Trackey for manual 2014 GT's manufactured after 7/1/2013
#301
it would be nice for the update to allow for a default lopey idle off. it seems like it uses a little more gas and dont want to manually turn it off every morning when i use the car for commuting.
for us trackcal guys, an option on the tool to select which way we would like the idle to default would be great, because we cant switch between tunes as easy as the key people.
#302
#303
it would be nice for the update to allow for a default lopey idle off. it seems like it uses a little more gas and dont want to manually turn it off every morning when i use the car for commuting. for us trackcal guys, an option on the tool to select which way we would like the idle to default would be great, because we cant switch between tunes as easy as the key people.
#304
How will people receive the update? I ask because I have the procal with the performance tune. I was told we cant get the new trackcal tune without buying yet another Procal tuner.
#305
I imagine that a new memory card sent out in this case wouldn't cause the same issue. Yes, it will overwrite the original track cal thus making it gone forever. But being that the new one is an improved version and not one the is somewhat different, this won't matter. No one will want to go back to the original track cal with the cel vs people that may want to go back to the performance cal.
#306
Yes but this is only because if you were to take your current procal and load only the track cal memory card into it, you would then permanently lose the performance cal. The track cal would overwrite it on the unit and the original memory card from the performance cal would be blank.
Makes sense however, if I understand it correctly the new Trackcal is essentially the performance cal or even an improved version of it, with the addition of launch control etc. Why would someone want to go back from it? I asked them if they could send the tune itself and was told "No you have to buy another Procal tuner" that's ridiculous in my opinion.
#307
There is discussion to add a part number so customers like yourself can upgrade over the kit you have now. I dont have a time frame on when that may be available but it is moving in the right direction.
People that have Tracal will have to load the stock tune back into their car with the original SD and then load the new tune in with the SD that will be sent out.
#308
Will we have to pay the dealer another Hour+ shop time?
Thanks,
-Bill
#310
Just curious. If the customer is being trusted to load the new tune through the procal or get a new key somehow without going to the dealer again. Why do we have to pay the additional $100+ at the dealer in the first place to load the tune (I do understand that the key is a bit different, but clearly you guys have a way to do it without dealers)? I was under the impression that a dealer had to do it to ensure it was done correctly for in the event the warranty was needed (on a side note I never understood this. It's not like suspension that we could destroy and then want warrantied. It's a tune. You load it and done. Nothing we can mess up.). But if FRPP is allowing essentially the whole process to be done without dealers, it's seems like this is an unnecessary step and cost. Could someone not mess up the install on this new card sent equally as if it was the very first time? Why assume liability now?
#312
Just curious. If the customer is being trusted to load the new tune through the procal or get a new key somehow without going to the dealer again. Why do we have to pay the additional $100+ in the first place to load the tune? I was under the impression that a dealer had to do it to ensure it was done correctly for in the event the warranty was needed (on a side not I never understood this. It's not like suspension that we could destroy and then want warrantied. It's a tune. You load it and done. Nothing we can mess up.). But if FRPP is allowing essentially the whole process to be done without dealers, it's seems like this is an unnecessary step and cost.
The key was already activated by the dealer so all that needs to change is the calibration.
Because of the issues with the calibration we do not want the customer to accumulate more costs. That is why we will allow these cars to be fixed by you, the customer.
All of these customers should have already called 800-367-3788 to register for the Ford Warranty so there will not be any problems.
If anyone has not called to register for Warranty please do so now. You will need a copy of the invoice from purchasing the kit and the RO from the Ford Dealer.
800-367-3788
#313
Ray! Mike! Please talk somebody into making this happen!
Last edited by JJZ109; 7/10/14 at 05:13 PM. Reason: Restored original post as it was when answered.
#316
For those of you who have not registered for warranty, don't know if your dealer registered you for warranty, etc., please e-mail me a copy of the repair (work) order as well as a copy of the receipt of where you purchased your Trackey or Track Cal and I'll make sure you guys are all set.
My e-mail address is mrobi258@ford.com
Hope everyone has a great weekend!
-Mike
-Mike
#317
Thanks for all the info Ray. I will also spread the info to the other forums as mentioned prior.
One thing I must say regarding new and revised part #'s... As an aftermarket installer I've come across issues with new part #'s causing problems with CARB EO #'s, especially in CA. For example our shop installed an LS3 EROD engine on a pollution controlled vehicle, and it turns out that the EO # had been updated to the "new" EROD part # which we did not have, since we bought an "early" production. General Motors actually had us re-serialize the engine block to the revised part # so the thing would pass the visual inspection with the referee.
If a new part # is released for the update and that part # supersedes the original, a new EO decal might be required.
May not be an issue in this case but I thought I would offer the information from our EROD debacle.
#319
800-367-3788
800-367-3788
How did you know I forgot to send in for the warranty confirmation
My dealer will not be happy to see my car again but at least they know how to do it and this time should be quick. Five hours the first time. I may need to throw a pizza party for the service department at my dealer.
Tod
#320
Sorry if this is a dumb question but, if I was to purchase a cold air intake and Boss 302 intake manifold and then get the track key installed. Would the tune be ok with those modds, or does my car need to remain stock with the track key tune?
