'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Unfortunately, I am still getting silly excuses. He will be coming up here in May for a wedding, but the chances of him bringing it then are low as well.
Getting frustrated with him. He doesn't want to go to the post office because he'll be in line for 2 hours ...
... sure ...
... sure ...
... sure ...
... sure ...I'll ask another member here who lives in that area...
FYI .. Looks like I have located a 2013 GT cluster as well and should have it soon ...
Looks like I need to order the steering wheel switch now. Gonna make sure the cluster and track apps kind sorta do something before I buy the switch though.
Thanks for the compliments.
I have rigged it so UPS will pick up my cluster. I should have it next week. Switch ordered as well.
10MustangGT - let me know when you get yours so I can tell you how to wire up the switch. Your Switches on the headlight switch module will become non-functional, likely.
FYI .. I already have a tune in my car. Talked to the tuner .. they have never disabled PATS on a 2012 car .. but the option is available in the SCT software to do it. So .. once I get the cluster I will install a Tune with PATS disabled to see if car starts and Track Apps work ...
I think I said earlier. When I put a 2012 GT500 Cluster in my 2010 GT I told them to reset the PATS at the dealer. But he ended up Loading my 2010 Build data into the 2012 Cluster. This basically turned it into a 2010 Cluster. I do not know if the was a prerequistive to reprogramming the PATS or if he just did it or the heck of it.
Maybe just turning off PATS in the tune will suffice .. However ... my understanding is with PATS off in the PCM via a tune .. it will illuminate the warning light on the cluster.
I'll order the tune tomorrow .. and should have the Cluster on Friday.
If it all actually works and you want to make it look factory .. you could also order a 2013 Headlight switch without the setup buttons.
Been reading all the PATS documentation I can find online .. seems like it should be fairly simple for the tech to reset PATS without reloading the build data into the 2013 cluster.
They would need to:
1) Perform the PATS RELEARN procedure - this syncs the Cluster with the PCM
2) Peform the KEY RELEARN procedure - this syncs your keys to the Cluster.
I don't see any need to do anything besides those two steps.
They would need to:
I hope this works guys
