Retrofitting the 4.2 LCD Track Apps cluster
Old Mar 4, 2015 | 10:14 AM
  #101
jim010's Avatar
What are you looking to add to the clock spring? Is this to make the steering wheel from the 14 fit in 05? Are there enough slots in the connectors for that?
Old Mar 4, 2015 | 08:10 PM
  #102
zeroaviation's Avatar
We plan on replacing the entire column. But going to need to change some wiring first, and I want to do it right of course.
Still on the hunt >_<
-Matt
Old Mar 4, 2015 | 10:12 PM
  #103
jim010's Avatar
-Matt
The whole column? The entire assembly that houses the clockspring, steering shaft etc? Is this for the 05/09 project or something else? And why the entire column?
Old Mar 5, 2015 | 08:57 AM
  #104
Well, there are two projects on going right now.
1. Swapping in the 13 Gauge cluster in my shelby.
2. Swapping in the 11(and soon to be 13) gauge cluster in a local 05. We are going to try swapping out the entire column to gain the more wires and 11 steering wheel. Still to figure out the rest of it though.
I was wanting the pin part numbers for both.
-Matt
Old Mar 5, 2015 | 12:56 PM
  #105
jim010's Avatar
You may want to check this thread out, then. akdoggie retrofitted the 2010 and up steering wheel and made the buttons functional. His way may be better than switching out the whole column.
https://themustangsource.com/forums/...o-mods-528705/
Old Mar 5, 2015 | 12:58 PM
  #106
jim010's Avatar
Can I quote this for the thread in the 05-09 section to give updates?
Cheers
Old Mar 5, 2015 | 01:59 PM
  #107
Will look into it! We already have the spare column loose.
Cheers
Sure thing. If all goes well, and its really greater than 12C temperature wise this weekend, should have another update by Monday.
Cheers,
-Matt
Old Mar 9, 2015 | 08:08 PM
  #108
jim010's Avatar
Matt,
Any luck?
Old Mar 15, 2015 | 12:58 PM
  #109
Kona12GT's Avatar
Just in case someone reading this thread is wanting to do the swap on an auto 11-12, I have a complete 13 auto shifter assembly for sale. Was only on my car for a few months and was purchased new originally. Pm me for price if interested.
Old Apr 7, 2015 | 11:49 AM
  #110
Coyote5-0's Avatar
how does the left side button panel on the steering wheel come off?
Old Apr 7, 2015 | 12:34 PM
  #111
Just pry's out. Remove the airbag, unplug, then push towards center while pulling up on in part.
-Matt
Old Apr 7, 2015 | 01:14 PM
  #112
Coyote5-0's Avatar
-Matt
dang...a lot more in depth that I thought it would be.
Old Apr 15, 2015 | 12:03 AM
  #113
jim010's Avatar
I found this video on youtube from someone converting a base 13/14 to the track apps. Includes the IDS programming of keys and inputting as built.
https://www.youtube.com/watch?v=in68335Qe2c#t=20
Old Apr 15, 2015 | 06:55 AM
  #114
Coyote5-0's Avatar
Is it hard to find a dealer that is willing to program the As Built Data? Would they even know what you're talking about?
Old Apr 15, 2015 | 09:03 AM
  #115
Any dealer can do it. If the tech is not understand what needs to be done, let me know and I can explain it to him.
-Matt
Old Apr 15, 2015 | 10:03 PM
  #116
crazietj's Avatar
Does anyone have a part number for the pins used in the connectors for the clockspring or the switch?
I know blueeyedsnake (sal) found them, but hes banned from most forums now. So I cant ask him :/
-Matt
It's been a while since I've been on. If you haven't found the pins yet, here ya go. If you have well here is a reference to them.
Part number for the male pins (www.digi-key.com):
A104905-ND
http://www.digikey.com/scripts/DkSea...9&y=11&cur=USD
Part number for the female pins (www.digi-key.com):
A101884CT-ND
http://www.digikey.com/product-detai...4CT-ND/2700941
Old Apr 16, 2015 | 08:21 AM
  #117
A104905-ND
A101884CT-ND
Good find! How did you find them?
-Matt
Old Apr 16, 2015 | 02:57 PM
  #118
crazietj's Avatar
I used them for my sync retrofit. Someone posted them on another site.
Old Apr 22, 2015 | 12:30 PM
  #119
devildog1679's Avatar
If I run aftermarket tune will I have to give my tuner the new VIN used when trying to get the gauges to work?
Old Apr 30, 2015 | 08:45 AM
  #120
jim010's Avatar
http://www.ebay.com/itm/13-14-Ford-Mustang-GT-5-0L-OEM-Speedometer-Cluster-MPH-19K-CRACKED-LENS-/391129141504?&_trksid=p2056016.l4276
Still clusters out there. I just picked another one up for $175.
