Cpotts's 2kgt Build Thread
Old Jul 22, 2012 | 10:16 PM
  #221
shurtual86's Avatar
Originally Posted by 1999Pony
Black with white.
I agree.
Old Jul 23, 2012 | 07:14 AM
  #222
Dbranham's Avatar
Black with white
Old Jul 23, 2012 | 11:01 AM
  #223
cpotts13's Avatar
Originally Posted by Dbranham
Black with white
Thats what i was thinking, the white would be over kill.
so ahwhile ago a bought some leds to do my cluster, come to find out they were the wrong size. So last night i figured they would work with my license plate lights!
Old Jul 23, 2012 | 11:04 AM
  #224
shurtual86's Avatar
What size were they? I think the license plate bulb is the same size as the HVAC bulbs.
Old Jul 23, 2012 | 12:10 PM
  #225
cpotts13's Avatar
They are, but i bought 6 thinking they were for the cluster, so i used two on the license plate bulbs. It only takes 3 to do the hvac right?
Old Jul 23, 2012 | 01:40 PM
  #226
shurtual86's Avatar
Yup they are kinda hard to get at, at first, but once you get one, the other are easier
Old Jul 23, 2012 | 02:07 PM
  #227
cpotts13's Avatar
Alright, so I have a few ideas for some upgrades, I will only be able do one at a time and will require some saving.
Here's my ideas:
Brakes: slotted and drilled front and back rotors, ebc/ hawk pads, ss brake lines, dot 4 fluid.
Reason: if you have a sn95 you know the stock brakes suck...
Lower: chin spoiler, lowering spring, caster bolts, spring isolators.
Reason: to get rid of the dang 4x4 look!
Lights: 3rd brake light, rear taillights, and chin spoiler.
Reason: faded 3rd and leaking rears..
Opinions and thoughts welcome! I've been bouncing between these 3!
I figure since this whole thread started off as a list of things I wanted to do, and completing that list and then some (cobra brakes, lcas, gears + all quoted) that I would make a new list detailing whats next for my car.
STEP 1: shift boot, leds, new (used) drive shaft, and INSTALL THOSE PITA MOTOR MOUNTS. <$200
STEP 2: CAI, finally get a dang tuner, throttle body and plenum. <$600
STEP 3: sway bars and full length sub frame connectors. <$500
I figure this is a fairly accomplish-able list, I go back to school late august, im still in high school so school will leach all my availability at work. ]
Open to suggestions.
Old Jul 24, 2012 | 07:03 AM
  #228
mdelao's Avatar
What about gears?
Old Jul 24, 2012 | 09:22 AM
  #229
cpotts13's Avatar
Originally Posted by mdelao
What about gears?
I Have 3.73 already :3
Old Jul 24, 2012 | 01:58 PM
  #230
mdelao's Avatar
Great, definitely go with tuner and TB!
Old Jul 24, 2012 | 02:33 PM
  #231
cpotts13's Avatar
Drivehaft first!!
Old Jul 24, 2012 | 10:00 PM
  #232
cpotts13's Avatar
Well had a little brake miss hap today. I was driving and noticed that parking brake light would turn on while heavy braking, long story short i researched it, came to be a leaking passenger line (threaded wrong) which caused me to lose alot of brake fluid. So i went back, correctly threaded the line, added more fluid and bleed the caliper till the bubbles where gone. You live and you learn.
Old Jul 25, 2012 | 05:39 AM
  #233
shurtual86's Avatar
Good thing you noticed it before you ran out of brake fluid
Old Jul 25, 2012 | 09:25 AM
  #234
cpotts13's Avatar
WOOOOOT. Just ordered a used Driveshaft off ebay, he accepted my offer for $50. Yayyyyy
Old Jul 25, 2012 | 08:25 PM
  #235
shurtual86's Avatar
Old Jul 30, 2012 | 08:12 PM
  #236
cpotts13's Avatar
Put on my new driveshaft today! litterally took 5 minutes. Jacked the car up, undid 4 12 point 12mm bolts, slide the old off, slide the new on, lock tight the bolts and tighten them down like youre life depends on it!
No reall pictures.. cause its just a boring stock ds, but this one wasa in good condition with zero rust. also solved the problem with the slack.
Old Jul 30, 2012 | 08:40 PM
  #237
1999Pony's Avatar
Old Jul 30, 2012 | 09:26 PM
  #238
conv_stang's Avatar
Nice man...car is coming along nicely.
Old Jul 31, 2012 | 01:29 AM
  #239
cntchds's Avatar
I really would try to stick to the torque specs especially on stuff like your drive shaft. I know it seems like something that you should just "tighten like your life depends on it," but really with lock tite they are not just going to wiggle free if it's tightened to spec. I'm glad to see your car coming together so well.
Old Jul 31, 2012 | 03:49 AM
  #240
cpotts13's Avatar
Thanks man!
I tq'ed it to 76 ft/lbs, which was recommended. It was just at an akward angle with the tq wrench under the car, is what I was going for.
