'13-14 Cluster into '10-12 car (with TrackApps) retrofit
Old Dec 18, 2015 | 09:21 AM
  #2221
LEXiiON's Avatar
Originally Posted by DeeJayTJ
Thank you VERY much!
You wouldnt have a pinout diagram for Connector C4368B would you?
I've only got a pinout diagram for C4368A :-/
here we go
LEXiiON
Attached Thumbnails '13-14 Cluster into '10-12 car (with TrackApps) retrofit-4368b.jpg
Old Dec 18, 2015 | 09:53 AM
  #2222
DeeJayTJ's Avatar
Originally Posted by LEXiiON
here we go
LEXiiON
wow awesome LOL THANK YOU! I'll stop hijacking this thread now. Thanks again!
Old Jan 6, 2016 | 08:04 PM
  #2223
RusWolf's Avatar
Hello all!
Found this thread on this forum and made an account. I'm an active member on SVTP with the same screen name.
I don't have time to go through 112 page so i would appreciate if you guys would just tell me a BLUF.
1) I have a 2011 Premium, would love to retrofit 13-14 GT500 cluster with track apps. Any known issues specifically on 11's?
2) Can someone post a list of ALL parts needed? That would be MUCH appreciated.
3) Will any new functions unlock after good installation?
If that matters my audio set up is stock Shaker 500. (i mention this is becasue on few pages i see people mentioning IDS flashing, so not sure if IDS is maestro IDS kit or something else.)
I realized\ cluster is needed, ebay doesnt have any at least today so if anything i'll get one from a dealer online.
Also from quickly reading, do i need to give them 13-14 GT500's VIN or any 13-14 VIN with trackapps?
This swap would be great!
My car is slightly modded already so the cluster would kind of set off the interior and i think would look cool with rev gauges on the ipad in the car.
Old Jan 6, 2016 | 09:04 PM
  #2224
RusWolf's Avatar
And i think i just answered all of these questions by finding another thread.. lol...
However, i would still appreciate it if someone answers my questions.
rewiring may take time...
anyone on the northeast done this?
Old Jan 7, 2016 | 07:46 AM
  #2225
DeeJayTJ's Avatar
there is a sticky about this or atleast about most of it.
Old Feb 25, 2017 | 11:36 AM
  #2226
BALIZTIK's Avatar
Anyone in California able to help me do this? Willing to pay.
Old Jun 12, 2020 | 04:52 PM
  #2227
JonCal Tovar's Avatar
how do i contact you to get the mod for OK switch?
Old Jun 12, 2020 | 05:10 PM
  #2228
How do i get the mod for the OK button to work on gauge cluster swap. Zeros inbox is full lol. Please contact me 915 478 2440
Old Jun 13, 2020 | 05:29 PM
  #2229
jim010's Avatar
Zero Aviation is no longer a member and has long since disappeared. Your best bet is to either redo the resistors as I had shown in the 5 way switch or to program your PCM to that of a 2013/14 car.
Old Jun 13, 2020 | 05:31 PM
  #2230
jim010's Avatar
Check the other stickied thread for how to do this.
Old Jun 14, 2020 | 11:32 AM
  #2231
Kona12GT's Avatar
check Facebook for a company called “arcanep2”. I think I had heard from somewhere that he has something to do with it.
Old Jun 15, 2020 | 01:17 PM
  #2232
jim010's Avatar
Well, the guy's name is Matt Honeycutt, and he uses the zeroaviation username for alot of things, so you could try and track him down that way.
If you do get a hold of him, tell him I want my cluster back!!
Old Jul 28, 2020 | 09:23 AM
  #2233
GoldenStang's Avatar
I swipe my 2010 GT500 Cluster to 2013, but I can't see Boost & oil pressure.
Can you help me it?
