This is why shocks matter.....
#162
Ahhh, the limited slip unit is the same no matter what gear set you pick.... makes no difference, it was just used up. There are better differentials than the stock Trac-Lock but again the gear ratio has nothing to do with how long they last/how they work, a 3.15 auto comes with the same LSD as a 3.73 stick (unless you get the optional Torsen in the Boss, which isn't bad--but still not ideal for track rats).
Ok, the Torsen is better than the Trac-Lock LSD but not ideal.
So what do I want??
#163
I'm guessing Sam's answer is going to be this --> Eaton http://www.stranoparts.com/partdetai...=186&ModelID=5
![](http://www.stranoparts.com/showimage.php?p=data/images/p44219164229.jpg&w=244&s=1&a=1)
#164
That's one option which is similar to a T-Lok, but has a much better spring setup and carbon clutches to start with. Truetrac is another. Rebuilding the stock diff with carbon clutches is another. Torsen T2R is another (but I pretty much quit selling those as they are hard to get and don't last like they used too). The lesser Torsens just don't have as much bias ratio as we'd really want (Truetrac is in the same area as a Boss Torsen).
#165
I had a 28 spline Auburn pro in the rear of my 97 GT. Worlds better than the stock unit but i don't know how well it would be suited for the track.
#166
#167
#168
#170
My car is a 3.31 car because anything else would be too short and force me into 3rd gear when autocrossing on my Hoosiers. In fact the 3.73 is super short on stock tires, something like 60 mph max. Funny part is when you watch the video from Motor Trend you can see the M3 pull the Mustang because it's shifting so much. And I hear that they need 5th at the end of the 1/4. I think 3.73 is a hype setup more than anything and that 3.55 is probably the better drag gear. And I've very happy with my 3.31 for corner carving.
#171
If you run the numbers, a 3.73 car can't make 60 in 2nd gear but the other can. And they test what they are given... Also test methods vary, surfaces vary, and if CR wasn't in a Brembo car the tires aren't as sticky either and of course if they were on 87 they were down on power and torque too.
There are a ton of variables and it's my opinion that 3.73's aren't really any quicker 0-60 on a street car on street tires.... and force an unshift to 5th in the 1/4 mile (which if you watch the video is when the M3 pulled back a bit).
#172
As a road-course guy, I spend most of my track time in 3rd gear, with the occasional drop into 2nd and the occasional bump to 4th, maybe 5th on a long straight. The 3.73 is a reasonable choice for that duty cycle.
#175
Hmmmm....
I might be looking into this at some point.
Exactly what do you mean by weak, though, like they burn up then start slipping, allowing too much wheelspin? What's a typical shop cost to get one of these installed (I think it's beyond my meager skills).
Thanks Sam
Thanks Sam
#176
Exactly, they are not prone to breaking... just wearing out quickly and causing handling issues. The car will not only get out of corners as fast, but will also become more power on loose.
Labor I can't tell you, every shop wants to do it differently. Take me about 3 or 4 hours not killing myself for a swap (no gear change).
#177
Anyone here with the Steeda Sport springs have any issues with ground clearance. I would love to improve the suspension on my car but my car is going to be an 80% street car and the roads around her suck.
Any bottoming out on speed bumps or potholes with the lowering springs?
If there are issues, are there any performance springs that do not lower the car that much that are better than the Steeda's?
Would my car benefit from just changing the shocks and struts and leave the stock Brembo springs?
THanks!
THanks!
#178
I had the Steeda Ultralites, which lower the car as much, if not more than, the Steeda Sports. I didn't really have any ground clearance issues, unless there was a really, really high speedbump, or a high parking berm. At the same time, I wasn't that impressed with the Ultralites. I'm more of the belief that unless you're racing professionally, most of these aftermarket parts are not that great in comparison to what Ford already puts on these cars, and even then, you're going to create problems which will cost even more money to fix. Just my two cents.
#179
JCC07 I do feel you are in minority there. Parts work in combination and sometimes there are variables that certain things work better for. Soft ride, stock shocks and springs are the softest. But as stock shocks age they lack control and tend to ride impacts more and more poorly. If you want a stock type replacement damper then you can go back to stock...most want to upgrade.
And I make this point a lot. Everyone has a opinion, everyone... and they are never exactly the same. It's what makes the world go 'round. However, when you find a great majority of folks liking something and a few that don't with details about why they feel that way, there's a good bet that the majority opinion will apply to more people. And frankly your in the minority on this one. That's not making you wrong, not at all.. just of a different opinion. And for what it's worth, your list of parts has a lot of FRPP stuff on it. FRPP relabels stuff all the time. On your list, you don't have much that is like that, but just something to bear in mind when you say that ford parts are better in general.
#180
Subd'.... Sam...I'm learning a ton from this thread...I'll be looking to purchase parts from your store for my suspension upgrades. (and recommend you to others in the Mustang and Camaro world) I like many others have a street car that is well...strictly street for daily driving and the occasional back road romp. 2011 Mustang GT non-brembo 3.73. Might auto x road race or drag the car to get some 'data' for my own satisfaction but nothing heavy.
Looks like the Steeda sports are the way to go for street comfort. I appreciate your view on progressive vs. linear springs. I would've gone after the progressive springs thinking I am getting ride comfort and handling improvement when it sounds like the ride is worse on the street vs the linear. Mainly due to the spring rate...
In any case sounds like I want/need the following to have a 'complete kit'
1.0 springs
2.0 shocks/struts (Koni Yellow or ST)
3.0 camber bolts (Do I need Trailing arm/pro alignment kit?)
4.0 adjustable pan hard bar.
5.0 Upper Strut Mounts
6.0 Upper Strut Mount bolts
Anything else needs to be adjusted to compensate for the 1 to 1.5 inch drop on the suspension?
Looks like sway bars would be considered if I wanted to reduce body roll further? Would it be safe that adding bigger front and rear sway bars could make the ride a little too stiff for the street? Also I don't know that a rear bar would be that great for the street anyway as I don't want to end up backwards or spinning out with some 'spiritied' driving.
If this is something that requires a phone conversation that's cool too as I'm unsure of the adjustable yellow koni vs non adjustable. I've read the 'better to have options' piece, and 'rather set it up for what I am doing with the car or roads I am driving on'...however there is something to be said for getting balance in the valving by somebody in R&D from the factory. I presume the Koni line matches the steeda sport and the stock springs as necessary.
What's your take on the folks at 'other' shops encouraging GT500 take off shocks/struts with Steeda Sport springs and GT500 sway bars? Seems like the shocks/struts would be valved for a little heavier car, with more weight on the nose. Or would something like that be solid for a street car and comfortable?
1.0 springs
