MGW short throw shifter !!!!
Old 2/27/07, 02:51 PM
  #221
05Blackbeauty's Avatar
just ordered mine
Old 3/2/07, 05:12 AM
  #222
05YellowGT's Avatar
Bump ...
Old 3/2/07, 05:42 AM
  #223
MGW
Former Vendor
MGW's Avatar
Originally Posted by 05YellowGT
Bump ...
UPDATE!!!
well the shifter pieces that i make are basically done and at the anodizers. the only thing i am waiting on is the first production run of the rubber sound plates and lower dust boots. my target of mid march looks spot on and we should start assembling the shifters by middle of the week after next to go out.
AS SOON as i get the rubber dust boots i will be assembling a complete shifter and posting FULL detailed pics.
oh and our patent application was filed this week and everything is done.
regards
george
Old 3/2/07, 06:58 AM
  #224
05YellowGT's Avatar
Old 3/2/07, 09:51 AM
  #225
freebass55's Avatar
Right on.
Old 3/2/07, 05:53 PM
  #226
flashfearless's Avatar
George, your timing will be pretty good for me. Thanks for scheduling that around my needs.
Old 3/2/07, 06:33 PM
  #227
Got Oatz's Avatar
Time to schedule a Friday off from work!! Can't wait George, and thanks.
Mike
Old 3/2/07, 10:19 PM
  #228
eromzek's Avatar
Thanks for all the updates George. Any idea how much shorter the shifts are in comparison to the competition with the shifter set to it's shortest shift setting? Thanks again for all the updates.
Old 3/5/07, 05:31 AM
  #229
05YellowGT's Avatar
Bump ...
Old 3/5/07, 06:18 AM
  #230
MGW
Former Vendor
MGW's Avatar
sure sure what this means. is something wrong with the release date??
george
Old 3/5/07, 07:00 PM
  #231
eci
eci's Avatar
George are you taking orders now? I spoke with your personally and left my number but no call yet...
Old 3/6/07, 05:28 AM
  #232
george
I was being sarcastic that it looks like you planned the release date around my needs. As in, I'm not ready this week. But probably will be ready when you are. Nevermind.
Old 3/8/07, 05:17 AM
  #233
05YellowGT's Avatar
Bump , so George can find it easily ...
Old 3/8/07, 02:58 PM
  #234
MGW
Former Vendor
MGW's Avatar
AND FINALLY SOME PICTURES OF THE COMPLETE SHIFTER!!!!!
( WELL NOT EXACTLY COMPLETE I AM STILL WATING ON THE "UPPER" DUST BOOT AND THIS PICTURE DOES NOT SHOW THE RUBBER SOUND PLATE THAT IS PART OF THE KIT)
some notes about the pictures....
1. the side view shows the shifter with the shift handle option for use with
a hurst ball ****. we will also have 2 other options for the shift rod: 1 for the stock **** and even one for the older 12mm x 1.75 pitch threads.
2. the lower linkage bracket ( the square part on the bottom with the hole in it is shown fully retracted in the center shaft. this will give the "LONGEST" throw setting. about 10-15 percent shorter than stock. when extended to its usable range limit it will shorten the throw close to 50 percent!!!
3. the top view shows a significant feature. we stabilize the shifter with the tranny close to the centerline of the shifter body not off to the side like the stock and other shifter designs do., this eliminates the 3rd gear lockout problem so many people have *****ed about.
4. looking at the detail of the shaft you will see that it actually clamps the rod and center shaft indepedently. this allows the shift rod to slide up and down for height and also swivel 180 degress to adjust location in relation to the console. so guys with gorilla arms and short legs will love this feature becasue you can actually swivel the handle all the way up to 12 o'clock close to the dash if the stock position is too close to you.
5. the ENTIRE body is machined from aircraft grade alum. and 303 stainless steel. EVERY aluminum part is HARD coat anodized NOT just decorative type 2 black. it will hold up for a looooonnnggggg time. also, every bolt that has a stress rating is not stainless but rather grade 8 steel that is "ARMOR COATED" which is a new coating that gives the same durability for corrosion as stainless but allows you to use a much higher rating of bolt.
6. if you notice the end of the shifter that attaches to the tranny you will see that on BOTH sides of the mount are stainless steel flanged bushings for better strength when attaching to the tranny.
7. none of the parts on this shifter are urethane as this is a poor choice for noise and vibration issues. CAN YOU SAY "squeak squeak".
8. there are currently 3 utIlity patents pending on this shifter. 2 of them are the same patents that cover our older model shifter. the new patent is to protect the unique feature of the shifter that allows the throw to be adjusted.
regards
george
Old 3/8/07, 03:04 PM
  #235
13 MIKE's Avatar
Awesome, can't wait.
  #236
YALLER's Avatar
DANG!
Old 3/8/07, 03:07 PM
  #237
Phorty's Avatar
Mmmmmm....
Old 3/8/07, 03:08 PM
  #238
05HOTROD's Avatar
HOLY MOLY,,,,this thing look awesome,,,,I can't wait george....
looks good........
Old 3/8/07, 04:41 PM
  #239
Looks great George. Hopefully, I won't need an engineering degree to install it. LOL...
Old 3/8/07, 04:54 PM
  #240
MGW
Former Vendor
MGW's Avatar
actually the shifter is designed to break down and install in 2 sections and it is VERY easy to do. i can actually install one in about 10 minutes now.
regards
george
Quick Reply: MGW short throw shifter !!!!
