work correctly.
Al
Old May 16, 2008 | 11:42 AM
  #333
data174's Avatar
Hi All
Well I picked up my GT today. The tpms light is off and its back to square one. Replacing the wheel speed sensors,and a late model cluster has not resolved the B2477 config. failure and the speed control U2473 error. I will keep in contact with Will at H&H and see if he has had any luck solving this problem. I have tried contacting Kevin, but have not been successful.
Cheers
Old May 16, 2008 | 03:50 PM
  #334
data174's Avatar
Hi All
I am looking for any member that has a 2007 or 2008 Mustang with a nav.system that is working correctly, to post pictures or text of the configuration system,when you run the diagnostics on the nav radio. The configuration of those units might anwer some of the problems configuring the new nav units.
Thanks Al
Old May 16, 2008 | 05:47 PM
  #335
USMC0341's Avatar
Hi All
Thanks Al
I installed a nav in my car with no problems, how do I bring up this screen?
Old May 16, 2008 | 06:47 PM
  #336
denlem's Avatar
I've been watching since day one, shaking my head.
Here are the config screens on a 2008 GT/CS Coupe Job 2 Nav.
Attached Thumbnails Installing a Factory NAV on a 2005 'Stang-dsc02411_resize.jpg   Installing a Factory NAV on a 2005 'Stang-dsc02412_resize.jpg   Installing a Factory NAV on a 2005 'Stang-dsc02413_resize.jpg   Installing a Factory NAV on a 2005 'Stang-dsc02414_resize.jpg   Installing a Factory NAV on a 2005 'Stang-dsc02415_resize.jpg
Installing a Factory NAV on a 2005 'Stang-dsc02416_resize.jpg   Installing a Factory NAV on a 2005 'Stang-dsc02417_resize.jpg
Old May 16, 2008 | 07:02 PM
  #337
data174's Avatar
Navigation Radio Diagnostics
USMC0341
Turn your radio on and select FM1. Then by pressing #3and#6 and holding them down for approximately 3 seconds the system will switch into speaker test mode. Push the exit button on the bottom, and it will switch to diagnostic mode. The first mode will do a complete scan of unit for any errors. The second will give you a list of any errors. And the third is the configuration settings on your radio. You will have to scroll down to see all the pages. I saw a thread some place by ford on how to do the daignostics on the nav radio. Give it a try you will find interesting.
Cheers Al
Old May 16, 2008 | 07:08 PM
  #338
data174's Avatar
Hi Dennis
Thanks for the information I will make a copy and compare it with my system.
Cheers Al
Old May 16, 2008 | 07:13 PM
  #339
denlem's Avatar
I hope it helps!
Old May 16, 2008 | 07:30 PM
  #340
USMC0341's Avatar
USMC0341
Cheers Al
Thanks Al, tried it and took some pics. just a little background, my car was built in 01/07 and came with the shaker 500. bought/programed the nav unit on ebay. was plug and play with no errors or problems. I hope this info is useful
Attached Thumbnails Installing a Factory NAV on a 2005 'Stang-img_0233.jpg   Installing a Factory NAV on a 2005 'Stang-img_0234.jpg   Installing a Factory NAV on a 2005 'Stang-img_0235.jpg   Installing a Factory NAV on a 2005 'Stang-img_0236.jpg   Installing a Factory NAV on a 2005 'Stang-img_0237.jpg
Installing a Factory NAV on a 2005 'Stang-img_0238.jpg   Installing a Factory NAV on a 2005 'Stang-img_0239.jpg   Installing a Factory NAV on a 2005 'Stang-img_0240.jpg
