'13-14 Cluster into '10-12 car (with TrackApps) retrofit
#201
dmhines,
Do you have a part number handy for the 2013 cluster? I'm at work, but am in contact with United Radio. They will change the odometer reading, and will look into a couple other issues, but they want a part number.
#203
Part number:
DR3Z 10849 EA
Engineering number:
DR33 10849 EA
I'll be talking to their tech guy when he's off lunch.
They will change the odometer reading. You send in the cluster with proper documentation (Don't know what that is yet) and they charge $85.
DR3Z 10849 EA
Engineering number:
DR33 10849 EA
#207
3.7L 4V PFI V6 NA Gas, Instrmnt Clust-Unique Feat/Graphics, With MPH/KMH Speedometer
Required: 1
Also IC to
5.0L-4V Dual Over Head Cam SEFI NA, (+)"USA";
Thanks!
Last edited by zeroaviation; 4/11/13 at 10:46 AM. Reason: Cuz i didnt click the read more button :/
#210
I have another part number. Check these just in case. They may both be for Canadian cars:
DR3Z 10849 FA
Dr3Z 10849 DA
One of these is for a Boss, another is for a Canadian cluster.
DR3Z 10849 FA
Dr3Z 10849 DA
#211
So. This would be easy to do if you had your own VCM IDS...
BCE Modules
Module 760-01-01 BCE Value 016A
This is all based on a previous post i wrote distinguishing vehicles to the ICM.
BCE Modules
#213
Order Direct From FCSD-IDO
MOD 5.0L-4V DOHC SEFI NA, Instrmnt Clust-Unique Feat/Graphics, With KMH/MPH Speedometer
Required: 1
Bottom One:
5.0L V8 32V DOHC EFI Modular, With KMH/MPH Speedometer
Required: 1
#214
The problem is, will the BCE recognize this moduleSetting. Would you guys PM your Cal codes please? or stratagy ID's
#217
#218
Here is my tech guy responding:
Hi:
Best plan would be to book an appointment with one of the ladies in the cash office to ensure that I can get it in the shop ASAP. Tell them that I’ll probably need a couple of hours with it. You might want to just leave the old cluster plugged in but not fully installed just in case we run into problems. We will also require 2 keys to make it start, so bring them as well. If you have only one key, we will have to cut another (minimum of 2 keys). If your car has a remote starter we will need the transmitter to program it to the system. We have a menu price for electronic diagnosis ($155.95) that would cover the time to do the reset and programming of the keys. As I mentioned to you on Monday, I can’t vouch for whether all of the data will be available for the extra functions of the new cluster. We might end up having to reflash the PCM or other modules to make them match the cluster (make everything think it lives in a 2013 Mustang). If this is the case, some additional charges may apply. Please also bring the VIN for the car the cluster came from in case we have to obtain as-built data for anything. After you make an appointment, please drop me a quick note to let me know when it is coming so that I can try to free up some time.
#220
