'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old Feb 7, 2014 | 12:48 PM
  #761
323window's Avatar
Originally Posted by dmhines
Just replace the VIN in the link with the VIN your want the AS BUILT for.
Thanks got it.
Old Feb 7, 2014 | 01:32 PM
  #762
zeroaviation's Avatar
Originally Posted by 323window
Zero is the ICP, SJB, and BCM included on the link to the as built data sheet? I only see the PCM Module and BCE Modules listed.
Yes.
ICP - 720
SJB - 726
BCM - 7B7
-Matt
Old Feb 7, 2014 | 02:54 PM
  #763
323window's Avatar
Originally Posted by zeroaviation
Yes.
ICP - 720
SJB - 726
BCM - 7B7
-Matt
Thanks Matt, just wanted to get everything straight before I go back to the dealership.
Old Feb 8, 2014 | 11:43 AM
  #764
ajpturbo's Avatar
DR3Z10849CA
That is the part number for a 2013 boss cluster with track apps and 4.2" lcd screen.
This is what I bought and now just waiting for my scan tool
Old Feb 8, 2014 | 11:47 AM
  #765
ajpturbo's Avatar
323Window what kind of swap did you do exactly? What cluster to what model car?
Why could they not load the as built data?
Maybe It'll be more clear when I get my scan tool but I thought I would just load the as built in one shot but now it seems like you have to do things individually?
Old Feb 8, 2014 | 11:49 AM
  #766
Trevor08gt's Avatar
Originally Posted by ajpturbo
DR3Z10849CA
Looks great! I'm waiting on some email replys. Hope to have one soon as well!
Old Feb 8, 2014 | 12:07 PM
  #767
ajpturbo's Avatar
Trevor what cluster are you getting? For what car?
Old Feb 8, 2014 | 12:16 PM
  #768
Trevor08gt's Avatar
Looks like I'll most likely be getting just a 5.0 cluster with the screen. Would love to get a gt500 cluster but I can't find any used and I am NOT paying the full price for a cluster. I refuse lol. I just recently got my 2011 gt/cs and thats what it will be going in.
Old Feb 8, 2014 | 12:29 PM
  #769
ajpturbo's Avatar
What's the benefit of the screen? Track apps won't work since you have an 11' right? You would need the buttons,wheel and abs stuff right?
Old Feb 8, 2014 | 12:40 PM
  #770
Trevor08gt's Avatar
For me, Its more of the "coolness" factor. I feel like it adds a luxurious feel to the interior. It looks great and It seems much more convenient that the small screen I have now. Plus it just looks fantastic. And I'm hoping we can get some more things worked out. I could care less about track apps though. Like the others have said, what will you even use it but maybe a couple times when you first get it? To me its like Siri on the iPhone. She was really cool for a couple weeks. Probably haven't used Siri in over a year now..
Old Feb 8, 2014 | 12:43 PM
  #771
ajpturbo's Avatar
But besides the speed and performance timers I thought the gauges and some of the displays that the lcd shows are dead. Like head temp, volt, afr, oil temp and pressure. Am I wrong?
Old Feb 8, 2014 | 12:44 PM
  #772
Which VCM did you buy? and from where?
-Matt
Old Feb 8, 2014 | 12:48 PM
  #773
ajpturbo's Avatar
The one you mentioned from alibaba or that aliexpress. 200 shipped
Old Feb 8, 2014 | 03:21 PM
  #774
323window's Avatar
Hello ajpturbo,
I did a swap similar to Matt, Jim, and Zero by following there instructions on this thread. My cluster came from a 2013 Premium and I installed it in my 2012 base model 5.0/auto.
I think it was inexperience on the techs part (he did not know he was supposed to load it manually) and inexperience on my part by not telling him exactly what I wanted. (I just gave him a vin # of a 2013 premium/auto car and asked him to load as built data from it) Hopefully I will have better luck next time I take the car in.
Good luck
Old Feb 8, 2014 | 03:27 PM
  #775
323window's Avatar
Yes.
ICP - 720
SJB - 726
BCM - 7B7
-Matt
Hello Matt,
ajptorbo made me think of another question. Now that I have pats done, and my car cranks up fine with the new gauge panel, will I have to have pats done again when I have the dealership load the as built data manually? Sorry for all the questions, but I just want to have all the bases covered before I take the car in again.
Old Feb 8, 2014 | 04:56 PM
  #776
jim010's Avatar
You are not wrong, but we have been able to get the guages to work, and are now working on the cruise and Track Apps.
Old Feb 8, 2014 | 05:22 PM
  #777
Hello Matt,
No, ASBUILT can be changed without issue.
-Matt
Old Feb 9, 2014 | 08:56 PM
  #778
jim010's Avatar
OK, I have a cruise solution that is about as functional as can be.
The first pic (courtesy of Zero) shows the resistors as they are in a 2013/14 switch.
The second pic shows what you need to change the resistors to.
Buttons will have the following functions:
Cncl/Rsm - is now 'on'
On/Off - is now 'off'
-set - is the same
+set - is the same
The light indicators on the cluster still won't light up, but cruise will function almost as indicated on the buttons.
Attached Thumbnails '13-14 Cluster into '10-12 car (with TrackApps) retrofit-circuit-cruise-2013.jpg   '13-14 Cluster into '10-12 car (with TrackApps) retrofit-circuit-cruise.jpg
Old Feb 9, 2014 | 09:16 PM
  #779
jim010's Avatar
I can't solder this small myself, but I had an electronics guy do it for $20.
Old Feb 9, 2014 | 10:25 PM
  #780
dmhines's Avatar
Cool .. is it JUMPER or 1000 ? .. the first time I saw the pic it said 1000.
So for $20 your guy did the soldering and supplied the resistors?
