5.0 mustang 95
Old May 12, 2013 | 12:21 AM
  #141
bluethunderhorse's Avatar
Parts like that you will want to be immovable. Large front bolts, 110 ft-lbs with red lock tight. Smaller rear bolts 95 ft-lbs with red lock tight. Bolts that hold the A-arms to the k member 150-200 ft-lbs with red lock tight. Motor mounts to engine bolts 40 ft-lbs with blue lock tight, motor mount to k member bolts 100 ft-lbs with blue lock tight.
Old May 12, 2013 | 12:24 AM
  #142
Blackout's Avatar
Originally Posted by ShaneGT
pick up a maintenance manual on your model car, it will have all the tech specs and torque specs you will need.
I got books keep forgetting to look at them
Old May 12, 2013 | 12:29 AM
  #143
Blackout's Avatar
What type of break system does the 95 5.0 have same as my v6 right?
Old May 12, 2013 | 09:06 AM
  #144
ShaneGT's Avatar
brake* and i think the GT has bigger brakes. I know on the latest gen thats true
Old May 12, 2013 | 09:58 AM
  #145
Blackout's Avatar
I mean as far as brake booster and set up looks the same
Old May 12, 2013 | 12:49 PM
  #146
1999Pony's Avatar
Your car is hydroboost and 94-95 are not. That being said, you can still use your brakes just fine. Just don't change anything in the brake system.
Old May 12, 2013 | 01:00 PM
  #147
Blackout's Avatar
What's the plug in to the break reservoir for?
Old May 12, 2013 | 01:07 PM
  #148
Blackout's Avatar
I am pretty much sure it's a fluid level sensor right?
Old May 13, 2013 | 08:52 AM
  #149
devontayh's Avatar
hey i got a 2001 mustang thats been salvaged just wondering how can i take off the front bumper
Old May 13, 2013 | 01:13 PM
  #150
Blackout's Avatar
Isn't the mustang 5.0 the same as the cougar 5.0?
Old May 13, 2013 | 07:46 PM
  #151
Blackout's Avatar
I've been Doing research and the 5.0 will not bolt up to the 4r70w WILL NOT....
Old May 13, 2013 | 08:10 PM
  #152
Blackout's Avatar
Beginning to have doubt in this swap
Old May 13, 2013 | 09:00 PM
  #153
The 4R70W behind your V6 will bolt to a 5.0. The 4R70W from a 4.6 will not. The V6 and 5.0 have the same bolt pattern
Old May 13, 2013 | 09:05 PM
  #154
lexi2013's Avatar
Thought the auto transmissions in the v6 and v8 of the same year were the same. Why the difference in transmissions? Is it like that for the newer models too?
Old May 13, 2013 | 09:16 PM
  #155
Blackout's Avatar
One way to find out ill take your word for it. I believe you. Gonna stick with it no backing down
Old May 13, 2013 | 09:42 PM
  #156
No. The 3.8 is based off of the windsor 5.0, it's basically just a 302 with the number 3 and number 7 cylinders removed. the newer 3.7 is an all new engine that shares the bolt pattern with the 4.6 and coyote 5.0. When a company builds a transmission they first design the main body of it with the gears, clutches, and so forth, then they have the bellhousing that is different for each engine family.
Old May 13, 2013 | 09:55 PM
  #157
Blackout's Avatar
And that's the 99-04 v6?
Old May 13, 2013 | 09:58 PM
  #158
82-04
Old May 13, 2013 | 10:28 PM
  #159
Blackout's Avatar
So if I go carbed how will sensors go like I plan to have speed gauge , rpm gauge , oil pressure , water temp, and amp gauge how's all that set up? On a wireless computer less set up ?
Old May 14, 2013 | 05:47 AM
  #160
Blackout's Avatar
Look even if the 4r70w didn't fit, which it should ill figure out something. For now I need to let my hand heal been a week and the bone is still broken
