Cpotts's 2kgt Build Thread
Old Aug 30, 2012 | 08:51 PM
  #281
shurtual86's Avatar
Are rear 13" brakes really necessary, unless you are going to the track a lot.
Old Aug 30, 2012 | 09:22 PM
  #282
stupidgenius36's Avatar
Just Plain Rude!
Probably not, but there are worse things to waste money on. Personally, I hate seeing a big rim with a tiny rotor hiding behind it...Just looks awkward. So to me a brake upgrade makes sense, even if you don't go to the track.
Old Aug 30, 2012 | 09:43 PM
  #283
cpotts13's Avatar
This.
Honestly the brakes look super unproportional right now with 13" inch in the front and a little tiny 10.5 in the rear. I wouldn't expect to get added braking performance at all, considering the 13" upgrade for the rear reuses the stock gt caliper (relocation bracket) and unvented eradispeed rotors.
I am doing it purly for looks.
Old Aug 31, 2012 | 04:15 AM
  #284
shurtual86's Avatar
that's why I dislike big SUVs that have big 20+ in rims and the little rotors, just looks funny to me.
Originally Posted by cpotts13
This.
I figured that's why, just thought id ask.
Old Aug 31, 2012 | 05:37 AM
  #285
cpotts13's Avatar
Old Sep 8, 2012 | 05:31 PM
  #286
cpotts13's Avatar
So I went to get my alignment done the other day, they said they maxed my CC plates out and it still is barely out of spec. What the heck? I have mm CC plates and am only lowered like 1.25 inches....
Old Sep 9, 2012 | 08:21 AM
  #287
shurtual86's Avatar
I'm probably gonna go get an alignment sometime this week.
Old Sep 9, 2012 | 08:25 AM
  #288
cpotts13's Avatar
I took it to a different place and the guy that did it made it even, he's a ford certified mechanic. Yayyy! He also removed the 3rd starter bolt for free. So now I can install motor mounts!!!
Old Sep 9, 2012 | 08:40 AM
  #289
shurtual86's Avatar
have fun with those.
Old Sep 9, 2012 | 09:02 AM
  #290
cpotts13's Avatar
Hard parts done!!
Old Sep 9, 2012 | 04:44 PM
  #291
cpotts13's Avatar
I swear I have crappy luck..
So I went to install my motor mounts..... got everything apart but the red and black wire that is attached to the bottom bolt... it was fused or something..... so I had to put everything back on. I put the starter back on, and connected the two wires to it. And bolted it up.
Now my car won't turn over, at all. It turns on and the electronics work
Just won't start.
Any ideas??
Old Sep 9, 2012 | 05:35 PM
  #292
cpotts13's Avatar
Wont crank just makes a single click when you turn the key on
Old Sep 9, 2012 | 06:45 PM
  #293
cpotts13's Avatar
Old Sep 10, 2012 | 07:18 PM
  #294
cpotts13's Avatar
Pictures from the weekends project:
Old nasty rotors, they were actually rusting in the middle of the rotor...
The new and the old, parts store rotors and pads, nothing special.
Getting my alignment did!
Old Sep 10, 2012 | 08:58 PM
  #295
Just Plain Rude!
So did you get it started? What was the issue?
Old Sep 10, 2012 | 09:09 PM
  #296
shurtual86's Avatar
It was the wires
https://themustangsource.com/f636/20...roblem-513443/
Old Sep 11, 2012 | 04:49 AM
  #297
cpotts13's Avatar
Yes it was the wires. They weren't tightened onto the starter enough. The bolt was finger loose. Tightened it all up and gave it a few love taps with a hammer and bam fired right up!
Old Sep 19, 2012 | 08:14 PM
  #298
cpotts13's Avatar
Have never mentioned what the final goal for my car is..
Im thinking teskid block, 302 stroker, 4v, monster cams, forged everything. Mated to a t56
Maybe a blower or maybe a N/A beast.
Anyways thats the long term goal. Right now with limited funds i wanna build the car to hold the power, manly suspension wise.
With that being said, whats next? Obviously subframe connectors... but then what?
Woot. Going to try the motor mounts once more sometime soon, my shop teacher said to cut the ground wires that fused to the motor mount bolt and splice a new connector back on. Dosent sound to hard.... hahaha.
Anyone in the houston area down to work on cars?
Old Sep 19, 2012 | 08:41 PM
  #299
1999Pony's Avatar
Sounds a lot like mine lol. Already have the teskid block sitting in my room
Old Sep 19, 2012 | 09:58 PM
  #300
cpotts13's Avatar
That would be a huge motivation to get sh*t done.
When i got my rims, i couldnt afford the tires at the same time so my rims sat in my room and i had to look at them every day till i could afford the tires. Very motivational though.
