5.0 mustang 95
Old Feb 8, 2013 | 06:29 AM
Blackout's Avatar
5.0 mustang 95
What type automatic transmission did the 95 5.0 have? Was it the same and the 2000 v6 transmission?
Old Feb 8, 2013 | 10:51 AM
1999Pony's Avatar
Don't think so. The auto in the 95 is a AODE
Old Feb 8, 2013 | 11:22 AM
Blackout's Avatar
Can I easily bolt that up to my car?
Old Feb 8, 2013 | 01:02 PM
bluethunderhorse's Avatar
Yes it will bolt up the 3.8 shares the 5.0's bolt pattern
Old Feb 8, 2013 | 03:05 PM
1999Pony's Avatar
Check the input shaft length. I'm not sure if they are different, but it wouldn't be a lot of fun if they are.
Old Feb 8, 2013 | 05:48 PM
Blackout's Avatar
If I did this swap where's a good source that could help me for the swap if I go this route
Old Feb 8, 2013 | 06:24 PM
shurtual86's Avatar
I remember seeing write ups on Modded Mustangs a while ago, but try to google it, I'm sure you'll find some good info.
Old Feb 10, 2013 | 05:19 PM
onequickstang's Avatar
This may sound stupid but how many gears does a 94 GT automatic tranny have? I swear it feels like 3 + overdrive but that doesn't sound right at all....
Old Feb 10, 2013 | 05:22 PM
steven46746's Avatar
Yes 4 speed auto
Old Feb 10, 2013 | 05:23 PM
Originally Posted by steven46746
Yes 4 speed auto
I was afraid of that. Is it possible to change it to 6 without a whole new tranny?
Old Feb 10, 2013 | 05:47 PM
1999Pony's Avatar
Nope. No room for the extra gears. And even if it were possible, the cost would not be worth it.
Old Feb 10, 2013 | 08:02 PM
Hmmm ok. I'm planning on rebuilding the tranny soon anyway, do you know of anywhere that sells clutch pedal assemblies? I want to change it from auto to manual, I've found everything I need except the assembly.
Old Feb 11, 2013 | 03:23 PM
1999Pony's Avatar
Junkyard, craigslist, or ebay will be your best resources.
Old Apr 25, 2013 | 08:58 PM
Blackout's Avatar
I'm serious about this build as you see I'm tearing that crapy v6 apart and going to swap to 95 5.0. I want to go carbed. So will this work? My plan: carbed 95 5.0 with t 5 trany no computers old school will the block bolt up to my 2000 v6 k member?
Old Apr 26, 2013 | 11:38 AM
Yes it will if you use 94-95 motor mounts
Old Apr 26, 2013 | 01:52 PM
Blackout's Avatar
Alright I just had to get more confirmation
Old Apr 26, 2013 | 03:48 PM
mccolaus000's Avatar
85 and older 302 foxes came carbed. Might be easier goin that route instead of gettin a 95 302 and switching it to carbed. Might be able to get motor and tranny from same donor car. Seems like less hassle
Old Apr 26, 2013 | 04:10 PM
skunk21's Avatar
He can carb a 94-95 5.0. and a 93, 92 etc. plenty of efi fox guys convert over to carb it's easy enough to do.
Old Apr 26, 2013 | 04:17 PM
Blackout's Avatar
Will I need a computer if I go with a t5?
Old Apr 26, 2013 | 04:38 PM
Nope
