Mustang 3.5L Ecoboost engine swap
Old Aug 18, 2015 | 08:39 PM
  #181
unnoticedtrails's Avatar
Originally Posted by Ecostang
Got the 3" exhaust today, this should bolt up to my gt500 quad tips. I'll need a custom piece with cats installed to connect the x pipe to the ecoboost manifolds.
Awesome project!
Old Aug 18, 2015 | 08:40 PM
  #182
Ecostang's Avatar
Rear end also arrived
Old Aug 18, 2015 | 09:11 PM
  #183
YepItsGreen's Avatar
Love this tread you gonna make some videos for us?
Old Aug 19, 2015 | 07:46 AM
  #184
Ecostang's Avatar
Awesome project!
Thanks!
For sure, as soon as I get it running I'll post a video. Second video should include tire smoke
Old Aug 19, 2015 | 12:25 PM
  #185
boss man's Avatar
For sure, as soon as I get it running I'll post a video. Second video should include tire smoke [/QUOTE]
Just be careful with the tire smoke. Would'nt want to void your manfacture warrenty
On a serious note...I'll be wating for the video.
Old Aug 22, 2015 | 12:24 PM
  #186
Ecostang's Avatar
Finally some progress, got the lower radiator hose buttoned up. The ecoboost comes with a water-cooled oil cooler and I was able use it along with most of the factory ecoboost lower radiator hose. I used a shelby radiator so it had a 2" connection and the ecoboost is 1.5", I found a silicone reducing 45 degree fitting that took care of the transition.
Old Aug 22, 2015 | 12:28 PM
  #187
Ecostang's Avatar
I also got the heater hoses hooked up but still need to put on the hose clamps. I had to order a flexible hose for the upper radiator.
I also got all the air conditioner lines hooked up and ready to vacuum down.
Old Aug 22, 2015 | 12:46 PM
  #188
LEXiiON's Avatar
Nice! Great to see this project coming along. Let me know when you want to chat about EPAS and ABS and pick up your harness.
LEXiiON
Old Aug 22, 2015 | 08:30 PM
  #189
Ecostang's Avatar
LEXiiON
Thanks Lexiion, I should be ready for that in a couple weeks.
Old Aug 22, 2015 | 08:35 PM
  #190
Ecostang's Avatar
Got the old rearend out today and prepped the new rearend to go back in. I also installed the x-pipe and mid pipes, waaaay easier with the rear end out.
Old Aug 23, 2015 | 12:47 PM
  #191
TimeWarpF100's Avatar
Still following your build closely! AweSome!
I was finally able to take my Maiden Voyage in my EcoProject yesterday.
Exciting stuff to finally be able to drive it . .
And yes all the electronics work. No codes or issues with exception to the AirBags which are still being figured out.
Old Aug 23, 2015 | 02:30 PM
  #192
Ecostang's Avatar
Man that's awesome! Congrats
Old Aug 23, 2015 | 02:37 PM
  #193
Ecostang's Avatar
New rearend installed, 3.73 gears. Also added some aftermarket lower control arms. Now I need to order the one piece driveshaft to finish the drive train install.
Old Aug 23, 2015 | 03:18 PM
  #194
SpectreH's Avatar
Nice work! I went with the Driveshaft Shop's carbon fiber unit. Smooth and quiet. I've heard some of the aluminum units make a clunk on automatics when engaging reverse or drive. The CF one is quiet. Probably a non-issue in a manual car.
Old Aug 23, 2015 | 03:22 PM
  #195
Ecostang's Avatar
Upgrading rear brakes to gt500 13.8" rotor, I bought the brackets to adapt it. The rear calipers on the gt500 and v6 are the same from what I've read. All you need is these brackets and the rotors. I got the brackets off eBay, search 13.8" brakes for $130 (I think) and $75 each for the OEM rotors. Very simple upgrade for track cars, would be pointless for street cars.
http://www.ebay.com/itm/05-14-Mustang-14-Rear-Brake-Rotor-Adapter-Brackets-GT-Boss-302-GT500-V6-13-8-/161797211451?hash=item25abdd853b&vxp=mtr
Old Aug 23, 2015 | 03:25 PM
  #196
Ecostang's Avatar
I'll check them out, only one vendor so far is willing to make the custom driveshaft. I need a v6 length but v8 mounting for the rear end. Nothing crazy but 3 other shops told me no.
Old Aug 23, 2015 | 03:32 PM
  #197
SpectreH's Avatar
I ordered mine through American Muscle. Not sure if they would handle the custom work or if you'd need to contact the Driveshaft Shop directly.
Old Aug 23, 2015 | 08:50 PM
  #198
As I was catching up on this thread, I was literally about to tell you to do this while you're at it!
Old Aug 25, 2015 | 07:36 PM
  #199
Ecostang's Avatar
I got a 2012 gt500 cluster today. I mainly wanted this for the adjustable rpm shift chime and shift light, plus it was a really good deal. Has 106 miles on it lol, must have been one hell of a test drive. Also has adjustable colors and adjustable steering selector. Has a boost gauge but it will peg out at 15 psi, I should be around 25 psi one day.
Old Aug 25, 2015 | 09:19 PM
  #200
Ecostang's Avatar
No need for a custom driveshaft, I figured out that I can simply change the mounting flange on the rear end I have now to a V6 mount. The mount is only $30 and it's just a large nut that holds it on. This saves me about $250 on the driveshaft, not having to have it custom made.
