Trackey for manual 2014 GT's manufactured after 7/1/2013
Old 10/18/14, 12:24 PM
  #761
MyStang2010GB's Avatar
Originally Posted by SMOKE46
I downloaded all instructions for both Trackey installations , it's say's the Lopey Idle sounds better with Quad Exhaust so, Will it Void warranty if I put Quads on my 2014 1 /2 GT Does anyone know ?
It will not void your warranty to add Boss302 side exhaust. I have it on my car as well
Old 10/18/14, 06:51 PM
  #762
SMOKE46's Avatar
Talking
Thanx for info!
Old 10/20/14, 07:18 AM
  #763
joejakegrace's Avatar
So I put about 75 miles on it this weekend.
A few more observations.
1 - Lopey idle is about perfect, don't get me wrong. It's just that, from the posts/reviews of others, I expected more up/down rpm and more shake - it's not that big a deal - and you have to point it out to non car folks! - It's fine though - don't get me wrong.
2 - Idle sometimes takes more than 130 seconds to kick in - I've had it take a full 20 seconds more. ALSO, the docs say that temp has to be 170 or over for idle to transition. For me, it's closer to 180.
3 - I was totally freaked out when, in lopey idle, my RPM/Rev limiter was acting ALL GOOFEY. I was in my garage and later, at a light, trying to engage lopey idle when my car was sputtering / rev limiting as I tried to run up the RPMs. Just had to think about it some. Turns out, lopey idle had JUST engaged (I hadn't yet realized it) AND my new launch control had been set at 2,000 rpm. I changed that to 5,000 for now (I'm not racing it) and issue solved.
4 - Again, car runs up through the RPMs / shifts MUCH more seamlessly with the Track Cal AND the MGW. The best analogy I can give is it is like the difference between a new, tight car and a sloppy 100k stick shift.
Oh.....and the MGW is pure gold.
Old 11/17/14, 04:59 PM
  #764
OneBadGtCs's Avatar
Can anyone with tire size 245/45/19 tell me what RPM = Revolutions per mile they have there car set up with? That is if you have a procal tool. Online tools say it should be 729 but Ford Racing had told me it was 753 which seems a bit high to me. Thank you in advance.
Old 11/18/14, 08:47 AM
  #765
2012GT's Avatar
Set the speedometer in your car with your GPS reading.
Old 11/18/14, 08:59 AM
  #766
My lopey idle in my car literally shakes the car. much more pronounced than it was in my 2012 Boss
Old 12/11/14, 01:27 PM
  #767
Critical Mass's Avatar
Just FYI, That's Revolutions Per Minute, not Mile.
Old 12/11/14, 03:11 PM
  #768
todcp's Avatar
Ford racing is correct. Just go to Tirerack and look up your size. This size should be 748 to 754 or so.
Old 12/12/14, 04:30 AM
  #769
bwkelley76's Avatar
Better video than the last.
~SOUND IS VERY QUIET, TURN UP YOUR VOLUME AND THE VOLUME ON THE VIDEO ITSELF. Sounds best if you have an updated sound system on your computer.
CLICK ON LINK/IMAGE BELOW AND ENJOY!
http://vid69.photobucket.com/albums/...psb593a33a.mp4
I held the gears longer so you can hear the difference in the engine braking on decel with the Track Cal Tune. You can also hear a hint of the lopey idle before I take off.
Old 12/12/14, 07:41 PM
  #770
golffanatic777's Avatar
Try the video again?
When I clicked on the picture, I just got a thumbnail version of the pic and no video. Would love to hear because I'm considering purchasing!
Old 12/13/14, 09:16 AM
  #771
pminri's Avatar
I would love to share mine at idle but can't figure out how to attach video either. I don't think the iPhone app lets you. I can email mine to whom ever wants to hear it. I have the Corsa extreme axel backs on mine and love it.
Old 12/13/14, 11:35 PM
  #772
bwkelley76's Avatar
Here you go..
I also added a link to the post for those of you that couldn't get it to work.
Old 1/14/15, 12:29 AM
  #773
shaneyusa's Avatar
Received 1,144 Likes on 820 Posts
So is the track key tune only for 93 octane or can it also be set to adjust? Does the K&N filter come with the key or is that just a package that some are putting together? Everyone still think this is the way to go?
Old 1/14/15, 01:26 AM
  #774
Springer200's Avatar
I believe the TracKey requires 91 & up octane. (It comes with a sticker for the inside of the gas door that reads "91+".)
Also, the "kit" (normal Trackey purchase) includes the K&N Filter.
Old 1/14/15, 07:49 AM
  #775
berzerk_1980's Avatar
If you go to the Ford Racing site and download the instructions, it's tuned for 93. The dealer has an option to re-tune to 91.
I have heard that others have called Ford Racing and were told to run the 93 tune. If they got detonation, the next step is to install an oil separator. If that doesn't work then have the dealer run the modified tune.
Old 1/14/15, 08:15 AM
  #776
gjcavana's Avatar
The instructions say to run 91+ but I always run 93. The filter came with the kit and was installed by the dealer.
BTW, it's very cool!!
Old 1/14/15, 11:23 PM
  #777
shaneyusa's Avatar
I have installed a Moroso Oil Separator in preparation for the Track Key. I have been running 91 octane non-ethanol fuel in it. I have not found anywhere in my area that sells 93 octane fuel (ethanol or non-ethanol). I would probably have to find some Jet fuel to get there or add some octane booster. Really would like to get the key, but have it set for 91 octane fuel. I have heard some of the ProCal tunes are being set to auto adjust, is that an option with the key?
Old 1/15/15, 07:49 AM
  #778
I think the TracKey tune and ProCal tube are the same except that you have the second key and need the dealer for the TracKey.
On adding Octane booster, does anyone know how to figure the ratio? I also want to turn 91 to 93, but I don't know what the octane of the booster would be. I also don't want to make a higher octane than can be tuned automagically by the engine.
Old 1/15/15, 10:30 AM
  #779
There are no settings to change. (at least with the TracKey.)
I wouldn't worry - the car has knock sensors & can adjust the timing on its own. It can definitely adjust to compensate for two points of octane.
FYI - you may have been kidding, but don't put "jet fuel" or Av-gas, or any fuel not specifically formulated for automotive use in your car (or any car). There may be additives or significant differences in the fuel characteristics that could damage the engine or rubber/plastic components or the catalytic converters.
Old 1/15/15, 12:55 PM
  #780
In the dealer instructions I've downloaded from FRPP, it describes an octane adjust procedure. I'm on mobile but I have attempted to attach a screenshot.
Trackey for manual 2014 GT's manufactured after 7/1/2013-picsart_1421351216112.jpg
Edit: Download link for the pdf so you can see it yourself (page 12):
http://fordracingparts.com/download/...tomer_V1.0.pdf
Further to my other question: Suppose there is a gas station that sells 91 octane and 100 octane. I want 93 octane. Do I use an equation like 91x + 100y = 93? This yields a 1:50 ratio. Or is octane more complicated than that?
Quick Reply: Trackey for manual 2014 GT's manufactured after 7/1/2013
