Performance And Tech
#1201
#1202
It's from all the Vista paint chips Jarrod. I think Doc told me that they make a pill for that though.
#1203
The Pill is called Bestangis HP.
#1204
Bestangis HP= Best stang is Horse Power? ummm ok
#1205
This is different
MMR Distributor System for 2005-2008 Mustang GT
As used by the MMR raceteam to produce 2000+ HP. Allows use of std. Ignition system and aftermarket ECU systems such as FAST or DFI.
Includes Valve covers and Billet Aluminum MSD Distributor and dist. drive assembly-easy bolt on!
#1206
Anyone want an intake for 3k dollars? not me
MMR "SPYDER" Manifold
Simply the baddest manifold available for your High HP 2005-2007 3 Valve. Available for 4.6 or 5.4 with different throttle body locations, includes Billet Fuel rails. Good up to 1600 HP and up to 8000 RPM.
#1207
i could weld one...
#1208
it looks like a cheap aluminum weld IMO... paul probably could weld one. now if that was a price for a full motor, than i'd say thats a good deal, but who would spend that on a manifold! thats my .02
#1209
Cheap aluminum weld? are you crazy? look at the beading! This is a beautiful welding job IMO
#1210
Not up to aircraft standards,looks like gorilla welding to me,strong but ugly
#1211
#1212
#1213
Not supposed to be sturdy...its sheet metal
#1214
Posted by David.... A$$
What causes the "noise" in the signal? Is it shrouded some way or not placed properly in the airstream?
I have the Racer from C&L and have no issues with throttle lag or such gremlins. I run 3-4 tenths quicker than a couple of guys with similar setups and different CAI (read: JLT).
3-4tenths quicker huh
which guys are you referring to?
I will say that driveshaft helps. my best yet is 12.79...but we both know the car with some powershifting can go faster. 12.79-12.61 = .18 faster
just having some fun with you David...hehe
#1215
#1216
From Jarrod A$$.
Noooooooooooooooooooo!!!!!!!!!!!!!!
ZING!
ZING!
#1218
What Andrew said.
#1219
I was just curious who was 4 tenths behind you with a JLT thats all..... ZING!!!!
#1220
