Mustang 3.5L Ecoboost engine swap
#1102
One potential problem, the ecoboost control pack requires a specific pedal assembly. It has a picture of a mustang gas pedal but the part number is for a f150 pedal which looks totally different. I pulled the gas pedal out of my 2013 f150 ecoboost to try it and it's not even close. It's a huge assembly with 3 plugs and what looks like an electric motor on the back of it. I have no idea what that's for unless it's cruise control.
#1104
After more thought...the f150 2010+ 3.7 and 3.5 all use the same gas pedal, I don't see how using a 3.7 mustang gas pedal would be any issue. If it is an issue the pedals are cheap but installing it will be a PITA.
I looked at used 2010+ f150 pedals on eBay and they are similar to my mustang pedal, just one electrical connection. I'm not sure why my truck pedal is so different, I'm sure it's due to one of the options the truck has.
#1106
If it had clogged injectors, which I don't believe is the issue, it wouldn't cause the fuel pressure to drop. The HPFP has a fine mesh screen on the inlet, it was clean when I looked at it last night. Not sure what could have clogged the injectors.
#1107
Yes thats what I read. So at minimum it should be maintaining 200 psi. Your description of the smoke and fuel out of the exhaust drive me to believe in leaking/stuck injector/s.
About the pedals, doesn't your f150 have adjustable pedals!?
#1108
I see what you mean about the injector, I think we need to get the fuel pressure up first and see if that fixes the smoking.
#1109
It's a huge amount of white smoke, but it's not water vapor. If the engine was running out of gas why would it smoke? Flooding a cylinder could cause both white smoke and possibly fuel low pressure.
Here's a link to a flex with a similar problem
http://www.fordflex.net/forums/viewtopic.php?t=9081
#1110
After more thought and more Google research on ecoboost injectors actually you may be on to something. It's hard for me to believe the injector is clogged, that wouldn't effect fuel pressure in the way we are seeing. BUT if the injector was stuck wide open this could possibly cause the low fuel pressure and flooding.
LEXiiON
#1111
Yes please, if not I'll have to load it up and take it to the dealer to have them check it out. I'll replace it myself but the test would be nice to know if that's the problem before I tear it apart.
#1112
One more piece of evidence to support your theory. I've only driven 3 miles since the Mobil 1 oil change, I checked the dipstick and the oil smells like gas. This was one more diagnostic tool people were using to check for stuck injectors. Between the white smoke, rough idle, gas smell, gas in the oil, not starting....it's pretty clear now.
Oh and Lexiion do you remember how much water drips from the exhaust? The puddles underneath the car where the mufflers attach? That's another sign of a bad injector, I read that it happens from the fuel that isn't burned somehow. It was another symptom to look for. I thought that seemed excessive considering my Shelby or my truck don't drip near that much. 10 mins of running and there would be 2 good puddles underneath.
I found 2 new injectors on eBay for $35 each, I'll probably grab them both to have an extra for next time. After some investigation apparently there has been some issue with 11/12 injectors on the f150s, some people having multiple failures....not so much on the newer ones.
**** another mobil 1 oil change is going to cost as much as the new injectors. This thing has been a money pit lately.
#1113
Lexiion came over last night and we tried to run the injector test but we're not able to because the IDS was not able to start the car. No auto transmission among other issues. I found several places that can test direct injectors, I'll pull them all out and send them so I know for sure what's going on. It's only $5-20 per injector depending on where I see them.
#1115
The video pointed me to a decent torque converter for the 6R80 (its Achillies heel).
Many thanks.
#1116
Also, did you have to run a slave cylinder spacer with your Boss clutch and flywheel? I know the 3.7 can't run a GT clutch and flywheel setup without it, so I'm assuming the 3.5 is the same way.
#1117
I was just looking at those turbos the other day. I think they said it had a larger compressor housing though. Do you think there's clearance for these in the S197? It would be an awesome upgrade if they fit.
Your right, I barely cleared the steering shaft so these may not work. It was the exhaust side of the turbo that was close to the steering shaft, maybe that doesn't increase in size on the new turbos. That's a good question for me to ask him tomorrow.
I didn't know anything about a spacer so it doesn't have one. I used a GT flywheel, I wonder if that makes a difference? Clutch seems to work fine without it, seems like normal travel and pressure.
#1118
It's possible that the 3.5 is not compatible with the 3.7 clutch and stuff. I believe the main difference is that the 3.7 dual mass flywheel is thicker than the GT flywheel. But I would think that if there was an issue with your clutch setup it would be apparent by now. When I get my 2 engines side by side I'll try to take some measurements just to make sure. I just don't want to get everything installed and find out that the trans has to come back off to install a 100 dollar spacer.
#1119
#1120
The clutch would be too far from the slave cylinder. Apparently it can still work for a little bit though, but I don't really know how. This is an excerpt from a review of a flywheel that says it should fit the 3.7 but has no mention of the spacer:
"The V6 flywheel bolts were too long for the much thinner flywheel. This was the first warning that more parts are needed. A quick, courteous call to Ram revealed that you need the flywheel bolts from an '01 4,6l V8. So that slowed things down a bunch as very few places stock that on the shelves. After getting everything reinstalled and the clutch bled, the clutch throw was hair trigger & eventually the pedal stuck to the floor. The clutch was too far from the slave cylinder. Another set of calls & talking with the ford tech reveals you need a 1/2" slave cylinder spacer that a V8 comes with stock - which currently is only included in the V6 RAM HDX clutch. Ford DOES NOT stock this part, it's not in their parts computer anywhere. I was able to find the RAM spacer by itself after a couple days searching and now the car runs fabulously."
American Muscle really should mention this under technical notes, but they don't, and they don't sell the spacer by itself either. I feel like that's a pretty major oversight seeing as they say it's compatible with the 3.7. I'm sure you would have noticed the issue by now if you had it though, so I'm guessing that's just another difference between the 3.5 and 3.7 but I'll try to confirm this as soon as I can.
