5.0 mustang 95
Old Apr 30, 2013 | 04:27 PM
  #81
Blackout's Avatar
Attached Thumbnails 5.0 mustang 95-image-606263413.jpg   5.0 mustang 95-image-1152231162.jpg
Old Apr 30, 2013 | 04:28 PM
  #82
Blackout's Avatar
Donor car 351 Cleveland
Old Apr 30, 2013 | 04:43 PM
  #83
Blackout's Avatar
The guy working there said 1000 is possibly what he will let it go for.
Old Apr 30, 2013 | 04:46 PM
  #84
Blackout's Avatar
It was a guy working there he has to check with jis boss tomorrow
Old Apr 30, 2013 | 05:00 PM
  #85
bluethunderhorse's Avatar
That does not look like a Cleveland. The valves in a cleveland are angled
Besides Cleveland engines are weak and prone to breakage. The only good thing about them are the heads.
Old Apr 30, 2013 | 05:11 PM
  #86
Blackout's Avatar
Oh wow thanks. Good deal man. Well then it's best if I keep searching. Thanks man. Glad I came here what about the Windsor?
Old Apr 30, 2013 | 05:12 PM
  #87
Blackout's Avatar
What do you thing that engine was?
Old Apr 30, 2013 | 05:25 PM
  #88
Inline valves tells me it's a windsor, but cant really tell if it's a 302 or 351 without knowing the casting numbers off the block, or how wide the intake is. All windsors have inline valves, all clevelands and modifieds have canted valves
Then you have the original Boss 302. It was a 302 windsor block, with cleveland heads, and a special intake to make it all work. It was called a clevor engine
Old Apr 30, 2013 | 05:28 PM
  #89
Blackout's Avatar
Where can I find the casting numbers?
  #90
Blackout's Avatar
And btw it had gas mixed in the oil too
Old Apr 30, 2013 | 05:38 PM
  #91
The casting numbers are on the block are behind the starter. You have to remove the starter to see them. You will see numbers that look like this C90E-8015b. Another thing 351 clevelands do not have the upper radiator hose going to the intake, It goes directly to the engine block. and they were only made between 1970-74. Only reason I know all this, is because I spent 4 years finding parts to build a Boss 302 to go into my old car. Only to have to sell it, when all I needed for it was a 4 barrel throttle body, and valve covers.
Old Apr 30, 2013 | 06:16 PM
  #92
Blackout's Avatar
Great information thanks man.
Old May 1, 2013 | 09:53 AM
  #93
Blackout's Avatar
Ok so do y'all think this is a great donor car? Not only that but it actually drives too
Old May 1, 2013 | 09:57 AM
  #94
Blackout's Avatar
Not only that but what rear ends are compatible to my 2000?
Old May 1, 2013 | 10:06 AM
  #95
Blackout's Avatar
I'm doubting this car the guy is trying to **** hard to get rid of it. The place it's at us a wrecker place.
Old May 1, 2013 | 10:09 AM
  #96
Blackout's Avatar
Have a feeling I'm being scammed.
Old May 1, 2013 | 10:20 AM
  #97
You are, first he was trying to tell you the engine was a cleveland when it clearly is not
Old May 1, 2013 | 10:25 AM
  #98
Blackout's Avatar
Correct. Thanks to you I wouldn't have even thought to do my research in my book that I have
Old May 1, 2013 | 06:31 PM
  #99
Blackout's Avatar
There is controversy whether or not my transmission will work or not...
Would this be a smart upgrade?
http://www.americanmuscle.com/qa1-tu...995&adtype=pla
Old May 1, 2013 | 06:36 PM
  #100
That's the wrong k member, you need the one for 79-95. Tubular k members are best for drag racing, or if you plan on running a huge set of long tubes.
Will also bolt into a 96-04 Ford Mustang for use with a Windsor based engine.
http://www.uprproducts.com/mustang-p...member-79.html
