Performance And Tech
#1302
Gotta love nitrous!
#1303
i have the obx headers that i bought off of jeff. they went on without any problems other than having to use some new bolts on the drivers side. the quality is good, all the welds look great.
pull the starter and disconnect the steering shaft, jack the engine up a little and they go on pretty quick, i did mine in the garage by myself with no problem. the only thing to watch out for is the drivers side hitting the steering shaft, i had to pull mine back off and flatten it out where it contacted the steering shaft, now no problems.
if you are thinking of motor mounts, do them at the same time, they are a pain after you get the headers on!@
#1304
Good tips Doc!
#1305
Doc... did you notice any dif in power with th e headers? How about the motor mounts? NHV?
#1306
i don't know about any power increases, the exhaust sounds meaner. there is a little increase in nvh with the motor mounts but it is not to much
#1307
They are most loud! That's for sure.
#1308
2006 Mustang Gt Prem/ Manual/Black
Mods: Roush Suspension, Roush Shifter Kit, Granatelli Intake Tune, Roush Underdrive Pulleys, Flowmaster 40's, MMR Throttle Body Spacer, NX Iceman Series 150 Wet shot.
Appearance: 6000 k HID'S, A Pillar Gauges, Black Out kit, Tints All the way around.
#1309
Well we got my brothers motor in and started! Prrrs like a kitten. let her get up to operating temperature...changed the oil....drove her for 15 miles keeping her under 3500Rpms....changed the oil again. Now there is a 500mi break in period increasing the RPMs as the milage goes up...then changing the oil again. Going to put synthetic in her after the 1000mi mark. There are some kinks we need to work out... we think the exhaust is rubbing on the body a little. Also you can feel the motor (vibration) a little more than normal...you can feel it in the steering wheel and the shifter...vibrates a little. Its possibly the Prothane Motor Mounts we installed (ya think?)
#1311
Yep The mounts + if the exhaust is touching the body you will get some vibration from that as well.
#1312
We're you driving? If so, I'd go with the driver....
#1313
durr durr durr... There is also a popping sound when the clutch pedal is depressed.... Clutch is working fine...but again there is an ominious pop....any thoughts on that David?
#1314
Cable perhaps?
#1315
went to archangel today and jeff's car is close to being done.Kurtis is going to have a good facility when completed.He asked about my tune and wanted to know if there were any problems.I think i will look for a mgw shifter.I would also like the steeda tri ax.
#1316
The tri-ax is what I have and I love it.
#1317
#1318
They answer everytime I call. His wife is working at the shop answering phones and helping with paperwork. The shop number is 437-7729.
#1320
