Mustang 3.5L Ecoboost engine swap
#721
I added a line loc for a reason , you better believe there will be some smoky burnouts!
When I was 16 yrs old I got a ticket for doing a burnout. My dad told me that when I had to pay for my own tires I wouldn't be doing that anymore. Well dad my factory tires for my Shelby had to be replaced after 3k miles lol.
#723
Considering how much factory Shelby tires suck, I can see you burning them up just as an excuse to replace them, lol
#724
Lexiion came over again tonight and we made some headway. He established communication with the PCM but then we realized we need the pcm programmed to remove PATS and to remove the auto trans before we can start it. He's got a friend that can do this work so I will send the PCM to him tomorrow. Unfortunately it could take a couple weeks to get it back.
#726
#727
Eh, it's not that bad. There's a sheet of ice on my driveway and it's supposed to snow today so I'm not missing anything yet. If the weather was warming up I would have a greater sense of urgency and less patience for sure.
Also for the last 9 months I've been building this car there has been uncertainty on how the electronics were going to work exactly. At least we know now what needs to be done, so that's a huge step in the right direction. When the PCM comes back the car should start without any troubles.
I still have a few things to work on with the car, mostly to finish a few paint and body items before it can be driven.
#728
Lexiion has been working with the tuner/PCM guru on the next steps with the car. Sounds like they have a plan so I overnighted the PCM. He also had me buy a MPVI which is a programming tool that I can use here once I get the PCM back. He's going to make some major adjustments to the PCM programming on his bench and then ship it back to put it back to us. Whatever additional changes that are required can made here using the MPVI, it will also allow the tuner to custom tune the engine remotely. I'm not sure how all this works just yet, I'm learning as we go.
I'll probably get to paint the rear bumper this weekend and get it installed. There are a few other small projects I'll knock out while I wait on the PCM to come back.
#729
My wife found this pic she took today, we picked the car up in Indianapolis at a copart auction. This is day 1!
Had to make this my avatar, it's a cool pic.
#731
#733
That was only 9 months ago, feels like years lol. Defintely saved this one from the graveyard, even most of the parts that were used were also from graveyard cars and trucks. I think I'll print this pic and put it in the glovebox to always remember
#734
I am confident that he can get us towards turning the key next week.
LEXiiON
#735
I'm looking in to classes to learn how to tune cars myself, there is a place in Florida that offers a 2 day course. Sounds like fun, I would be able to tune my cars between races to get the best performance based on the the parameters that day. Plus I already own the tool so it makes sense I learn how to use it.
http://www.thetuningschool.com/product/4121ls/
#736
Like Father...
I ♥ Sausage
I ♥ Sausage
#737
I moved my catch can to the passenger side pcv valve. I used a combo of pcv hoses I pulled of my Shelby and the ecoboost. Turned out nice.
I'm about to expose some snake oil sold to us. I'm actually pretty disappointed in the aftermarket companies selling catch cans for the drivers side and the "dual" catch cans. They have absolutely no value.
The pcv valves are only one way, the drivers side lets air in but not out, the passenger side lets air out but not in. So in other words the drivers side supplies fresh air to the crankcase and the passenger side exhausts the crankcase. I know this because I tested my theory by using a clean hose on both pcv valves And blowing air in to them. I always wondered why my Shelby drivers side catch can didn't have any oil after 7k miles.
This should be a thread by itself, to stop people from wasting money on products that shouldn't be sold.
#739
#740
The drivers side pcv pulls from the air intake tube, the passenger side exhausts air in to the engines intake. There's always more vacuum behind the throttle body than in front of the throttle body, unless you are under boost. What curious is how the ecoboost vents the crankcase while under boost? The passenger side pcv valve is set up on the Eco to only vent while the engines intake is under vacuum. With the Shelby for example the pcv exhausts before the supercharger so it's always under vacuum. I suspect that the driver side pcv for the Eco most likely has a way to bypass if the pressure builds up, which I wasn't able to replicate using my lungs.
Here's a cool video of a properly installed catch can in action. In case anyone questions why these exist, the oil/gas/water vapor pulled from the crankcase is mixed with the air that feeds the engine and it causes the octane to be lowered of the fuel being added. This makes the PCM pull timing to prevent detonation lowering horsepower. This seems to be more of an issue for boosted vehicles which makes sense, there's more air pressure inside the cyclinder so therefore more oppritunity for blow-by.
Check out the vid especially around 1:30. Oil really comes out when they let off the gas, this is when the cars intake is in vacuum.
