Cpotts's 2kgt Build Thread
Old Sep 22, 2012 | 11:42 AM
  #321
cntchds's Avatar
That is crazy. I'd call MM.
Old Sep 22, 2012 | 06:46 PM
  #322
cpotts13's Avatar
Im going to call them up monday.... but i have had them on my car for 4 months so idk....
Old Sep 23, 2012 | 04:14 PM
  #323
cntchds's Avatar
What struts and springs are you using?
Old Sep 23, 2012 | 05:23 PM
  #324
cpotts13's Avatar
Tokcio blues
Old Sep 25, 2012 | 12:38 AM
  #325
cntchds's Avatar
and springs? If you are running at a near stock height and you are using the lowered setup for your spacers you could be making trouble there.
Old Sep 25, 2012 | 05:03 AM
  #326
cpotts13's Avatar
Frpp c springs. No isolators in the front. Its lowered pretty good. Ill grab a pic..
Old Sep 25, 2012 | 09:40 AM
  #327
cntchds's Avatar
C springs only lower about an inch and the isos only drop about a 1/4 inch. The lowered setup may not work with so little drop. If I were you I would try throwing one of the long spacers under the bearing and see if you can get it in spec after that. You said that they got the alignment in spec on your passenger side?
Old Sep 25, 2012 | 01:07 PM
  #328
cpotts13's Avatar
Yeah I did with room for more . A buddy of mine is having the same problem with his mm CC plates and h&r super sport springs.
Old Sep 25, 2012 | 01:35 PM
  #329
cntchds's Avatar
That is too weird. Were you in spec when you had the stock plates on?
Old Sep 25, 2012 | 02:11 PM
  #330
cpotts13's Avatar
When I was stock ride height yes.
Old Oct 2, 2012 | 08:44 PM
  #331
cpotts13's Avatar
So my rear brakes have started squeaking..
WUT. I just replaced the pads and rotors a few weeks ago... everything is on properly... and its only the rear..
Any ideas?
Old Oct 2, 2012 | 08:53 PM
  #332
1999Pony's Avatar
Mine squeak all the time. I don't worry about it.
Old Oct 2, 2012 | 08:54 PM
  #333
cpotts13's Avatar
I know it's notbad... just a pet peeve if mine.
Old Oct 2, 2012 | 09:40 PM
  #334
Blue Notch's Avatar
Thought I heard something once about it being colder weather. Really can't remember though.
Old Oct 2, 2012 | 11:53 PM
  #335
cntchds's Avatar
Colder weather can affect brakes making sound a little bit, but as soon as your rotors and pads get up to temp the outside temperature should not make a difference.
Old Oct 3, 2012 | 05:37 AM
  #336
cpotts13's Avatar
Yeah i thought it was that at first. but it insnt cold here. plus its only the rear.. constantly..
Old Oct 3, 2012 | 08:50 PM
  #337
shurtual86's Avatar
Old Oct 3, 2012 | 08:55 PM
  #338
cpotts13's Avatar
Yes.
I took the wheels off and checked things out today. Its all good.
Old Oct 3, 2012 | 08:57 PM
  #339
shurtual86's Avatar
is it still making noise?
Old Oct 3, 2012 | 09:55 PM
  #340
1999Pony's Avatar
Originally Posted by cpotts13
Yes.
I'm in the same boat. Id say in March I replaced the rearend with new brakes and put cobra brakes up front and I hear squeals and whatnot. The pads and all that are good. I think its just the nature of the beast.
