Notices
'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old 3/23/14, 11:38 PM
  #1261
jim010's Avatar
I also recall having it call up the back-up configuration (or whatever it stated to that effect) when it prompted me to do so.
Old 3/23/14, 11:44 PM
  #1262
jim010's Avatar
Originally Posted by dmhines
That was the only time you cancelled IDS? You did ATL CTL DEL and forced it ? Not sure how IDS forced during an ACM AS BUILT load would let you load the PCM .. but that is why its called a bug I guess ..
IDS kept prompting me to PMI the PCM. I finally relented and tried that. It then began to PMI the PCM. That's when I cancelled it because I didn't want to screw with the PCM. When we started a session, it just kept going back to that PMI. I didn't use critical Alt delete. I just unplugged the VCM from the computer to prevent it as there was no way to cancel the process or to go back.
Old 3/23/14, 11:48 PM
  #1263
jim010's Avatar
Also .. did you verify that your VIN is correct in the PCM now?
Other than DTCs, how else do I check to see the VIN in the PCM?
Old 3/23/14, 11:59 PM
  #1264
dmhines's Avatar
I think I found something .... Here are some PCM AS-BUILTS ...
MY 2012 Manual:
<NODEID>7E0<F111>BR3A-12B684-AC </F111><F113>CR3A-12A650-ACC </F113> <F188>CR3A-14C204-ACC </F188> </NODEID>
2013 Manual from an early build .. car number 1313 off the line
<NODEID>7E0<F111>DR3A-12B684-BA </F111><F113>DR3A-12A650-ABC </F113> <F188>DR3A-14C204-ABC </F188> </NODEID>
Here is the 2013 Automatic you used to do your PMI
<NODEID>7E0<F111>BR3A-12B684-CC </F111><F113>DR3A-12A650-ND </F113> <F188>DR3A-14C204-ND </F188> </NODEID><NODEID>720<F111>DR33-14F094-BA </F1
The first field I believe is the actually ECM part number if you google that 12B684 ... So it looks like 2013 Mustangs used the same ECM as 2012 if its an automatic. However .. The Manual transmission ECM is completely different part # (goes from BR3A to DR3A) so the Calibration won't load.
We can test the theory by you doing another PMI to the PCM and using the normal menus .. if it works .. then it looks like only automatic ECM's can be changed.
Tomorrow I will try editing and forcing a load by editing the AS-BUILT file ... but not sure if that will work.
Old 3/24/14, 12:03 AM
  #1265
jim010's Avatar
I'm scared to try again in case something gets messed up.
When I did purposely try to go in and do a PMI on the PCM, it would not let me, though, just as it isn't for you now. It was only when trying the ACM that this happened. My final attempt at programming the ACM was through the manual entry instead of the new session.
Old 3/24/14, 12:04 AM
  #1266
dmhines's Avatar
So the first time you tried to do a PCM PMI .. you got the error about the parts mismatch and it showed two different PCM part numbers? Back to the drawing board I guess ...
Old 3/24/14, 12:09 AM
  #1267
jim010's Avatar
I don't remember if it gave the part number mismatch, but it did say there was a matching error and to do a PMI and blah blah.
With the ACM, it said there was a problem with the VIN and to do a PMI on the PCM.
As I said, the last thing I did was try to enter the as built manually for the ACM, and then I aborted that. When I went back in and tried to do PMI on it again after aborting I accepted the prompt for the PMI on the PCM. I also said yes to getting the back-up configuration, or something to that effect.
Old 3/24/14, 03:34 AM
  #1268
LEXiiON's Avatar
Hi All,
could it be that my issue with the ABS module (incompatible Software) due to the fact that i did not have the 2013 cluster installed? Does the ABS talk to the cluster first during initialization and did not get the correct sequence from the cluster back?
I am currently trying to get a 2013 cluster, maybe Matt and Dan can guide me through again...
I also got the blank PCM message, but that i think was due to the fact that i have a 2010 PCM (it always asked me to do a PCM PMI, but i declined as it may brick my 2010 PCM)....
Once i am back i will check/try/work on that topic again....
LEXiiON
Old 3/24/14, 06:42 AM
  #1269
dmhines's Avatar
Jim .. is your VIN now correct in the ACM when you check the INFO button? perhaps the key to the puzzle is to get the ACM and PCM vin out of sync first.
Old 3/24/14, 08:40 AM
  #1270
jim010's Avatar
Originally Posted by LEXiiON
Hi All,
LEXiiON
I relented and did not decline.
Old 3/24/14, 08:42 AM
  #1271
jim010's Avatar
I'll go look, but I don't think so. Still getting the DTC claiming that the ACM is not communicating with the PCM or cluster.
Old 3/24/14, 08:45 AM
  #1272
jim010's Avatar
Still the 2010 VIN on the ACM
Old 3/24/14, 08:48 AM
  #1273
dmhines's Avatar
Jim .. can you send me your VIN again? I want to check your PCM AS-Built as compared to the -ND PCM As-Built .
I know you don't want to mess with it but it would be nice to see if you get the PCM part number mismatch if you try to do a PMI again ...
Old 3/24/14, 09:01 AM
  #1274
jim010's Avatar
I will get this for you on my break.
Old 3/24/14, 09:14 AM
  #1275
dmhines's Avatar
I am thinking its an AUTO vs Manual PCM thing ...
