Cpotts's 2kgt Build Thread
Old Nov 5, 2012 | 06:03 PM
  #381
cpotts13's Avatar
So I hate me car. It wasn't the dang water pump. Replaced it with a brand new one. Put everything back together, and bam still squeals like a pig. So i removed the serpentine belt and started the car, no noise. So that rules out anything internal at least.. the noise itself is coming from the passenger side of the engine. So i am thinking its the air condenser. I am going to keep the new water pump on anyways since the old one did make noise and had slack.
So the thing thats most likely going to happen is i am going to bypass it all together.
How exactly does this work?? http://www.latemodelrestoration.com/...tor-Delete-Kit
because i forsure dont have the money to have mine serviced.
It will most likely be awhile till i get my car running again, it will give me some time to reflect on what my real goals are for this turd.
Old Nov 5, 2012 | 06:28 PM
  #382
Dbranham's Avatar
So the ac delete for now until you replace you get around to replacing it? I'd say you just pull the compressor out an it should bolt right up to the existing holes. If you replace the compressor make sure it's an oem, I had a remaifactured one put in about 20k ago and it's crapping out.
Old Nov 5, 2012 | 07:09 PM
  #383
cpotts13's Avatar
The thing is, It will be cold/ good weather till i Leave for basic training. So i may just delete the ac period. Like I said, I need to reevaluate what my final goals for this car will be
But right now i am leaning towards this..
http://www.allfordmustangs.com/forum...-c-delete.html
Old Nov 6, 2012 | 06:01 AM
  #384
1999Pony's Avatar
Your compressor is locked up. The same thing happened on my Moms caddy. The pulley still spun but it spun slower so the belt was slipping on it. Bad part is, you cant just replace the pulley on that.
Old Nov 6, 2012 | 06:10 AM
  #385
cpotts13's Avatar
Yeah. and it isn't a dyi job either.
Old Nov 6, 2012 | 06:31 AM
  #386
Dbranham's Avatar
That's what happening to mine right now. Really annoying noise
Old Nov 6, 2012 | 11:27 AM
  #387
cntchds's Avatar
That's what's happening on mine right now, too. Pain in the butt that you can't just replace the pulley and call it a day.
Old Nov 6, 2012 | 01:44 PM
  #388
cpotts13's Avatar
looks like its a new edge/ sn95 curse haha. its happening to everybody. Least there is a easy band aide.
Old Nov 6, 2012 | 11:34 PM
  #389
cntchds's Avatar
Yeah, but I don't think I would enjoy driving my car nearly as much without A/C. I don't know about you guys, but my car gets warm in the cabin even when it's cold outside. I usually have the A/C on at least a little during the day. Then again, I am in CA... Maybe out in that part of the country where 65 isn't considered "cold" that doesn't happen.
Old Nov 7, 2012 | 09:45 AM
  #390
1999Pony's Avatar
****, 65 and I am running the heat. Lol
Old Nov 8, 2012 | 06:35 PM
  #391
cpotts13's Avatar
So would there be any repercussions from bypassing the AC compressor with a shorter belt ?
Old Nov 8, 2012 | 06:38 PM
  #392
Dbranham's Avatar
You mean as in just leave the annoying compressor there and just run a belt that doesn't go the compressor? I don't see any down sides to it, I'd say go for
I'd be interested if it works great, I'd love to do that.
Old Nov 8, 2012 | 06:52 PM
  #393
1999Pony's Avatar
Other then not having A/C? Shouldn't be.
Old Nov 8, 2012 | 07:54 PM
  #394
Dbranham's Avatar
Did a little searching. Should cost about $30, you need a v6 6 rub pulley and a 70.5 inch belt I believe
Old Nov 8, 2012 | 10:22 PM
  #395
cpotts13's Avatar
Just ordered the parts, I wanted a specific type of belt (good year gatorback) and no one around had it.
Old Nov 9, 2012 | 08:25 PM
  #396
cpotts13's Avatar
Soooo, ran my car for about a minute to poke around some more and my alternator started shooting sparks at my face, no joke. Took it off and the bearings are shot, the whole things loose.
If I replace it, what am I looking for? 130amp 6guage?
Old Nov 9, 2012 | 08:57 PM
  #397
Blue Notch's Avatar
Get the PA Performance one from AM. Replaced mine last winter and I have no complaints. Cheaper than some of the one's I've seen at auto parts stores as well. It's on sale too.
http://www.americanmuscle.com/130amp...or-9904gt.html
Old Nov 10, 2012 | 07:44 AM
  #398
cpotts13's Avatar
Thanks! That's the one I was looking at, just wanted to be sure
Old Nov 16, 2012 | 10:14 PM
  #399
cpotts13's Avatar
Yay, alternator came in today, took 15 minutes to put in. Car runs like a champ
Old Nov 17, 2012 | 02:39 AM
  #400
Dbranham's Avatar
Sweet! Any update on the compressor? I'm really thinking of getting a delete kit.
