Eduardo's 94 Mustang GT thread
Old Dec 22, 2014 | 01:54 PM
  #521
edumspeed's Avatar
Legacy TMS Member Pr
Clean and with a nice coat of paint
Still need 99-04 brake pads. A pitty that the 94 spec ones are like new
Old Dec 22, 2014 | 01:56 PM
  #522
Nice. Always easier when they're off the car!
Old Dec 22, 2014 | 01:59 PM
  #523
edumspeed's Avatar
Found a pic on an article about the swap on where the spindle needs to be grinded for the calipers to fit. Red line where there's interference and blue line the material to be cut.
Old Dec 22, 2014 | 02:00 PM
  #524
edumspeed's Avatar
Ya. Too bad the rears are still in the car lol.
Old Aug 27, 2015 | 10:40 PM
  #525
edumspeed's Avatar
update
Ordered a head gasket set because most probably one of the head gaskets was incorrectly installed and is causing the weird symptoms the motor has. And also I scored this:
Old Aug 29, 2015 | 12:27 PM
  #526
nice score!
Old Aug 31, 2015 | 02:20 PM
  #527
edumspeed's Avatar
nice score!
Yeah. I couldn't believe myself. Asking price was $80 and I made a $50 offer for kicks and the guy accepted it
Old Aug 31, 2015 | 02:22 PM
  #528
edumspeed's Avatar
Gaskets and arp ultra torque lube arrived today. Teardown begins tomorrow
Old Sep 1, 2015 | 03:02 PM
  #529
edumspeed's Avatar
I made some good progress today. Just need to remove the headers and valve covers to unbolt the heads off the block. Then the long proces of cleaning the mating surfaces an re-assemble everything back.
Old Sep 1, 2015 | 03:13 PM
  #530
edumspeed's Avatar
side note:
Driver's side caliper is bad. Wheel gets locked
Old Sep 2, 2015 | 09:46 AM
  #531
edumspeed's Avatar
Driver's side head is out.
Old Sep 2, 2015 | 09:57 AM
  #532
edumspeed's Avatar
This is a rough idea of how I want the car to look in the long run.
Old Sep 2, 2015 | 12:36 PM
  #533
edumspeed's Avatar
Found the cause of the cooling & pinging issues
Old Sep 4, 2015 | 05:10 PM
  #534
edumspeed's Avatar
Cylinder heads and rockers are installed. I also got rid of the thermactor tubes that were doing nothing. I just cut the metal tubes from the junctions on the heads and flipped them. And for sealing them, i used a section from the discarded head gaskets
It's a shame I'm broke atm so I couldn't replace them with roller rockers
Old Sep 8, 2015 | 06:29 PM
  #535
Jim74656's Avatar
is that a garret turbo??? would love to see the numbers on it!
Old Sep 26, 2015 | 10:22 PM
  #536
edumspeed's Avatar
Seller never shipped it. I oppened a case and was given a refund.
Old Sep 26, 2015 | 10:27 PM
  #537
edumspeed's Avatar
Update
Fired up the engine. There's white smoke and an oily residue from the passenger side exhaust (where the gasket was installed incorrectly) and isn't idling right. Pretty frustrated right now.
And the shift kit arrived today.
Old Oct 12, 2015 | 08:17 AM
  #538
edumspeed's Avatar
I went at the car again and figured out the unsteady idle it had. The vacum hose junction below the alternator was unhooked and the egr and fpr hoses were mixed up. Now it purrs like a big kitten lol. The oil getting off the passenger tailpipe is still an issue, but since I put 5w30 oil in the crankcase and the piston rings must have suffered a bit for the head gasket issue must be going past them. I'll just put 20w50 oil as it had that on the begining.
Old Oct 13, 2015 | 12:01 PM
  #539
Knight's Avatar
Needs to be more Astony
Sweet.
Old Oct 20, 2015 | 08:08 AM
  #540
Chad@Amp'D's Avatar
Former Vendor
Nice
