Cpotts's 2kgt Build Thread
Old Jan 17, 2013 | 12:48 PM
  #501
stupidgenius36's Avatar
Just Plain Rude!
Originally Posted by cpotts13
Those are the things that have been done... and I did need them. Lol
Oh, ok. That makes more sense. Might as well change the fuel filter... they're pretty cheap.
Old Jan 17, 2013 | 12:53 PM
  #502
conv_stang's Avatar
Change the air in your tires
Old Jan 17, 2013 | 06:44 PM
  #503
cpotts13's Avatar
Done
Yep I bought the atf fluid and fuel filter today.
Old Jan 20, 2013 | 11:28 AM
  #504
cpotts13's Avatar
Well did the transmission fluid swap and replaced the fuel filter. Not very exciting i know. The transmission fluid was only slightly dirty, so not much difference. A bit smoother. Now the fuel filter was a big deal, at least to me. It was the original filter that was from the factory, and when I took it off and tipped it sideways, black fuel and sentiment poured out. Glad I got that crap out of my fuel system.
Up next is a tune, throttle body (70mm) and plenum.
I did notice a slight difference with the cai, so hopefully with all this it will be a huge gain over stock.
Also I plan to make my first dyno run this march on a mustang dyno. I'm pretty excited to see what I can put down.
I am really hoping to see 255 rwhp and 280rwtq with a
-93 octane "race tune"
-airaide cai
-professional products 70mm tb
-professional products plenum
Comments or suggestions welcomed!
Old Jan 20, 2013 | 11:17 PM
  #505
cpotts13's Avatar
Old Jan 21, 2013 | 04:49 AM
  #506
Evil_Capri's Avatar
These are on my list for spring time. I will (probably) also swap plugs as well and flush coolant.
Old Jan 21, 2013 | 06:48 AM
  #507
shurtual86's Avatar
did you hear any difference in the Exhaust?
Old Jan 21, 2013 | 08:52 AM
  #508
cpotts13's Avatar
Id recomend ngk spark pliugs all the way!
Yes I did actually. It is deeper idling and completely different driving around. Well imho. It sounds mean.
ALSO I have updated the first page, Check it out!!!
Old Feb 3, 2013 | 02:43 PM
  #509
steven46746's Avatar
Dynoed that puppy yet C?
Old Feb 3, 2013 | 05:04 PM
  #510
cpotts13's Avatar
Have not, I am waiting in my tax return to do some more mods before I do that
Old Feb 3, 2013 | 05:51 PM
  #511
JDF's Avatar
JDF
You could always wait for a shop to host a dyno day just to see what numbers you put down. I did that just to see what my baseline was.
Old Feb 3, 2013 | 06:03 PM
  #512
That's my plan, to get a baseline.
Old Feb 3, 2013 | 07:39 PM
  #513
cpotts13's Avatar
I need to look into the dyno day thing.. good idea
Old Feb 4, 2013 | 07:33 PM
  #514
cpotts13's Avatar
Let me give y'all a little update. I have narrowed down what I want for my car. I am going to do a vortech v1 supercharger with a built rear and and replace the clutch. I plan to have all this done and ready by the very end if the year. But I am going to start piecing everything together now.
Woot!
Old Feb 5, 2013 | 05:37 AM
  #515
1999Pony's Avatar
Old Feb 5, 2013 | 05:54 AM
  #516
Evil_Capri's Avatar
Woot!
Dig it!
Old Feb 5, 2013 | 01:09 PM
  #517
cpotts13's Avatar
I am going to start with the supporting mods first to be safe. It will cost $800 to do the clutch and $1100 for the rear end (31 spline moser axles, frpp diff, weld the axle tubes, all labor).
I plan on doing the $1500 supercharger which was featured in another forum.
For those of you that don't know about it you basically buy a used vortech head unit and buy all the misc parts from superchargersonline.com
http://mustangforums.com/forum/pipes...-its-done.html
Old Feb 15, 2013 | 04:20 PM
  #518
cpotts13's Avatar
This would be my luck... I think the differential is shot guys..
it clunks and rattles when i am making a turn slowly.. What could it be? I also found that the rear sear on the diff is leaking very slightly...
what should i do guys??
Should i get this and attempt the install myself?? http://www.latemodelrestoration.com/...-Lug-410-Gears
is it that hard???
Old Feb 15, 2013 | 04:55 PM
  #519
Just Plain Rude!
is it that hard???
You say it's leaking slightly, but how long has it been leaking? Perhaps it's already empty and that's why it's making the noise?
I personally wouldn't attempt it, if you haven't done gears before. Even if you take it to a shop, make sure they'll stand behind their work and redo it as many times as necessary if it whines afterwards.
Old Feb 15, 2013 | 07:50 PM
  #520
Dbranham's Avatar
For that price i would IRS swap
