412hp!!! Is it true???
Old Dec 27, 2009 | 07:09 PM
  #421
UnrealFord's Avatar
Originally Posted by 05mach1
When I get my 5.0 GT in late summer the 5.0 badges are gone the Running pony will on the sides.
Do you really own all those Mustangs? Ive seen people own many Mustangs but they were usually classics..
I need to do whatever you do for a living.. Da'ammmm
Old Dec 27, 2009 | 07:33 PM
  #422
825LTRGT's Avatar
The 5.0 badges should be cool to see again.
Old Dec 28, 2009 | 02:08 AM
  #423
PTRocks's Avatar
Here you go:
Old Dec 28, 2009 | 02:23 AM
  #424
LateralG's Avatar
Originally Posted by PTRocks
Here you go:
Classy. I like it.
Old Dec 28, 2009 | 07:06 AM
  #425
ferrarimanf355's Avatar
I like the new 5.0 badges. YMMV, I guess.
Old Dec 28, 2009 | 07:10 AM
  #426
Uh, guys, there may be a problem.
http://media.ford.com/images/10031/2...g_GT_Specs.pdf
I hope the listed curb weight is an estimate...
Old Dec 28, 2009 | 07:15 AM
  #427
Topnotch's Avatar
P235/50R-18 all-season
18 x 8.0-inch wide spoke painted aluminum wheels
Standard aluminum wheel mini-spare
Optional 18 x 8.5-inch premium painted aluminum wheels
19 x8.5-inch machined face with painted spoke aluminum wheels
18 x8.0-inch sterling gray metallic painted aluminum wheels (MCAS Edition)
19 x8.5-inch machined face with argent painted aluminum wheels (GT/CS)
19 x9.0-inch dark-stainless premium painted aluminum wheels
(Brembo Brake Package)
Old Dec 28, 2009 | 07:21 AM
  #428
I wonder what the GT/CS wheels look like...
Old Dec 28, 2009 | 07:34 AM
  #429
Tony Alonso's Avatar
I am going to be optimistic and say that the weight listed is inclusive of all fluids and a driver (as I understood curb weight to sometime indicate), not the weight of just the car. If so, that's a heck of a weight gain with an all-aluminum block engine. Maybe all the extra valvetrain hardware added up to some extra pounds, but I would not think THAT much.
I guess we will find out...
Old Dec 28, 2009 | 07:44 AM
  #430
I thought the new motor was only 10 pounds heavier than the old one...
Old Dec 28, 2009 | 07:50 AM
  #431
According to cars.com, the '11 GT is getting a 1-4 skip shift similar to what the Challenger and Camaro have.
http://blogs.cars.com/kickingtires/2...auto-show.html
I hope it's not a pester...
Old Dec 28, 2009 | 07:59 AM
  #432
PTRocks's Avatar
The weights are bunk. We'll have to wait until the final numbers to come out to know for sure. But the weight is going up for the GT.
The new engine ie 430 lbs - 10 lbs heavier that the 4.6
The new transmissions weigh - ?? lbs more
There is new sound deadening material on the firewall, inside the rear wheel wells, etc - ?? lbs more
There is new structural foam in the A pillars
Convertibles get numerous new braces
There is a new aerodynamic tray under the car
etc. etc.
Old Dec 28, 2009 | 08:01 AM
  #433
This is why I am optimistically saying I would not expect that quoted figure of 3875 for the manual to be just the car. It possibly could also be an error. I think someone else pointed out that the rotor measurements were not correct in some of the articles or press releases.
My assumption was that this car would come in around 3600-3650 (max) for a weight with fluids and a full tank of fuel and no driver.
Old Dec 28, 2009 | 08:06 AM
  #434
etc. etc.
As long as it still enjoys an advantage over the Camaro in terms of curb weight, I think I can live.
  #435
IWantMyNewGT's Avatar
IIRC this is the first confirmation that the 5.0 is in fact 302 CI (not 301 or 303) and that 91 octane fuel is recommended.
Old Dec 28, 2009 | 08:07 AM
  #436
etc. etc.
Quite possibly the transmissions account for the biggest chuck of any weight gain - good point.
Old Dec 28, 2009 | 08:48 AM
  #437
The spec sheet someone posted mentions the following -
302 cu. in./4,951 cc
91 octane (unleaded 87 octane minimum)
Old Dec 28, 2009 | 11:14 AM
  #438
Ugh I hope not!
Old Dec 28, 2009 | 11:17 AM
  #439
Overboost's Avatar
I was right about the subtle changes, the rear fascia has 'slats' in between the tips, the 2010 does not.
I'm shaving those fender badges ASAP. Still want to see more info on the 2011 GT/CS
Old Dec 28, 2009 | 11:38 AM
  #440
PTRocks's Avatar
From what I recall reading here - GT/CS + Track Pack is a no go.
