Notices
Sponsored By:
Sponsored By:
Actual weight 3,603!
Old 12/29/09, 09:52 AM
yeahyouknwit's Avatar
Exclamation Actual weight 3,603!
Ford has updated the weights 3,603 coupe 3,720 for vert
http://media.ford.com/images/10031/2...g_GT_Specs.pdf
Edit...
just saw someone else posted this as well
Originally Posted by rayainsw
Not sure where to post this -
with all the 2011 threads here, but -
The 'official' weights have been corrected here:
Old 12/29/09, 09:58 AM
Boomer's Avatar
THAT sounds about right
Old 12/29/09, 10:03 AM
coffeejolts's Avatar
So that's about 30 lbs heavier than 2010, but with 97 additional hp and a six speed transmission.
Old 12/29/09, 10:05 AM
Sounds like a winner to me :-)
Old 12/29/09, 10:07 AM
Cooper424's Avatar
lol just take out that spare tire ;P
Old 12/29/09, 10:08 AM
MBK
MBK's Avatar
yeah but anyone can come up with a weight figure ... (camaro 5)
Old 12/29/09, 10:09 AM
PTRocks's Avatar
So that's +70lbs over the 2010 numbers claimed here.
2010 Specs (Coupes only)
V6 - manual 3401lbs
V6 - auto 3454 lbs
GT - manual 3533 lbs
GT - auto 3581 lbs
Old 12/29/09, 10:17 AM
John H's Avatar
So, a GT coupe lbs. per HP is:
11.2 (2010) vs. 8.7 (2011)
Old 12/29/09, 10:23 AM
fdjizm's Avatar
LOL @ some people on other forums saying the car is going to weigh close to 4000 lbs
Old 12/29/09, 10:29 AM
2010MustangGT's Avatar
The 2010 stock gt 5 speed bone stock no options tipped the scales at 3533lbs with a weight dist. of 53/47. Equipped (motortrend's example) it saw: 3572 lbs with a (53/47%) distribution.
The 2011 bone stock no options is in at 3603 54/46% weight distribution. So that's 70lbs more- still not too bad. But figure an extra 20-50lbs for options.
(Also what roll will that 54/46 vs 53/47 play? Is the 2010 more balanced?? )
3533lbs / 315 hp = 11.216lbs/hp
3603lbs / 412 hp = 8.745lbs/hp
Optioned Weight
3572 / 315 = 11.339lbs/hp
3650 / 412 = 8.859lbs/hp
Whichever way you slice it. It's still awesome numbers.
Old 12/29/09, 10:34 AM
3Mach1's Avatar
Yep, this wont make the haters happy.
Old 12/29/09, 10:35 AM
whysoserious's Avatar
Awesome. The spec sheet also says forged steel connecting rods. The article from Autoblog says the following though:
"The connecting rods are forged powdered metal and the pistons are hyper-eutectic (translation: they contain a higher concentration of silicon, which helps reduce thermal expansion)."
Is this just oversight on whoever wrote the spec sheet, in the same way that the weight was 200# off?
Old 12/29/09, 10:38 AM
Swamp Donkey Aficionado
MARZ's Avatar
Nope, they're forged powdered metal, unfortunately.
Old 12/29/09, 10:47 AM
In any case, I'm assuming that forged powdered metal is an improvement, be interesting to see how much stronger they truly are. Guess we'll have to wait for someone to throw a rod to find out...
Old 12/29/09, 11:09 AM
Yeah. This car is going to be nuts.
Old 12/29/09, 11:11 AM
MARZ's Avatar
No, they're the same material as the current 4.6L 3V's rods. That's how powdered metal works: they take metal "powder" and through excessive amounts of heat and pressure, they then "forge" a rod, rather than forging from billet.
Old 12/29/09, 11:15 AM
Falchion's Avatar
That weight sounds a lot better. I'm glad the new 2011 isn't 4000 pounds!
Looks like they also changed the size of the front brakes. Yesterday it was 11.4 I think?
Thanks for posting!
Old 12/29/09, 11:21 AM
yes they updated the brakes as well. 13.2 up front and 11.8 out back
Old 12/29/09, 11:39 AM
MOTM Committee Member
stangfoeva's Avatar
I have to go to camaro5 now and read their denial. Just hope the thread isn't locked by the time I get there!!
Old 12/29/09, 11:47 AM
05fordgt's Avatar
You mean like that troll Matt on Autoblog?
Quick Reply: Actual weight 3,603!
