5.0 mustang 95
Old Apr 26, 2013 | 05:00 PM
Blackout's Avatar
Alright. I'm disconnecting the motor mounts on the v6. Could y'all tell me how many bolts a 2000 v6 has to the trany?
Old Apr 26, 2013 | 05:39 PM
Blackout's Avatar
Never mind screw that. Those bolts are too tight so I will take engine out with tranny
Old Apr 26, 2013 | 05:51 PM
lexi2013's Avatar
Why not just buy a older 5.0? You can get them pretty cheap. Just my .02.
Old Apr 26, 2013 | 06:12 PM
Blackout's Avatar
Older like what a fox body? I just like my new edge.
Old Apr 26, 2013 | 06:14 PM
Blackout's Avatar
Ok two questions can my build have an automatic transmission with the computer for the transmission but not the engine? And if I get the AODE transmission is that a fought transmission?
Old Apr 26, 2013 | 06:55 PM
Blackout's Avatar
Ignore last post going to stick with the t 5 swap
Old Apr 26, 2013 | 07:14 PM
lexi2013's Avatar
Yes and no. On cars.com I found even new edge GT's going for 6-8k and older fox bodies for around 5ish.
Old Apr 26, 2013 | 07:27 PM
Blackout's Avatar
Yeah for 3000 I can have my build
Old Apr 26, 2013 | 07:32 PM
lexi2013's Avatar
Never really saw the point I'm engine swaps to a old engine. Saw some people swapped the new 5.0 into a new edge that was pretty cool.
Old Apr 26, 2013 | 07:48 PM
bluethunderhorse's Avatar
Older engines are a lot easier to work on, parts are cheaper, easier to diagnose problems, and the reaction from people to see a newer car with a Holley double pumper carb
Old Apr 26, 2013 | 07:53 PM
lexi2013's Avatar
Doesn't the old 5.0's barely pump out 200hp never mind how much it lost as the years went on. I don't know anything about it so I won't judge but I do agree that it's easier to work on the older engines. No electronics and all that.
Old Apr 26, 2013 | 08:02 PM
Blackout's Avatar
I can respect your opinion the coyote is the ultimate build. But I want something that I know all about. And I want something old school in my new edge that I know will work and that will be a tribute to 5.0. It's my dream
Old Apr 26, 2013 | 08:04 PM
Blackout's Avatar
This is the build I want to do
http://www.latemodelrestoration.com/...k-Crate-Engine
Old Apr 26, 2013 | 08:21 PM
the 94-95 5.0 had 215 HP 87-93 had 225
Old Apr 26, 2013 | 08:35 PM
Blackout's Avatar
On a carb build how do you do the wiring as far as engine speed, rpm, oil pressure, h2o temperature, and amp ?
Old Apr 26, 2013 | 08:49 PM
lexi2013's Avatar
Huh the 2005 v6 mustangs pumped out the same hp numbers as the older v8's but not the same torque.
Old Apr 26, 2013 | 09:06 PM
Blackout's Avatar
I could go with a 351 but that would be more expensive?
Old Apr 26, 2013 | 09:13 PM
Blackout's Avatar
I know more about the 5.0 than anything else
Old Apr 26, 2013 | 09:19 PM
mccolaus000's Avatar
Or the same sound. Gotta love v8s with with off road exhaust 😄. Also I feel they were underrated. A buddy of mine has a 94 cobra which is 240hp stock that with only gears and o/r X pipe dynoed just over 300hp.
Old Apr 26, 2013 | 10:00 PM
  #40
1999Pony's Avatar
Probably not by much.
Are you planning on rebuilding whatever 302 you get. If so, why not go stroker, 331 or 347? I think that would be sick
