401a interior - is this "normal"
#101
Man, my car has under 10K on it and my Driver's side recaro is starting to do this, too. I don't see this seat lasting 30K miles without the leather cracking at this point. My car is parked in a garage night and day and get's the best leather care system around and it hasn't prevented what I've seen here.
#102
I spoke with the dealer today - they said the engineer did a great job on the seat and prescribed the XL-18 friction modifier for my transmission. The a/c compressor problem was not reproduced - not too surprising considering its in the 50's up here in NE. I'm out of town for work, so I can't pick up the car until Saturday, but the dealer said they are keeping it in the garage until I return. I truly hope that everything is fixed - this has been a huge black eye on what could (and should) have been a truly great car.
#103
Thanks for asking. I've been reluctant to keep posting since I have nothing nice to say.
They stretched the leather taut, so far so good. The problem is they did this by adding a bunch of extra padding and modifying the springs (according to the work order). The seat is so overstuffed that I'm sitting about an inch and a half higher than before - I can't get the seat low enough for a proper seating position. The work order also said that they took apart and "adjusted" the seat back... not sure what that means or why it was necessary, but the seat does not feel the way it did stock (it used to be very comfortable, now its back pain city).
With the way the leather is bulging and overstuffed, I have not faith in it holding up. The materials and construction are garbage.
On top of that, they scratched up my door sill and surrounding area. Gee, thanks and lot Ford. The bolts look nearly stripped too.
#104
D@mn it to hell. That is very disappointing. How hard is it for them to simply use a stock foam bottom seat bolster and new 401a bottom seat cover?!! There should not be any stuffing, adjusting, trimming, modding, stripping bolts... why?
#107
Wow - I'm sorry to hear of your nightmare with Ford. I just got the OK to grab a new work truck; Dodge or Ford. This type of manufacturer and dealer headache is pushing me towards the Ram.
#108
#109
I feel bad for all the trouble you are having. To all those asking why ford dosent just replace the seat, its because they dont sell them. All the parts are seperate. you have to keep in mind that these are most likely manufactured in Mexico and that when you are dealing with materials such as this, and dealing with assembled by hand materials, there will be some variance, and what is "commercially acceptable" will be just fine for 99% of the popluation, but for us mustang owners, we can be more particular. Based on the first picture, I would agree that that is defective. The replacements are not as smooth as the original, but they are not "defective", its just different. As you stated you have concerns with the seat being taken apart a few times, and that is warranted. Is taking it to another dealer an option? or having them sublet the work to a professional?? What about getting a new cover in and giving you the option of looking at it before it is opened and installed? If it was me, and It drove me crazy, I would probably fix it on my own dime. Otherwise this cycle is going to continue where you get a new cover in that may or may not be perfect, and then you are having the seat taken apart again and put together by a flat rate technician getting paid warranty time (probably getting paid for less than the time it actually takes to do). I would find a reputable high end upholstry shop, show him your photos and your expectations, and get his opinion on the quality of the ford material and see what he thinks he can do with either a new ford cover that you bring to him to install, or salvage this new cover. last resort would be if he can make a custom one with better materials and workmanship. otherwise, you may never be happy with it. last option is to just roll with it.
#110
Exactly. Tell them to supply you with new lower foam and seat cover and take it to a pro shop.
Be sure to stick Ford with the bill.
Too bad you don't live in Indiana, I know a d@mn good shop of 35 years.
#111
#112
