Cpotts's 2kgt Build Thread
Old Sep 19, 2012 | 10:43 PM
  #301
1999Pony's Avatar
If I could swing it, it would go in my car this winter. Probably in 2 or 3 years. I will more then likely just be a lightly modded 2V, b/c it will still be my autox car, but the weight savings is awesome.
Its pretty awesome just to look at though. Plus it shipped UPS, wieghs 70 lbs lol. Just pick it up and put it wherever you want.
Old Sep 20, 2012 | 10:56 AM
  #302
mdelao's Avatar
Originally Posted by cpotts13
Pictures from the weekends project:
Old nasty rotors, they were actually rusting in the middle of the rotor...
The new and the old, parts store rotors and pads, nothing special.
Getting my alignment did!
So, alignment was finally fixed? What was the issue with it?
Old Sep 20, 2012 | 02:14 PM
  #303
cpotts13's Avatar
No, the mm caster camber plates won't allow for more adjustment on the drivers side, there maxed out at -1.5. So he just set the other side to the same so it wouldn't pull. sucks mm are supposed to be the best. Its only dropped 1 inch...
Old Sep 20, 2012 | 06:25 PM
  #304
mdelao's Avatar
Is a negative camber the problem??
Like this?
Or like this (wheel near right fender)
Old Sep 20, 2012 | 09:05 PM
  #305
cpotts13's Avatar
The caster and everything is all within speck. its the camber is set to -1.5 on both sides and thats as close to in spec as we could get it.
Negative camber is where the wheel goes in at the top..
something like this but not quite as extreme
Old Sep 20, 2012 | 09:07 PM
  #306
cpotts13's Avatar
I saw a teskid block (bare block) on CL for 150 O____O it was from a 98 cobra
Old Sep 20, 2012 | 09:39 PM
  #307
mdelao's Avatar
Yes, mine looks like that that's a negative camber, have you thought about camber bolts?
Old Sep 21, 2012 | 05:22 AM
  #308
cpotts13's Avatar
Thats what i am going to have to do. Which is really crappy cause i shelled out $200 for cc plates that cant even get a 1inch drop into spec.
Old Sep 21, 2012 | 06:31 AM
  #309
mdelao's Avatar
Is what I'm afraid of. Mine has been lowered 1.5 in and thinking only To get a 20 dlls Camber bolts by the moment. No CC plates yet, or any other recommendation?
Old Sep 21, 2012 | 06:43 AM
  #310
1999Pony's Avatar
f that. I reckon it's a good thing I never want to be in spec.
Old Sep 21, 2012 | 01:24 PM
  #311
cpotts13's Avatar
Hmmm Idk about camber bolts to be honest. But a good set of CC plates should do the trick.
I guess -1.5 isn't to bad anyways. Hahaha
Old Sep 21, 2012 | 01:34 PM
  #312
1999Pony's Avatar
that's gotta be close to what I am running right now with just my lowering Springs.
Old Sep 21, 2012 | 01:55 PM
  #313
mdelao's Avatar
So CC is a waist of money?
Cpotts, what mark of CC you have?
Old Sep 21, 2012 | 03:36 PM
  #314
cpotts13's Avatar
Maximum motor sports. I have had a couple other guys say they are having the same problem as me.
if you dont have you alignment in spec it will wear your tires faster. thats all.
Old Sep 21, 2012 | 03:54 PM
  #315
Blue Notch's Avatar
I have the MM plates with a 1.5" drop and they couldn't get mine perfect either. Oh well.
Old Sep 21, 2012 | 04:52 PM
  #316
cpotts13's Avatar
I may drill it out a bit. But eh -1.5 is alright for now.
Old Sep 21, 2012 | 10:05 PM
  #317
cpotts13's Avatar
WORLDS BIGGEST PET PEEVE: squeeky car..
brakes are squeeking and it squeeks since theres no isos. I am about to loose my mind. \
Old Sep 21, 2012 | 11:10 PM
  #318
shurtual86's Avatar
Agree I just step on the brakes hard a couple and noise is gone for me
Old Sep 21, 2012 | 11:32 PM
  #319
cntchds's Avatar
Dude, switch the plates to the positive position. I'm almost positive you switched it to the negative position.
They should look like this.
You probably have them so that the bearing is closer to the middle. You can just swap them, and you will get much closer to being in specifications.
Old Sep 22, 2012 | 07:32 AM
  #320
cpotts13's Avatar
First is passenger second is driver
