Cool Tech Roll Bar - Sneak Peek
#202
#203
Originally Posted by boss man
Wow, I'm jealous
Definitely! I should be in the NJ area for at least 1 track event this year.
Wednesday and Thursday look like in the high 50's. Depending on work, I'm shooting for one of those days!!
#204
Started on the roll bar install today. I got the front brackets bolted down and the side panels cut/notched. The hardest part was removing the original gussets/braces. The seam sealer really had them stuck down! Cutting the panels was fairly easy. Worked for about 3 hours taking my time. Hopefully get the rest of the bar installed in a few days.
![](http://desmond.imageshack.us/Himg337/scaled.php?server=337&filename=1012495.jpg&res=medium)
![](http://desmond.imageshack.us/Himg9/scaled.php?server=9&filename=1012496.jpg&res=medium)
#207
I'm guessing your bar was the Comp. Orange bar. Great choice in color. Those bars are a work of art and they should stand out. I would love to see all bosses bars power coated in the body color. IMO having it done in black, it gets lost on the inside. Cool Tech. builds the best.....Keep us all posted
#209
1 Post
No offense to Kendall and I appreciate his development efforts to bring new products to market, but what exactly are you basing this statment on? Do you have his bar or do you have someone elses to compare it to? Just curious.
#211
No template is included. The instructions are detailed with lots of measurements to make the cut. It woud be easy though to include a template. Maybe Kendall coud do this?
#212
Most people put a bar in for safety to be used along with a race seat and harness system, not its artistic value.
This implies a person is installing their bar to show it off at a cruise-in?
As for installing a bar to show it off at a cruise-in, Whats wrong with that? If you like the look and can afford it then go for it. How you choose to enjoy YOUR Boss is clearly up to the owner.
No I do not have a Bar as of yet (Family Frist). When I save my coins, Kendall's bar is for me unless something better comes along, which I dont see happening. I base my views on what I read and see in researching a product. I visit the strip about 2 times a year and it's his bar that I will install. And when I'm at the cruise-in and people ask about the bar, I'll be happy to tell them it's from cool tech.
#213
#214
I plan on having one of these bars someday along with the belts. Other priorities at the moment tho.
And yes, my car will mostly be a garage queen with a few autocross and track days. Love the looks and like someone else said, if I can afford it and like it, why not. It's my car.
No offense intended........
#215
First Test of Roll Bar
Well, I got my Laguna Seca back from Kendall's Saturday and the roll bar looks better in than it does in pictures. The fitment is outstanding. It looks like at was included from the factory where other roll bars I have seen look more aftermarket for lack of a better term.
I promptly took it out and tested it on Sunday... well not the roll over part, just out at the track. I do not have quantitative data, but subjective seat of the pants was amazing. The car seems to have really benefited from this extra structure. The car does not seem to body roll as much and seems razor sharp in transitions and turn in. The car was hooking up better out of turns and I do not seem to be getting as much inside wheel lift out of hard turns.. I am convinced this was not just the day or my imagination. I did not need to have the rear supension set as stiff as before the roll bar.
In any case, I am truly happy and am only waiting to get the harness so I can stay in my seat better...![Wink](https://themustangsource.com/forums/images/smilies/wink.gif)
Thanks Kendall!
Thanks Kendall!
#216
Actually, primarily a safety device but there is functionality - and aesthetics are in the eye of the beholder. For me,it is the functionality of this system that makes it so good. I did compare this to other bars and found this system uses the best combination of quality, fit, and function. With other non racing cages, many tie their cross braces into sheet metal panels, Cooltech has it tied to the shock mounts and floor braces. Many racing cages also tie into shock mounts, but have front bars which would certainly be safer for track, but potentially deadly in the street use application. Most roll hoops, or even bars I have seen in the mustang restrict seat travel, I find that there is no issue with seat movement with this bar. Kendall's bars accommodate the stock seat belt and actually improve their access.
It is an extremely well thought out system that works for safety, function, and therefore the bling factor is icing on the cake. Is it the best for all applications? No. But I feel it is the best for what most of us are using our cars for and that is why I bought mine.
(A little information on Kendall: He is in real life, an engineer at a high end aerospace company and he basically designs the software used for creating aircraft, he can't help himself about paying attention to the little details...)
#217
Well I remember when Billy Crystal would imitate Ricardo Montalban and say "Darling it's better to look good than to feel good and Darling you look marvelous "
When I go to a cruise in I know my Cool Tech bar will simply LOOK MARVELOUS !
Rob
Rob
#218
I want my car to look good at a cruise in (it does with our without the roll bar) & I want the added protection on the track. & soon it will
