retrofit a 2013/14 cluster
Old 7/14/14, 02:19 PM
  #81
LEXiiON's Avatar
Jim,
i am not sure, if you also need to swap the passenger side module. Try disconnecting that one and see if the reading is more accurate, once you installed the 2010 fuel pump.
Alex
Old 7/14/14, 02:30 PM
  #82
jim010's Avatar
One BIG problem I'm going to have is that IDS can't communicate with the 13 cluster while it is in the 05 car.
Maybe I can swap it into my 12 and program it there and then put it back into the 05?
Old 7/14/14, 02:32 PM
  #83
LEXiiON's Avatar
That's the best way to do it. I had the same issue when i put the 2013 ABS module in. IDS couldn't communicate with it, so i needed to go in with a 2011+ PCM code.
Alex
Old 7/14/14, 02:42 PM
  #84
jim010's Avatar
Since the car doesn't need to be running, I don't have to mess with PATS, so it should be OK.
Old 7/14/14, 02:47 PM
  #85
jim010's Avatar
Originally Posted by dmhines
Not sure if this helps but I installed a GT500 Fuel pump in my 2010 GT. FRPP released a specific 2010 Fuel Pump kit even though the 2005-2009 GT500 kit was identical. The difference was Ford reversed the resistance readings on the sending unit starting in 2010 so a 2010+ specific sending unit was required for the fuel guage to function properly.
Well, I bought Lex's pump, so we'll see if you are right. Makes sense to me, but I am still befuddled as to why 11-14 pumps aren't recognized as my 13 cluster reads my fuel levels in my 12. And these clusters do read 13-14 fuel pump signals
Old 7/14/14, 02:53 PM
  #86
LEXiiON's Avatar
The sending unit is the same, but the pump is different
More clearer:
The 05-10 have the same pump
The 11+ have a different pump
The 05-09 have a different sending unit than the 2010-2014.
2010-2014 have the same sending unit.
Questions?
Old 7/21/14, 03:39 PM
  #87
jim010's Avatar
Going away for a few weeks. Not going to be able to do much on this until then.
Doesn't seem to be much interest in this, though. I would have thought there would be many wanting to do this mod?
Old 7/21/14, 10:09 PM
  #88
Boomer's Avatar
I'm following, but I think the work looks a bit complicated for my technical abilities.
Old 7/22/14, 08:15 AM
  #89
Just Plain Rude!
stupidgenius36's Avatar
I'm interested as well. I'm sure there's plenty of interest, but this is beyond the skill level of most. I don't have the time or space to tinker these days, but I'd be willing to give it a shot if y'all are able to work out all the kinks.
Old 7/22/14, 08:55 AM
  #90
Boomer's Avatar
If there was a final solution and someone said "Here's what you need kit"
If the price was right, well...maybe....maybe
But reading this, you guys are WAY above my talent and dedication level. A lot of people appreciate it, myself included!
Old 7/22/14, 09:29 AM
  #91
jim010's Avatar
Zeroaviation will be offering the black box through Redliners Performance just as he offers the black box for 10 - 12 Mustang owners. It should be fairly straight forward, but will take some time to get it all sorted out. I'm hoping by the fall.
Old 7/22/14, 12:04 PM
  #92
friedmaster's Avatar
I'd echo those comments. Heck, if somebody could build a plug/play harness to do this, I'd happily pay.
Old 7/22/14, 04:49 PM
  #93
zeroaviation's Avatar
I'm working on it... Got a local guy with a 06 that I can use to grab data from. Jim010 sent me a 05 cluster, and I already have a 10 cluster. So now is just connecting the pieces..
Cheers,
-Matt
Old 7/22/14, 04:58 PM
  #94
jim010's Avatar
Doesn't the 10 use different data than the 11-14?
If so, I can send you a 12 cluster.
Old 7/22/14, 05:52 PM
  #95
LEXiiON's Avatar
The 10 cluster is pretty similar to a 2011+... Except for gauges TrackApps etc... Same thing.
Remember Jim, the 2010 is a 2011+ except for the drivetrain. All body modules are the same.
LEXiiON
Old 7/22/14, 05:57 PM
  #96
LEXiiON's Avatar
LEXiiON
Other words: the cluster is plug and play between 2010-2014. Exceptions are gauges and TrackApps due to the different PCM.
LEXiiON
Old 7/24/14, 08:55 PM
  #97
jim010's Avatar
The fuel pump arrived today. I'll be fitting it when I get back.
Matt, which pigtail do you need - 05-09 or 10-14? I haven't located a 05-09 one yet. Wreckers are not willing to cut up harnesses. I am in contact with TE Connectivity to see if I can get one.
Old 7/24/14, 08:56 PM
  #98
jim010's Avatar
Alex, any luck with stampings on the 10-14 connector?
Old 7/24/14, 09:14 PM
  #99
05-09 is preferred. Let me know what TE Connectivity says.
Old 7/24/14, 09:16 PM
  #100
LEXiiON's Avatar
Looking right now
Quick Reply: retrofit a 2013/14 cluster
