FRPP Hot Rod Cams installed - Idle is now surging/bouncing - Any ideas?
Old Jun 6, 2008 | 04:40 PM
  #61
mustangdaren's Avatar
Does anyone know if these cams will work on automatic mustangs without a torque converter change? I am seriously thinking of selling my 89 coupe and getting cams and procharger for my 07GT. Just wish I would have bought a manual instead of an automatic.
Old Jun 6, 2008 | 04:43 PM
  #62
tribaltek's Avatar
I've never owned an automatic car, so I don't have a definite answer for you... but I would assume it would be a good thing to do.
Old Jun 6, 2008 | 05:59 PM
  #63
70MACH1OWNER's Avatar
All I can say is you need a tune from Brent at Brenspeed! It is like a really big improvement over any thing you have been used too!! And "YES" cams work on these cars!!! Read my Sig!!!
Scott
Old Jun 6, 2008 | 06:32 PM
  #64
SONICBOOST's Avatar
I would love to hear what it sounds like reved up a bit!
Old Jun 6, 2008 | 09:20 PM
  #65
azoufan's Avatar
I hate you guys.
  #66
SlamMan02's Avatar
Originally Posted by IowaBeef
AHH! It was a lot easier to turn down the offer when they were over $1100 but come to find out they are ONLY $780 (Plus a tune, Im assuming)
Hey Matt,
Here is what I payed for the Comp NRS cams from Brenspeed in Jan. And the install price was an additional $280.00. Just for reference. I guess the price didn't come thru. They are $645 shipped.
Scott
Wow! And you said you gained roughly 20rwhp through the curve? How did the idle/lope change?
Old Jun 6, 2008 | 09:32 PM
  #67
tribaltek's Avatar
No sir. Brent told me Brenspeed "didn't support" the cam, so they will not install it or tune for it. Your only email tune choice right now is Bama, who has been kicking *** on getting the tune down for us.
Old Jun 6, 2008 | 09:56 PM
  #68
SlamMan02's Avatar
Brenspeed not supporting the Cam means what...
They don't feel its safe to run with stock Valve Springs?
Old Jun 7, 2008 | 04:29 AM
  #69
Matt,
I got closer to 25 at the wheels. My idle/lope is definitely more aggressive than the stock cams. You can tell it has cams. But it is not as aggressive as the Hot Rod cams.
I can understand that I guess. I understand Brenspeed worked directly with Comp Cams to develope the NSR cams. I can see that might be a comflict of interest issue.
Not at all Matt. He just supports and installs Comp cams. Both the Comp cams and Hot rod cams only have 1 mm more total lift than the stock cams. They are both safe on the stock springs.
Old Jun 7, 2008 | 06:00 AM
  #70
Mustang Sherry's Avatar
Cams sound awsome!!
You said you were near Detroit. I am somewhat near there also, Howell. Reason I ask is that I saw a car like yours in Howell when we were cruzing one night. Also was wondering who you used as your install. I have used hines Park Ford for our cold air intake and exhaust instal, only because theres not to many FRPP places around. I WILL HAVE THOSE CAMS SOON!!!! Oh and by the way GO WINGS!!!!! Aint no party like a Detroit party!!!
Old Jun 7, 2008 | 06:07 AM
  #71
EastCoast07GtCs's Avatar
I hear you Matt. It's a bit of a drive for me, so I have to factor in travel costs (minus the gracious breakfast offer ), but at this price and with those results it is so difficult to stay away!!!!!
Old Jun 7, 2008 | 07:36 AM
  #72
tribaltek's Avatar
I'm downriver - in Taylor, to be specific. I work in Ann Arbor though, so I had Varsity Ford do the install. They work on more race applications than typical dealerships, and it was the best quote I got after contacting 10 shops.
If you want these cams you better get your order in and get on the wait list. They're very scarce.
Wings should have won it at home, but screw it, we're the friggin' champs
And there is no party like a Detroit party, cause a Detroit party don't stop!
Old Jun 7, 2008 | 10:14 AM
  #73
SlamMan02's Avatar
Matt,
Roger that! I definitely want to look into a set, especially after I see the power numbers on the HR Cams.
Scott, Any idea how the Comp NSR cams respond to boost?
I hear you!
Old Jun 7, 2008 | 10:50 AM
  #74
I hear you!
They should work just great. Remember all they are doing is helping the engine breath better. Letting more air and fuel in the cylinders. Ben (EleanorDreaming) had the Comp NRS cams installed the same day as I did. He is running a 100 horse shot of nitrous and his car did like 390 at the wheels. His car pulls hard.
http://s138.photobucket.com/albums/q...0horseshot.flv
Old Jun 7, 2008 | 11:00 AM
  #75
SlamMan02's Avatar
Right On!
Do you have a before/after Dyno chart showing the results through the curve?
Old Jun 7, 2008 | 11:20 AM
  #76
Right On!
I don't have a before and after dyno pull of just the cams. But I gained 37hp and 17 lbs peak to peak and 41 hp 0 torque at 6000 with cams, obx longtubes and delete plates. You can see it here. http://forums.bradbarnett.net/showthread.php?t=463971
See post #30 for the dyno sheet made last Oct before cams,headers and plates and the dyno pull made in Feb. after cam install.
What is interesting about these aftermarket cams is they really only boost hp and not the torque values. The stock cams are producing the max amount of torque these little engines make N/A anyway.
Old Jun 7, 2008 | 12:13 PM
  #77
tom281's Avatar
Just to mention, if you're wondering about cams that work well with blowers, call Brent or Dave at Brenspeed- they have their version of the Comp Cams NSR cams but modified slightly to better benefit blowers. They work well with blowers to help accentuate lower end torque too, but especially top end HP.
Old Jun 7, 2008 | 12:18 PM
  #78
06GT4RAD's Avatar
Does anyone know if the HOT Rod cams with the proper tune can be a Emissions Friendly Cam?
I know Doug can give Emissions friendly tunes normally but does anyone know if that can be done with these cams?
Old Jun 7, 2008 | 12:58 PM
  #79
Five Oh Brian's Avatar
I was considering staying N/A and going with one of the NSR cams, or getting a supercharger. I inquired with Brenspeed about their thoughts and they responded that the Comp Cam NSR kit (that I was considering at the time) would work very well with the Vortech centrifugal blower.
I've had the blower installed, but am still wondering about doing the NSR cams (either Comp or FRPP).
Old Jun 7, 2008 | 07:13 PM
  #80
Well if I could get the same power out of the FRPP hot cams as I did with the Comp NRS cams and get that lopey idle I would do the Hot cams. But I still have not seen an independant dyno test yet. I love their sound but still not convinced they make the same power.
Scott
