Retrofitting the 4.2 LCD Track Apps cluster
Old Nov 5, 2014 | 11:30 AM
  #81
dmhines's Avatar
Track Apps will appear in your cluster .. but it will not work without the new ABS module. Pretty sure that was thoroughly discussed in this thread. It was also mentioned early in this thread that the 2012 select buttons can control the menu.
Old Nov 9, 2014 | 10:33 AM
  #82
Onefastmf's Avatar
Just so I'm 100%, I have a base 14 and putting in a Premium cluster does not require module programming? No as build has to be done also?
Old Nov 9, 2014 | 10:58 AM
  #83
Onefastmf's Avatar
I cannot gets pats to work, I did the earase of the keys and then when I get to the programming keys, it says tune key off, turn new key to on for 6 and then do same for next key, when I do that it says two keys have been programmed but also says to many keys cycles and security access lost and says to go though process again. Not sure what I'm doing wrong, please help.
Old Nov 9, 2014 | 11:23 AM
  #84
LEXiiON's Avatar
Once you programmed the two keys, exit the PATS menu and re-enter it. Then do the parameter reset option, and you successfully done the PATS.
LEXiiON
Old Nov 9, 2014 | 07:12 PM
  #85
Onefastmf's Avatar
All good thanks
Old Jan 3, 2015 | 01:13 PM
  #86
manlaw38's Avatar
will this work on a 2011 3.7 v6 with preim poney package?
Old Feb 14, 2015 | 11:30 PM
  #87
ajpturbo's Avatar
Anyone notice the link for as built data isn't working?
Old Feb 15, 2015 | 06:08 AM
  #88
dmhines's Avatar
Yes. Ford shutdown the build data site. Need ID and password now. Parties over.
Old Feb 15, 2015 | 06:57 AM
  #89
zeroaviation's Avatar
EDIT: If anybody needs ASBUILT PM me the VIN you need the ASBUILT for. I will only get it for established members of this site.
-Matt
Old Feb 18, 2015 | 06:03 PM
  #90
jim010's Avatar
I always knew Ford would close the door on us doing these sorts of mods. I think they closed it on us with the new VCM version as well.
Old Feb 18, 2015 | 06:43 PM
  #91
It won't take time for someone to make a work around.... Give the chinese a little time lol
-Matt
Old Feb 18, 2015 | 10:05 PM
  #92
ajpturbo's Avatar
What do you mean?
Old Mar 2, 2015 | 09:40 AM
  #93
Does anyone have a part number for the pins used in the connectors for the clockspring or the switch?
I know blueeyedsnake (sal) found them, but hes banned from most forums now. So I cant ask him :/
-Matt
Old Mar 2, 2015 | 10:21 AM
  #94
LEXiiON's Avatar
I have his cell # if you need it.
I just been to the as built site and got a as built version of a car. So it still works for me without login.
LEXiiON
  #95
dmhines's Avatar
Never saw a part # .. I know Jim010 was sourcing them from old wiring harnesses.
Old Mar 2, 2015 | 10:30 AM
  #96
LEXiiON's Avatar
Another update: You have to go manually into the link. Start the at motorcraftservice.com, then Quick Guides, then as built. Works fine.
LEXiiON
Old Mar 2, 2015 | 11:41 AM
  #97
dmhines's Avatar
Thanks! I had been using the old direct link .. but going in through motorcraftservice does still work ...
Old Mar 2, 2015 | 02:57 PM
  #98
LEXiiON
I texted him, I doubt I get a reply sadly :/ If anybody has this info, would be greatly appreciated.
This is good news!
-Matt
Old Mar 3, 2015 | 02:09 PM
  #99
jim010's Avatar
You need males and females, I assume? I can certainly get you some from my old harnesses as Dan said - but as for ordering them, that would take some research.
Old Mar 4, 2015 | 09:14 AM
  #100
I have some from my old harness as well (once i find my old harness lol).
I was hoping to get them so I can order them... Will report back what I find once I get my car out of storage this weekend.
-Matt
