Where does the 2013 GT 5.0 get the extra 8 horsepower?
Old Nov 23, 2011 | 07:22 AM
  #101
VTXFrank's Avatar
Ford hires some "fresh out of school" engineers to tea bag each cylinder.
Old Nov 24, 2011 | 12:38 PM
  #102
AzPete's Avatar
,,,,,sound tube delete......lol
Old Nov 24, 2011 | 05:19 PM
  #103
cinque35's Avatar
^ funny but wish they did, it's total rice.
i removed it on my '10 and will on my '13. all i wanna hear is the exhaust not some stupid video game sounding crap. not to mention how bad it looks under the hood
Old Nov 25, 2011 | 09:31 PM
  #104
bob's Avatar
bob
Originally Posted by 06GT
Roller muffler bearings.
Watch out! Some black Ford E-150s are headed your way
Old Nov 26, 2011 | 08:24 PM
  #105
2 Go Snake's Avatar
Smile
To me , it would appear the engineers would change the tune because of internal changes. Probably , probably, the engineers would not feel the needed tune do to the internal changes was not enough to tell many people about. So all may be correct when saying either tune or internal change, just not completely correct.
Old Nov 26, 2011 | 08:25 PM
  #106
2 Go Snake's Avatar
Smile
By the way, If I still liked the car design, I would trade my Mustang in for an 8 horsepower gain.
Old Nov 26, 2011 | 08:53 PM
  #107
Thomas S's Avatar
Got the latest issue of Autoweek today. According to them the extra hp is, and I quote:
"...thanks to the internal friction reductions migrating from the Boss 302 engine."
Old Nov 26, 2011 | 08:55 PM
  #108
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
Old Nov 26, 2011 | 09:05 PM
  #109
Double-EDad's Avatar
What I don't understand is why all the secrecy about it? Why doesn't Ford just provide the deets now? Like Elton John reading a Playboy, it makes no sense.
Old Nov 27, 2011 | 07:45 PM
  #110
eric n's Avatar
While I have no actual proof, I'm going to guess Santa!
Old Nov 27, 2011 | 08:31 PM
  #111
TheReaper's Avatar
My theory was shot down and I'm still waiting on some factual info. The Santa thing does sound pretty good.
Old Nov 29, 2011 | 10:06 PM
  #112
jaguarking11's Avatar
I can almost gurantee ford used a different piston coating on the skirts.
Secondary though is they micro polished and coated all the bearing surfaces although unlikely.
Either of those gets around 10hp.
As for DI, Ford should and will do DI on a variant of the 5.0, as for aftermarket, they will either have to overdrive the injectors or make higher flowing units. However DI engines starve in the upper rpm, this is where the aftermarket could potentially add port injection on-top of the di setup, this would mean a much flatter torque curve with a higher detonation threshold. This allows the secondary injectors be placed much higher in the runners giving inter cooling effect, di also cools the charge drastically as well.
Imagine a 5.0l mustang pushing 450-500hp in NA form and netting 30+ mpg.
Old Nov 29, 2011 | 10:18 PM
  #113
Bear Eats King...
Bear ****s Bone
Wouldn't adding upstream injectors defeat the purpose of Di?
Old Nov 30, 2011 | 01:33 AM
  #114
tom_vilsack's Avatar
With the new crosseyed hid's the mustang doesn't know where it's going,so just thinks it's going faster.
Old Dec 2, 2011 | 11:33 PM
  #115
2011 Kona Blue's Avatar
Originally Posted by dmhines
I think 11/12 folks are thinking the 2013 may be more durable.
That's funny because no doubt hands down I bet 13/14 folks will be thinking the 2015 may be more durable.
Then the 15/16 folks are thinking the 2017 may be more durable and so on. Where does it end. Enjoy what you got run that pony into the ground and then start all over with new and repeat.
Old Dec 3, 2011 | 06:22 AM
  #116
MRGTX's Avatar
I like that attitude...but I also envy that attitude.
I love MY Mustang. I guess I'm just not "Zen" enough to let my car go and trust that I'll be ready for the next one.
What I want is the best possible version of the Coyote in the car I have now...and while I want Ford to make ever better versions, I am a big enough man to admit that I'd be A-OK for progress to stay sill for a couple years before the motor is labeled inferior.
Old Dec 3, 2011 | 09:40 AM
  #117
bob's Avatar
bob
IIRC Lexus has a hybrid DI/PI system on one of thier V8s, at low engine speeds and idle it uses port injection then transitions to direct injection for the rest of the operating cycle.
I think this was done to offer the smoothest possible engine operation rather than any performance advantage.
Using an ad hoc port injection system to get around DI tuning limitations and problems is a pretty sound (albeit complex) idea and something that was done back in the 80's and 90's to address the limitations of the first domestic fuel injection systems when they didn't have the variety of injector and pump sizes we have today.
I think I saw this used on a turbocharged Lingenfelter vette back in the old 1st gen smallblock days. They used his signature manifold and plumbed the injectors way upstream in the plenum area.
I've also seen a supplemental injector set plumbed into the throttlebody spacer on a pushrod 5.0 for a high horsepower forced induction application.
The advantage of doing this is that you dont have to interface with the factory controller or fuel system at all, just plumb in the hard stuff and tune it to work in harmony with the factory fuel system.
Old Dec 3, 2011 | 11:26 AM
  #118
Scottward's Avatar
The 2006 IS350 with its 306 HP 3.5L 2GRFSE motor was one of the first engines to use the hybrid dual injection strategy. Per the attached tech article, engineers were able to get better FE and combustability vice going to pure DI. Another tech article had mentioned slightly better low end torque, but I can't find it. As a previous owner of a 2008 IS350, I can report that it worked well.
http://r-gt.com/wp-content/uploads/2011/04/2gr-fse.pdf
Old Dec 4, 2011 | 01:39 PM
  #119
rhsab's Avatar
In my opinion, in addition to all these good suggestions, Ford probably is using ZMAX like the Shelby line.
Old Dec 4, 2011 | 02:08 PM
  #120
MARZ's Avatar
Swamp Donkey Aficionado
HAHAHAHAHAHAHAHAHA!
Wait, that was a joke, right?
