Cpotts's 2kgt Build Thread
Old May 4, 2012 | 09:56 PM
  #61
1999Pony's Avatar
Originally Posted by cpotts13
Yes that's the plan. Fortunately my mom is letting me share her car for the time being. Unfortunately my car will be parked for the next month or so while I try to work my butt off to save up the $$$.
When mine went bad, or so I thought, I was in the same position. I didn't want it to lock up and end up in a wall. You can find replacements out there for right around 300, you just need to be patient. Mine was down for a couple months before I found anything. Hopefully you get yours done quicker then I did though.
Old May 5, 2012 | 06:59 AM
  #62
cpotts13's Avatar
Hopefully. I am kind of weary to buy a used axle, it could have the same problem.. haha you never know.
Old May 5, 2012 | 07:16 AM
  #63
1999Pony's Avatar
Its always possible. But then again, so could a new one. The 2 I've bought, the replacement 7.5 and the 8.8 in the car now, were both used.
Old May 5, 2012 | 07:19 AM
  #64
cpotts13's Avatar
It wouldn't be to much trouble to open it up and check the bearings and backlash.. But heres my question, if you have the replacement axle, is it just a drop in affair?
Old May 5, 2012 | 07:23 AM
  #65
1999Pony's Avatar
Yep. Drop one out, put the other right back in. Should only take a couple hours to do.
Old May 5, 2012 | 07:24 AM
  #66
cpotts13's Avatar
Alright, it shouldn't be too bad, I just had the axle off, aside for uca and driveshaft to install the lcas
Old May 5, 2012 | 07:32 AM
  #67
cpotts13's Avatar
Is there a difference between a 98 axle and a 99-04?
Old May 5, 2012 | 07:36 AM
  #68
1999Pony's Avatar
Yea its a little shorter, I think 3in. You can use it, but the tires will be tucked a little more.
Old May 5, 2012 | 09:31 AM
  #69
cpotts13's Avatar
Noo, If it has to be done, its going to be done right! Lol
Old May 5, 2012 | 09:38 AM
  #70
1999Pony's Avatar
Old May 5, 2012 | 09:42 AM
  #71
cpotts13's Avatar
Made a bit of money mowing a few lawns this am, and have a few cars to wash tomorrow, and picked up a couple of shifts at work. well on my way!
Old May 5, 2012 | 06:55 PM
  #72
cntchds's Avatar
Good to hear it. Really rough having your car down, but if I were you I would look into an IRS while you have it out anyway. Most Cobras have a lot less miles than GT's. Mine only had 10k miles on it.
Old May 5, 2012 | 06:56 PM
  #73
cpotts13's Avatar
I would love that, but probably wouldn't be able to do it cheaply.. keep on mind, I'm working on a high school budget.
Old May 6, 2012 | 12:13 AM
  #74
cntchds's Avatar
I just figure if you're looking at 800 bucks to fix your diff, that's about what an IRS costs, and if you are comfortable pulling out a straight axle installing an IRS is a synch.
Old May 6, 2012 | 06:58 AM
  #75
cpotts13's Avatar
Like I said, ill keep my eyes out, but is it literally bolt in?
Old May 6, 2012 | 01:33 PM
  #76
cntchds's Avatar
Yup. Only things that you need are a 99 or 01 IRS, shocks, springs, abs sensors, and exhaust.
Old May 6, 2012 | 02:08 PM
  #77
cpotts13's Avatar
This would seriously be an awesome upgrade, but they don't cone up for sale often. And I read somewhere you would need a new driveshaft?
Old May 6, 2012 | 03:31 PM
  #78
cntchds's Avatar
If you get a 99 or 01 it has the same flange and bolts up. If you get an 03/04 it has a different flange and can be replaced for 30 bucks. I'm done tempting you though.
Old May 6, 2012 | 04:33 PM
  #79
cpotts13's Avatar
Hahaha, I'm keeping my eyes out for either a live axle or IRS.. there's alot of 98 model years axles for sale, with 373 gears already..
Old May 6, 2012 | 05:19 PM
  #80
cpotts13's Avatar
I did a bit of research, although a cobra irs swap would be ideal, i already have alot invested in the sra (catback, lcas, shocks and springs) and with new gears and fresh bearings it would pretty much finish up the rear end.