Here you can see in 2013 Model Year Auto and Manual use DIFFERENT PCM Hardware ...
BR3A vs. DR3A
Most Recent Software Part Number for MY13 MUSTANG, 5.0L
Part Number Module Catchword Hardware Type
DR3A-ABE PCM BLV4 DR3A-12B684-BA
DR3A-ACE PCM KWC4 DR3A-12B684-BA
DR3A-AHC PCM DHW2 DR3A-12B684-BA
DR3A-NE PCM WYN4 BR3A-12B684-CB
DR3A-NE PCM WYN4 BR3A-12B684-CC
DR3A-PE PCM DWP4 BR3A-12B684-CB
DR3A-PE PCM DWP4 BR3A-12B684-CC
DR3A-TA PCM LRT0 BR3A-12B684-AB
DR3A-TA PCM LRT0 BR3A-12B684-AC
DR3A-UA PCM WLU0 BR3A-12B684-AB
DR3A-UA PCM WLU0 BR3A-12B684-AC
DR3A-VA PCM NWV0 BR3A-12B684-AB
DR3A-VA PCM NWV0 BR3A-12B684-AC
DR3A-ZD PCM DZW3 DR3A-12B684-BA
FRPP-MOD PCM SE13 DR3A-12B684-BA
FRPP-MOD PCM SE13 BR3A-12B684-AB
FRPP-MOD PCM SE13 BR3A-12B684-AC
FRPP-MOD PCM SE13 BR3A-12B684-CB
FRPP-MOD PCM SE13 BR3A-12B684-CC
For 2012 Model Year the PCM Hardware was the SAME:
Most Recent Software Part Number for MY12 MUSTANG, 5.0L
CR3A-ABB PCM VKU1 BR3A-12B684-AB
CR3A-ABB PCM VKU1 BR3A-12B684-AC
CR3A-ACB PCM ZFK1 BR3A-12B684-AB
CR3A-ACB PCM ZFK1 BR3A-12B684-AC
CR3A-ACC PCM ZFK2 BR3A-12B684-AB
CR3A-ACC PCM ZFK2 BR3A-12B684-AC
CR3A-ADB PCM ZKD1 BR3A-12B684-AB
CR3A-ADB PCM ZKD1 BR3A-12B684-AC
CR3A-ADC PCM ZKD2 BR3A-12B684-AB
CR3A-ADC PCM ZKD2 BR3A-12B684-AC
CR3A-AFB PCM YGK1 BR3A-12B684-CB
CR3A-AFB PCM YGK1 BR3A-12B684-CC
CR3A-AGB PCM XYH1 BR3A-12B684-CB
CR3A-AGB PCM XYH1 BR3A-12B684-CC
CU7A-CA PCM NLC0 BR3A-12B684-AB
CU7A-CA PCM NLC0 BR3A-12B684-AC
CU7A-DA PCM DLS0 BR3A-12B684-AB
CU7A-DA PCM DLS0 BR3A-12B684-AC
CU7A-EA PCM ERL0 BR3A-12B684-AB
CU7A-EA PCM ERL0 BR3A-12B684-AC
CU7A-RA PCM WZR0 BR3A-12B684-CB
CU7A-RA PCM WZR0 BR3A-12B684-CC
CU7A-SA PCM SWM0 BR3A-12B684-CB
CU7A-SA PCM SWM0 BR3A-12B684-CC
FRPP-MOD PCM SE11 BR3A-12B684-AB
FRPP-MOD PCM SE11 BR3A-12B684-AC
FRPP-MOD PCM SE11 BR3A-12B684-CB
FRPP-MOD PCM SE11 BR3A-12B684-CC
FRPP-MOD PCM SE12 BR3A-12B684-AB
FRPP-MOD PCM SE12 BR3A-12B684-AC
FRPP-MOD PCM SE12 BR3A-12B684-CB
FRPP-MOD PCM SE12 BR3A-12B684-CC
So it makes sense the Jim was able to reflash a 2012 to a 2013 since his is and automatic and its the same hardware ...
Jim can verify this if he attempts another PMI ...
Or . .what I can try is to flash my PCM as a 2013 AutoMatic car and see if that works.
Old 3/24/14, 05:15 PM
  #1276
dmhines's Avatar
What I don't understand .. is I cannot even get IDS to reflash my PCM ... The only thing I can get IDS to do is reload a calibration. I cannot get IDS to see my PCM as blank. I get the messages that say its blank ... but then IDS figures out it isn't and just loads a calibration.
Old 3/24/14, 06:58 PM
  #1277
jim010's Avatar
And this calibration that loads isn't for a 13? Could it be that is what I did?
Old 3/24/14, 07:11 PM
  #1278
dmhines's Avatar
Your running a 2013 calibration and firmware for sure. All I can do is reload my factory calibration. Can't do a reflash either. Maybe I should see if I can load Boss firmware like ajpturbo did.
Old 3/24/14, 07:45 PM
  #1279
jim010's Avatar
call me Dan. I think I got it.
Old 3/24/14, 09:05 PM
  #1280
jim010's Avatar
Bust. I can now go in and PMI the PCM, but can't get Dan to do it.
MUST have something to do with my ACM and the VIN mismatch. Ironic that Dan can program his ACM no problem, but can't do the PCM. Reverse of my issues.
Quick Reply: '13-14 Cluster into '10-12 car (with TrackApps) retrofit
