Cpotts's 2kgt Build Thread
Old Aug 1, 2012 | 05:31 PM
  #241
cpotts13's Avatar
Me and a friend built some ramps! makes working under/ juacking it up easier.
Old Aug 1, 2012 | 06:19 PM
  #242
Dbranham's Avatar
Nice! Do they slide when getting on them
Old Aug 1, 2012 | 09:09 PM
  #243
cpotts13's Avatar
Yes they did on the back, we put them on the out outside of my garage against the little concrete bumb to hold them in place.
Old Aug 1, 2012 | 09:25 PM
  #244
1999Pony's Avatar
I've been wanting to do that for years, just never did. It would make jacking up a unibody car sooooo much easier lol.
Old Aug 1, 2012 | 10:00 PM
  #245
cpotts13's Avatar
I had Lowes cut the wood to the exact lengths I needed, used 2.5 inch screws, and when I brought it all home it was only a matter of screwing the boards together and filing the edges.
Old Aug 1, 2012 | 10:02 PM
  #246
1999Pony's Avatar
Yea, I work at lowes lol ,just never got aroud to doing it. Maybe becaue its easier to get under the car without them, not that its all that easy regardless.
Old Aug 1, 2012 | 10:55 PM
  #247
cpotts13's Avatar
we mainly made them because the black mustang (pictured above) is getting a few suspension goodies (j&m cc plates, konis front and back, bmr panhard bar, h&r supersport springs and black gt500's staggered 18inch) and the jack would most likely not be able to be removed once lowered..
Old Aug 1, 2012 | 11:00 PM
  #248
1999Pony's Avatar
A regular floor jack, I can't get out or under for that matter. I have a low pro jack and if I need to jack it up more I use my floor jack. Though I really should build some of those ramps as well
Old Aug 2, 2012 | 01:10 AM
  #249
cntchds's Avatar
I always have to drive up on a piece of 2x4 before I can get my jack under my K member.. And I always forget to put them back under the tires before I drop the car... -_-
Old Aug 3, 2012 | 12:42 AM
  #250
cpotts13's Avatar
Did a little maintenance, front sway bar bushings and end links were all cracked and "dry rotted", replaced them with MOG brand bushings.
old
old
Old Aug 3, 2012 | 02:20 AM
  #251
cntchds's Avatar
Can you feel a difference? I remember when one of those broke on my 94 it was like the car could hardly steer. It was insane how bad it felt without it.
Old Aug 3, 2012 | 07:03 AM
  #252
cpotts13's Avatar
The front feels very solid. Like a new car. Like when you go over bumps.
Old Aug 3, 2012 | 09:12 AM
  #253
shurtual86's Avatar
old
old
Wooh those are crazy worn out.
Old Aug 3, 2012 | 02:22 PM
  #254
WheelStander's Avatar
What are the lengths?
Nice idea.
Old Aug 3, 2012 | 08:07 PM
  #255
cpotts13's Avatar
Nice idea.
http://mustangworld.com/ourpics/News/mwramps/index.htm
Old Aug 4, 2012 | 04:40 AM
  #256
Thanks man.
Old Aug 7, 2012 | 10:31 PM
  #257
cpotts13's Avatar
Ordered eibach sway bar kit. Next is subframe connectors, competition engineering rear coil overs, Koni single adjustable struts (eventually coil conversion). For now I want to get rid of that raked look, so I wanna cut my rear springs a tad bit. How much should I cut? I have isolators on the top of the springs, I wanna put the bottoms on too, so I wanna drop the rear an extra .5-1inch with both isolators included.
Old Aug 8, 2012 | 03:36 AM
  #258
cntchds's Avatar
After my extended time with Konis, I would honestly say that if you aren't racing more than you're on the streets, you are better off with Bilsteins. Vastly better ride quality, even though they aren't adjustable.
Old Aug 8, 2012 | 07:26 AM
  #259
cpotts13's Avatar
Thanks for the advice man, i want to get the competition engineering rear coil over setup from american muscle (alot cheaper than buying the shocks and coil over kit) and use bilstein and mm coil over kit in the front. But i seriously need to get subframe connectors, Im just nervous cause they are weld in.
Old Aug 8, 2012 | 11:19 AM
  #260
1999Pony's Avatar
They will be the best thing you've ever done.