Old Nov 19, 2022 | 01:39 PM
  #2234
Dawson Skelley's Avatar
Originally Posted by jim010
OK, here it is:
2012
-to the clockspring (c2274a)
Pin 1 - airbag driver 1
pin 2 - airbag driver 2
Pin 3 - unused
Pin 4 - switch Audio w/ SYNC 2 -
Pin 5 - ground cross car beam
Pin 6 - switch Audio /w SYNC 2 +
Pin 7 - unused
Pin 8 - horn
Pin 9 - airbag driver 1
Pin 10 - airbag driver 2
Pin 11 - unused
Pin 12 - switch audio 1 -
Pin 13 - switch audio 1 +
Pin 14 - cruise control command return
Pin 15 - cruise control command
Pin 16 - illumination
2013
Pin 3 - switch info
Pin 7 - unused
Pin 8 - horn
Pin 11 - switch info
2012
-from clockspring (c2274a) to clockspring (c2274b)
Pin 1 - horn
Pin 2 - unused
Pin 3 - bluetooth
Pin 4 - ground cross car beam
Pin 5 - climate sensors and generic vref return in logistical schematics
Pin 6 - unused
Pin 7 - illumination
Pin 8 - cruise control command
Pin 9 - cruise control command return
Pin 10 - audio pwr
Pin 11 - audio return
Pin 12 - unused
2013
Pin 1 - horn
Pin 2 - unused
Pin 3 - bluetooth
Pin 5 - bluetooth return
Pin 6 - switch info
Pin 10 - audio pwr
Pin 12 - switch info
2012
- from clockspring (c2274b) to left steering wheel switches (c2998)
Pin 1 - illumination
Pin 2 - cruise control command
Pin 3 - cruise control command return
Pin 5 - horn
Pin 6 - unused
Pin 7 - unused
Pin 8 - unused
Pin 9 - unused
Pin 10 - unused
2013
Pin 1 - cruise control command return
Pin 2 - switch info
Pin 3 - switch info
Pin 4 - unused
Pin 5 - unused
Pin 6 - ground
Pin 7 - cruise control command
Pin 8 - illumination
Pin 9 - unused
Pin 10 - unused
So what are the exact steps to get the dpad to work in the 11-12 cars?
Old Nov 21, 2022 | 07:46 PM
  #2235
Daniel Tellez's Avatar
I just did the swap on an 11 today, you CAN use the INFO RESET SETUP BUTTONS to control the ok is done by tapping setup multiple times. Reset is right setup one click is down and Info + Setup is back.
Old Dec 30, 2022 | 04:27 PM
  #2236
jim010's Avatar
You can also take the d pad from a 13-14 and change the resistors in it to work. There is a post in the other thread somewhere on which resistors need to be changed. But really, the best thing to do is to program the car's computer to thinking it is a 2013 car. Then everything gets unlocked and works properly. Oh, and you need the abs module as well to get track apps to work.
Good luck
Old Jan 1, 2023 | 02:16 PM
  #2237
Berlioz's Avatar
Good luck
Prior to the new year I had an issue that CC did not engage what so ever, and that the only thing that I could get to work was the DPad under certain circumstances. If I do NOT flash to a 2013 PCM (I have a 2011), then the CC light will not turn on, but that will also require me to essentially tune the engine due to the 2013 PCM having different tables than the 2011 in regards to engine performance. With respect to doing this retrofit, I've read most of the instructions from this thread (https://themustangsource.com/forums/...luster-529167/)
I've managed to get the D-Pad & Cruise Control to turn on (without flashing PCM, so currently the CC Light will not illuminate). The problem I ran into the first time was that my soldering job was an abomination. I ended up buying a heat pencil from amazon, used solder paste to put the SMD resistors on, and it worked. The right tool for the right job, ya know?
Here's the layout for the pins and everything (image below)
Here are the resistors required (2.00x1.25mm):
2200 Ohm: https://www.digikey.com/en/products/...02K2L/14286388
1500 Ohm: https://www.digikey.com/en/products/...071K5L/5896629
300 Ohm: https://www.digikey.com/en/products/...7300RL/5896755
Jumper: https://www.digikey.com/en/products/...R-070RL/728216
Old Feb 26, 2023 | 10:39 AM
  #2238
3vClifford's Avatar
Will this guide work on a 2010? I am attempting to get my button swap working with the 2013 cluster I installed.
Old May 24, 2024 | 03:45 AM
  #2239
Mitka's Avatar
Gentlemen,
What pins did you use to reconnect wires in clockspring switches and light switch?
Old May 24, 2024 | 05:53 AM
  #2240
Mitka's Avatar
Another issue I came across when installing 2013 premium cluster into 2010 premium car is that I have OIL CHANGE REQUIRED message every time I start the car. Oil life reset doesn't help.
The thing is that I did not put any additional wires from light switch to cluster (C220), I have connected light switch directly to clockspring switch on the wheel from the cluster side. Can it be the reason? Please help
Cruise control does not work also.
