Notices
MGW Shifter Ordered
Old 3/16/12, 05:43 PM
  #181
5PTOHH's Avatar
Is this shifter worth it if all you do is spirited driving on the street? I do miss third a lot when I am going at it hard.
Old 3/16/12, 06:14 PM
  #182
Hytek's Avatar
You answered your own question with missing 3rd.
But if you don't want to spend the money get yourself a good shifter bracket like the Steeda for $80. I'll be selling mine in a few weeks once my MGW comes in.
Old 3/16/12, 06:24 PM
  #183
5PTOHH's Avatar
Not so much about the money more about not having access to a lift or having anyone around me that's mechanical savvy lol.
Old 3/16/12, 06:32 PM
  #184
11SHELBYGT500's Avatar
You don't need a lift as for the latter, learn by doing and a shifter change is one of the easiest things you can do.
Old 3/16/12, 06:34 PM
  #185
5PTOHH's Avatar
Sounds good. Might as well get my feet wet sooner or later. Thanks for answering my questions.
Old 3/16/12, 07:53 PM
  #186
Hytek's Avatar
I helped my buddy do his on jack stands and I'll be doing mine the same way. Watch the videos a few times to get yourself prepared. I'm not mechanically savvy myself, but I've learned a lot from friends, this forum, and doing things by trial and error.
Old 3/16/12, 08:13 PM
  #187
Originally Posted by 2012GTCS
Well first few steps completed. Didn't start as early as I wanted to. Weather is light rain almost a mist and don't wanna lay on wet ground and then back into car. First few steps done.
That looks great man. How's it coming along? Did you end up finishing it?
Yeah I never used that special extension rod no need
Old 3/16/12, 10:12 PM
  #188
2012GTCS's Avatar
This is true, partially. The MGW isn't like just dropping any "regular" short throw in. In my 89 it was like 15 minutes. This is much more in depth and requires a little more mechanical work.
I was just about to post up, you definitely DON'T need a lift. I would be the first one to be bltching that it sucked. It is 100% do able on stands. Little awkward using the racket but that's all driveway jobs
Also, you can do it fine with 1 person. 2 people is not necessary.
Old 3/16/12, 10:13 PM
  #189
2012GTCS's Avatar
So far I'm up to bolting on the support arm with some loctite ( I think I'm gonna use my own loctite brand as opposed to what they supplied even tho that is decent stuff)
Then it's onto the top part of the shifter and buttoning it up.
I did most of the job in the darkness in the driveway with a hanging light. I was actually a lot of fun, never got frustrated once. But haven't done the boot yet.
Old 3/17/12, 07:01 AM
  #190
Hytek's Avatar
You finish or are you still screwing around with the boot lol.
Old 3/17/12, 07:10 AM
  #191
Probably passed out from swearing at that boot....lol
Old 3/17/12, 09:32 AM
  #192
2012GTCS's Avatar
Lol no I had stopped, I had some stuff to do. I was interrupted a bunch. Starting it back up in about an hour. Shouldn't take more then 45 min
Old 3/17/12, 01:31 PM
  #193
2012GTCS's Avatar
Ahhhhhhh!!! $&)((;/!?&$)$&$("@!!, Allen keys!!!! I knew when I saw them it would be an issue. I hate when they use them, I hope there's a reason. Lol. Especially when I need a extended Allen key drill bit. WTF Lol
Old 3/17/12, 02:25 PM
  #194
UnrealFord's Avatar
Awwe too bad, mines all done. Beat ya nana.
My impressions, even with extensive sound deadening and matting the solid rear mount to the body carries more transmission noise into the car after transmission warms up.
The good part is that hitting 3rd to 4th does seem to be completely gone ( which is the only reason I purchased it )
The notchyness from 1st to 2 nd is still the same, but it never bothered me.
The install was alittle tricky getting 2 halves together but I had good help.
The rubber boot was alittle pain but all you gotta do is take your time..
Shifter is A plus.
Id say just change back body mount to fix issue with shifter, but when I removed the stock shifter I noticed the shifter had some pretty severe wear on the reverse bracket.
Old 3/17/12, 03:01 PM
  #195
5PTOHH's Avatar
What do you mean by back body mount? You mean the shift bracket that can be replaced by the barton or steeda unit?
Old 3/17/12, 03:05 PM
  #196
UnrealFord's Avatar
Yes exactly, makes me wonder if that would have been enough, just replacing the back shift bracket with a Steeda or Barton. Id say for anyone thinking of shifters to at least try swapping out the factory shifter bracket and use a Steeda or Barton first.
Old 3/17/12, 03:07 PM
  #197
Hytek's Avatar
It's similar, just mgw comes with it's own built in. The piece that has the 2 bars through it that bolts to the car is essentially the same function as what the steeda/barton bracket do.
Old 3/17/12, 03:10 PM
  #198
Hytek's Avatar
I was tree'd lol. I have the steeda bracket and it's good for the most part, however the shifter still feels sloppy and I hate guessing if I'm going into 3rd or 5th. Same goes for 1st and reverse, sometimes I can't tell until I start letting the clutch out.
Old 3/17/12, 04:35 PM
  #199
Ahhhhhhhh sorry man NOW I remember that extension thingy you were talking about. Yes bolting that whole thing down, all 4 of them, was another royal pain the a**. Why? Because I did not have drill Allen bits like George in the vids did LOL. We spent another 15 mins just turning each bolt slowly as hell. We were also all worried about snapping Allen wrenches. I kept counting how many allens I had remaining.... Sigh....
Yes, that's one of the favorite parts about the mgw...vagueness and gear guessing is GONE.
Old 3/17/12, 04:44 PM
  #200
Hytek's Avatar
I can't wait then! My reverse spring must be so loose because I can't really tell sometimes between 1st and reverse. I hate having to think about which gear I'm going in.
Quick Reply: MGW Shifter Ordered
