'13-14 Cluster into '10-12 car (with TrackApps) retrofit
#981
#983
LOL. Thankfully I bought the VCM. So who do I contact at united radio about sending my cluster in?
Sometimes Bob has a cluster he can sell, too.
#985
Dealer can have the mileage set for you when you order from them.
This one is ready to install, odometer has been set.....awaiting the VCMII and the car...
![Name: BossClust1_zpsd7157752.jpg
Size: 309.1 KB](https://themustangsource.com/forums/attachments/f803/194579d1501285306-13-14-cluster-into-10-12-car-trackapps-retrofit-bossclust1_zpsd7157752.jpg)
#988
Very cool. But since I was planning on doing a 14 premium cluster in my 14 base, will this post any new problems if I get this 13 boss cluster for the 14 base?
#989
AJPTurbo swapped a '13 Boss cluster into a '14 premium. I am guessing the ABS module would be the only potential issue regarding track apps with that swap, but if you have Brembo brakes, you will have the same ABS module as the Boss. It should be pretty straight forward. I would listen to what dhines, Jim and Zero have to say. Once I complete the Base to Track Apps swap, I will document any glitches and exactly what was involved.
#990
There is only one ABS module listed for 2013+ cars so you should be good for Track Apps. Ford lowered the price of it significantly too ... Tousley has it for only $94 now .. thats like half of what it was a few months ago. I paid $150 for my used one.
#991
#995
No .. but this will .... I thought I had my iTsx sold and was gonna order the 2013 ECM .. but guy never called me back ..
![](http://thumbs4.ebaystatic.com/d/l225/m/m-VmhOZNDKEEHwgWtpwwd2A.jpg)
Would this fix the cruise issue and digital gauges issue?
http://m.ebay.com/itm/330888540512?nav=SEARCH
#997
AJPTurbo, I don't think the Boss cluster has the "halo" in the cluster itself. I will check this afternoon, but it could be that physically these units wont allow my color if they are built differently. Will be interesting if you could program the cluster to do some of the my color changes by changing the led colors of back lighting. I personally could care less about my color options as everything in the car we have is the same blue/green tone.
#998
#999
You could be correct. But when I was loading my tune or doing the PMI on the cluster I could see some of the speedo numbers changing from green and blue and it looks like there is a ring that could change color...I think it's a firmware in the cluster....That would make sense for the DTC I was getting saying the cluster is getting info from the PCM/ECU that is doesn't recognize. But I had my as built in the cluster so I don't know.
Maybe zero will know more about it....He may be my last hope lol
#1000
AJPTurbo, the Boss Cluster DOES have the halo. It IS programming. It is physically there. I am looking at it in my cluster. Zero......this is your mission should you choose to accept it........
