'13-14 Cluster into '10-12 car (with TrackApps) retrofit
#1602
That is a realistic option.
If the black box converter can be fixed and improved, and a converter for the cruise done as well, then that is the way to go for automatic owners like me.
But seeing as how I survived all bruised and cut up from doing my pony lights, how hard can going through the firewall and engine bay really be? ... ...
#1604
LEXiiON
#1605
I will PM you to give me a step by step, thanks.
#1606
Ditto, I did this for my amp wire. Ford put a place for it in the grommet. Jim, you could always convert to 6 speed-Manual -Matt
#1610
LEXiiON
#1612
Coyotes, you can add a electronic BAP...boost a pump for FI.
#1613
I did same as other guys. You can pull out passenger wheel well liner and run wires under there like factory. My 2010 had gt500 pumps and Sub Amp wires there. My 2012 has sub amp wires there.
#1615
OK, update. It is going to work, but it is not plug and play.
Automatic owners of 2011/12 cars will need to get the 2013/14 sport shift ****. You do NOT need the entire shift box (luckily, I got mine for cheap anyway).
You will also need a male and female connector C307 to plug all the wires into. You will also need female pins to put into connector C175B on the PCM.
I have just ordered the male C307 connector. I will get it in about a week. Full write up in the other thread when I have it totally done next week.
This does add sport shift.
#1618
Matt: Could it be, that the 2013 ABS module gets a signal on Pin 12/34/37 and spits that incompatible software message (as it shouldn't get anything on those PINs)?
I would think, if the steering wheel position is missing on the HS-CAN, that it would throw a fault, rather than incompatible software.
Thoughts?
LEXiiON
#1619
Btw, i am really thinking about retrofitting the EPAS. The biggest difficulty is to find a proper FEAD belt, without the hydraulic power steering pump. Connections are very easy: Power/Ground from the battery (i think i read like 100A), HS+-CAN and power at run...
Once i found a proper length FEAD belt, i might do this. As i have the 2013 cluster, i can actually use it in the different modes.
LEXiiON
LEXiiON
#1620
LEXiiON
LEXiiON
