'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old 2/13/14, 09:15 PM
  #801
Deerslayer's Avatar
When you pull them, you need to have the orientation of the needle perfect. When you replace them you don't put them all the way on in case you need tweak it slightly to get the orientation perfect. Power on, check orientation, make any adjustments and if there are none, you press them completely on. Like everything else, takes a little patience.
Old 2/13/14, 10:12 PM
  #802
jim010's Avatar
Patience is pretty key. Took me awhile to get my needles right when I switched out my faces.
Old 2/17/14, 08:40 PM
  #803
dmhines's Avatar
DHL is pissing me off ... Still on hold from SNOW in GA last week!!! I want my VCM.
http://www.dhl.com/content/g0/en/exp...00259912%0D%0A
Old 2/17/14, 08:50 PM
  #804
zeroaviation's Avatar
No doubt! DHL sucks.
I'm eager for you get yours. I'm really hoping it has a J2534 interface like the Genuine Rotunda Does.
-Matt
Old 2/17/14, 09:18 PM
  #805
ajpturbo's Avatar
-Matt
What is the J2534 interface? How will I know if I have it?
Old 2/18/14, 08:57 AM
  #806
When you install IDS it installs a J2534 Driver for the VCM. You can use the J2534-1 Bus Analysis Tool from Drewtech to test this driver (and ultimately the VCM) for this capability. Once Dan or you receive the VCM let me know, and I can walk you through setting up/testing this.
If it does indeed work, this opens up a good door for remote debugging.
-Matt
Old 2/18/14, 09:03 AM
  #807
dmhines's Avatar
My VCM is OUT FOR DELIVERY ... will have it this evening.
Old 2/18/14, 09:04 AM
  #808
w00t!!
Old 2/18/14, 09:06 AM
  #809
dmhines's Avatar
First thing I'm gonna do is see what the DTC's are on the ABS module.
Old 2/18/14, 09:40 AM
  #810
Excellent! Let us know what the network test returns as well.
Old 2/18/14, 07:31 PM
  #811
dmhines's Avatar
VCM II arrived. Looks good. IDS connectivity to VCM works with VMWare on my Mac Laptop so thats good. Problem though --- the VCM is configured with IDS V86 and I currently have V85 installed. Need to upgrade to V86 before I can do anything .... ugh .....
Old 2/18/14, 07:48 PM
  #812
dmhines's Avatar
Also ... the J2534-1 Bus Analysis Tool program does not recognize the device.
Old 2/18/14, 08:06 PM
  #813
Dammit.... What part does not work? Does the Bosch connector show up in the list?
Also, have you tried rolling the VCM software back?
-Matt
Old 2/18/14, 08:10 PM
  #814
dmhines's Avatar
-Matt
I'm scared to roll it back! Don't need a nice red brick.
I load the DLL for Bosch/VCM. I then OPEN under device. It sees the VCM but has an error that says something like Update PC software ... it does see a serial number on the VCM.
Old 2/18/14, 08:20 PM
  #815
Interesting... Maybe the V86 version will allow you to use it.
It would be a great resource if we could get that to work as well.
-Matt
Old 2/18/14, 09:54 PM
  #816
Deerslayer's Avatar
There is a '13 GT500 Track Apps Cluster on bay now...
http://www.ebay.com/itm/2013-MUSTANG-GT-500-SHELBY-INSTRUMENT-CLUSTER-SPEEDO-/251454973227?pt=Motors_Car_Truck_Parts_Accessories&hash=item3a8be2652b&vxp=mtr
Old 2/18/14, 10:20 PM
  #817
ajpturbo's Avatar
Looks like a knock off....Redline is too high and the font doesn't look right...And if it's like new is should be at least4-500 bucks...That's about an 800 dollar cluster with no core
Old 2/18/14, 10:22 PM
  #818
dmhines's Avatar
Success with the VCM ... installed V86 software (thanks ajpturbo). Was able to key in AS-BUILT for my ABS module and read DTC's. After resetting all DTC's the only one stuck was for ABS: code U201A. Invalid/Incomaptible software component.
Old 2/18/14, 11:07 PM
  #819
dmhines's Avatar
SUCCESS!!!! ABS working, Track Apps working and no DTC's !!!
Here is what I did in a nutshell ....
I did a Module PMI for the ABS module. When IDS showed my VIN and asked if correct I replied no. I manually keyed in a 2013 car VIN .. same one I used for my AS-BUILT for the cluster install.
IDS then asked if I had the original module. I said NO. IDS then downloaded the calibration file from the internet. IDS flashed the ABS module and that was that.
IDS did give me a warning that the VIN in my PCM was incorrect ... but that was because I had manually typed in a different VIN for the ABS module.
Took car for a quick test drive and Track Apps is all working and NO DTC's!!
Got my moneys worth out of the VCM II already!
Old 2/18/14, 11:50 PM
  #820
Mr. V's Avatar
Congrats!!!!! I've read about all the work you and the small group of people brave enough to try this mod. I am very happy that all the hard work had paid off.
Quick Reply: '13-14 Cluster into '10-12 car (with TrackApps) retrofit
