'13-14 Cluster into '10-12 car (with TrackApps) retrofit
#1861
Yes, 2014 base GT. I have seen the dtc, it also throughs a couple of other codes. Don't want to mess with it too much since it the cobra cluster instead of the pony, but was wondering if swapping the as-built will also change the boost gauge to the head temp?
I always use the seatbelt so don't mind the missing chime. But the park sensors setting is tempting.
#1862
Do you have a VCM to change the AS-BUILT? I tried GT500 AS-BUILT in my GT 0cluster just to for the heck of it ... I don't think it changed my CHT to BOOST. It also did not give me RED/WHITE/BLUE MyCOLOR option.
#1863
Did you get the snake on start up at least? Did Launch control appear?
#1868
No, if you buy the 2013 ABS module you will have track apps without the need of flashing. Flashing just allows you the ability of not needing a modified cruise control switch or black box, but you will need to get a tune to make sure your car is running right (Not to lean or rich... etc).
For me, I wanted every ounce of use out of the 2014 GT500 cluster and features, so I flashed my PCM to a 2014. My engine is modified anyways and I will be installing some aggressive camshafts this week and was going to get a custom tune anyways. I talked to my tuner and told him what I was doing and he had no problem helping me out getting everything worked out so my car would run perfect.
On a side note LEXiiON, After installing a base tune from Lund the tach does go to 7,000 RPM redline after reaching operating temperature. Even Launch Control works as it's supposed to. Now I need to figure out how to make the Cobra appear in the gauge cluster instead of the mustang. All the 2014 GT500 have the Cobra in their cluster. I have 2014 as built and I PMI'd the IPC with 2014 VIN and no go, mustang is still there. Any idea's for the anyone? I'm not sure if I need to flash anything else.
I'd like to upgrade my '11 base as well and just want to make sure I get this straight.....
To get full functionality (with track apps), I'll need the cluster, modified cruise, black box and abs module.........correct?
My car already has a custom tune on it (tvs), so if I do the install with the black box I will NOT have to get retuned???
Thanks in advance. Great thread!!!!
#1869
No it worked just fine. I sold the car a few weeks ago. I even went as far as hooking up the steering wheel switch correctly and everything. I took it out before I sold the car along with my 13 taillights(which are already sold) and some other parts
#1870
Alex, did you input your own car's VIN and programming into the cluster? I know Track Apps would disappear, but did the guages? And also, did the steering wheel feel also disappear?
Cheers
Cheers
#1872
So you have the switch and the cluster? Price?
#1874
LEXiiON
#1876
I never put my VIN into the cluster.
But yes, with my as build, no steering feel, no Track Apps, no Gauges.
LEXiiON
#1877
#1879
I've only played with it a few times, but LC is pretty cool and I'm glad it works even though I probably won't use it often. I'm going to change the as built around tomorrow, cause I want the cobra. I loaded DR3A-12A650-AJD into the the PCM, which I thought was 2014 GT500 PCM. I then PMI the IPC with a 2014 VIN which was the same one I used for the ABS module. I even changed the as built in the IPC, but no Snake. I want a Snake.... Lol I am happy that everything works perfectly, but I don't like the Pony, no offense to anyone that likes it.
